SWAK
Desmor944(at)aol.com
PostPosted: Tue Jan 10, 2006 7:54 pm    Post subject: SWAK Reply with quote
In a message dated 1/10/2006 6:08:50 PM Eastern Standard Time, rvfltd(at)televar.com writes:
cgalley(at)qcbc.org
PostPosted: Wed Jan 11, 2006 4:44 am    Post subject: SWAK Reply with quote
Another similar product one can find at an automotive store is Loctite PST. Works the same way and Loctite may make SWAK for Swagelok. Neither product should be used on flared fittings. If they are damaged, they need to be replaced or use an approved metal v-seal between the surfaces.
Cy Galley - Chair,
AirVenture Emergency Aircraft Repair
A Service Project of Chapter 75
EAA Safety Programs Editor - TC
EAA Sport Pilot
Edwin Curry
PostPosted: Wed Jan 11, 2006 7:57 am    Post subject: Re: SWAK Reply with quote
Doug,
We have done refurbishment to units after several years of service and found no problems removing SWAK connections. It does harden some but remains soft enough for easy removal. I do not have the data sheets on the product. I am sure that the company will provide data sheets to you if you request.
Edwin
