RV6 vs RV7
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
greghale
PostPosted: Tue Dec 08, 2009 4:45 pm    Post subject: RV6 vs RV7 Reply with quote
I am wanting to buy and RV7A or RV6A. It seems the RV7s are higher in price than an RV6s. What are the differences between an RV6 and RV7. Is there any advantage to buying an RV7 over and RV6 or vice a versa. Thanks for any replies.
Greg...
- The Matronics RV6-List Email Forum -
http://www.matronics.com/Navigator?RV6-List
Greg Hale rv10 -- N210KH
www.nwacaptain.com
ceengland(at)bellsouth.ne
PostPosted: Tue Dec 08, 2009 5:45 pm    Post subject: RV6 vs RV7 Reply with quote
Greg...
www.nwacaptain.com
Hi Greg,
The -7 has a bit more fuel capacity, it's designed for up to 200 hp
(though that's been done on -6's), and has a bit wider spread between
empty & gross weight. IIRC, the acro gross wt is a bit higher too,
meaning you can stay safe with 2 bigger people in the plane.
The fuselage width is the same.
Hope that helps,
Charlie
rledwards9(at)yahoo.com
PostPosted: Thu Dec 10, 2009 3:58 am    Post subject: RV6 vs RV7 Reply with quote
I asked Van this question at one of the air shows. He said it's about two inches different whatever that means. The vertical stabilizer is different and a little bigger I think. The rudder is balanced with weight now which might give greater flutter margins? Other small differences but I'm not sure they are worth the extra dollars. Kinda like buying a newer model car because people will keep their old one if nothing seems to change. RV6 N666R
--- On Tue, 12/8/09, greghale <ghale5224(at)aol.com> wrote:
Subject: RV6 vs RV7
To: rv6-list(at)matronics.com
Date: Tuesday, December 8, 2009, 7:45 PM
"greghale" <ghale5224(at)aol.com>
Greg...
www.nwacaptain.com
http://forums.matronics.com/viewtopic.php?p 76767#276767
Lists This Month --
Some AWESOME FREE Gifts!)
Raiser.  Click on
out more about
Gifts provided
www.aeroelectric.com
www.buildersbooks.com
www.homebuilthelp.com
              -Matt
Dralle, List Admin.
Forum -
FAQ,
   - MATRONICS WEB FORUMS -
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
