High fuel pressure in Shrike
n55bz(at)cox.net
PostPosted: Mon Apr 10, 2006 1:14 pm    Post subject: High fuel pressure in Shrike Reply with quote
Check the pressure regulator on your engine driven fuel pump.
rsrandazzo(at)precisionma
PostPosted: Mon Apr 10, 2006 3:07 pm    Post subject: High fuel pressure in Shrike Reply with quote
Tommy-
This happened on our 685 about this time last year. Had high fuel pressure
at idle power, and low fuel pressure at high power... Local mechanic was
able to make an adjustment to the fuel pump and the problem went away....
Cost me about 2hrs in labor, as I recall.
Good luck!
Robert Randazzo
YOURTCFG(at)aol.com
PostPosted: Tue Apr 11, 2006 7:35 am    Post subject: High fuel pressure in Shrike Reply with quote
HI TOMMY.
The pump s fine, the fuel control needs adjustment. It is not a
super simple adjustment, but can be done in the field. It requires the partial
disassembly of the unit and the replacing of shims. It should only be done
by someone who has some experience. Or, you can remove it and send it to an
overhaul facility for recalibration. jb
PostPosted: Tue Apr 11, 2006 1:23 pm    Post subject: High fuel pressure in Shrike Reply with quote
Tommy-
Correcting my previous response: I mis-spoke- it was the fuel control, not
the pump that we had adjusted.
Robert
