Adell Clamps?
rsrandazzo(at)precisionma
PostPosted: Tue Apr 11, 2006 1:39 pm    Post subject: Adell Clamps? Reply with quote
WCG-
Fascinating- you guys are piecing together segments of information that I
have gleaned from reading everything in the airplane's document bag. Saw
some references to Dick- and couldn't help but wonder what role 414C played.
Clearly the 685 is a bit underpowered when compared to the 690s, but I'm
certain taking a few hundred pounds off her will result in sound performance
improvements.
You mentioned the Adell clamps, and Milt mentions fire- can you guys give
me a quick education on this particular issue? (Few things frighten me
more than fire... I've done 5 engine failures and one control failure in my
career- but the one that scared me most was a fire indication in a lav... I
hate fire.)
I think I very well might have to invite Morris up for a day or two to spend
with my guys. They are a very capable organization who also knows when to
seek outside help. I told them I'm planning to keep "Charlie" around here
awhile so they are making an investment in being able to provide service for
her.
Robert Randazzo
n395v
PostPosted: Tue Apr 11, 2006 5:17 pm    Post subject: Re: Adell Clamps? Reply with quote
The early 685s had faulty or substandard fuel lines and owners were loathe to replace them. The nacelle is tight and hot so they deteriorated rapidly. Several ruptured and spewed fuel all over those big ass blowers and you can guess the rest. If I am not mistaken this led to an SB or AD requiring replacing of all hoses every 3 calendar years.
Your airplane is solid and once you get it back up to snuff it will serve you well.
Milt
CloudCraft(at)aol.com
PostPosted: Tue Apr 11, 2006 7:54 pm    Post subject: Adell Clamps? Reply with quote
In a message dated 11-Apr-06 14:40:19 Pacific Daylight Time,
rsrandazzo(at)precisionmanuals.com writes:
Robert,
Thanks for the opportunity to clear that up. After I launched that email and
went about my day, I realized I used the wrong name for the clamp I'm
describing. An Adell clamp is common and used to stand off tubes, wires and hoses.
This is not what I'm talking about.
I will probably have to ask Morris the name -- unless Bill Leff is here and
knows the answer -- but there is a stainless steel clamp that tightens with a
screw, kind of like a spring tensioned super hose clamp but much larger and
shaped with a groove if memory serves me well, that clamps down on the turbo and
the exhaust stack.
One 685 I flew had one that was not able to tighten enough. The symptom in
the cockpit was a drop in manifold pressure. The visual simptom was a pretty
hairy exhaust streak coming out the nacelle door. Scares me just to remember
it.
Anyway, I remember being told that "There are none," when discussing
replacing it as it was unique to the AC-685.
I'm sorry for being vague about something so important, but I can't recall
the name. Let's see .... it isn't a Sperthing Bearing, a Bellville washer or a
hydrocoptic Marzel vane. Isn't a transverse durakit .... not a retro
encabulator ...
Wing Commander Gordon
Life is not simple anywhere. Probably less so elsewhere.
swperk(at)earthlink.net
PostPosted: Tue Apr 11, 2006 9:27 pm    Post subject: Adell Clamps? Reply with quote
Is it called a "V-band clamp?" I've seen those used in other high
temp/high strength applications.
Stan Perkins
N681SP
28bravo(at)comcast.net
PostPosted: Tue Apr 11, 2006 9:37 pm    Post subject: Adell Clamps? Reply with quote
WCG:
That clamp is the ubiquitous Marmen clamp, commonly used to keep your
"hairdryer" in place. It is a "V" band clamp that is prone to failure. It
would be wise to safety wire these clamps with .040 stainless safety wire to
prevent unwanted catastrophic leakage of exhaust gas. Also it is a good idea
to remove them at least every annual and do a thorough visual inspection
under magnification to check for cracks.
Dennis
wjrhamilton(at)optusnet.c
PostPosted: Wed Apr 12, 2006 6:32 pm    Post subject: Adell Clamps? Reply with quote
Guys,
Go easy on Bellville washers, many an aircraft
with a wooden prop has had all sorts of nasty
things happen with disintegrating/ departing
props or parts thereof, because they didn=92t
understand Bellville washers =96 Schnizzentight is
not always the way to go, indeed RTFM.
Perhaps you are thinking of Marmon clamps.
Cheers,
Bill Hamilton
Robert,
the exhaust stack.
it.
encabulator ...
CONFIDENTIALITY & PRIVILEGE NOTICE
W.J.R.Hamilton,Glenalmond Group Companies,Fighter
Flights Internet Services and Warbirds.Net. & <wjrhamilton(at)optusnet.com.au>.
This message is intended for and should only be
used by the addressee. It is confidential and may
contain legally privileged information.If you are
not the intended recipient any use
distribution,disclosure or copying of this
message is strictly prohibited.Confidentiality
and legal privilege attached to this
communication are not waived or lost by reason of
the mistaken delivery to you.If you have received
this message in error, please notify us immediately to:
Australia 61 (0)408 876 526
Dolores capitis non fero. Eos do.
