teamgrumman(at)yahoo.com Guest
Posted: Mon Jul 18, 2011 9:10 am Post subject: oil filter torque |
I've checked the torque AFTER i've installed the filter the way I like. Average torque is 75 inch lbs. (lbs-inches to be exact) The lowest was 68, the highest was 80. This is using engine oil.
| - The Matronics TeamGrumman-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
haveblue1(at)mac.com Guest
Posted: Mon Jul 18, 2011 4:46 pm Post subject: oil filter torque |
Gary,
Interesting. Describe "the way I like." I always learn something from your engine posts.
Bruce
On Jul 18, 2011, at 12:51 PM, Gary Vogt wrote:
Quote: | I've checked the torque AFTER i've installed the filter the way I like. Average torque is 75 inch lbs. (lbs-inches to be exact) The lowest was 68, the highest was 80. This is using engine oil.
Quote: |
href="http://www.matronics.com/Navigator?TeamGrumman-List">http://www.matronics.com/Navigator?TeamGrumman-List
flyv35b(at)minetfiber.com Guest
Posted: Mon Jul 18, 2011 6:13 pm Post subject: oil filter torque |
Why so loose? The torque spec is 16 lb.-ft.
Posted: Mon Jul 18, 2011 9:25 pm Post subject: oil filter torque |
Hi Bruce,
I thought I went through this already.
Just in case . . . . . I hand tighten and then use vise grips and give the filter a little snug. Nothing scientific.. What I have done over the past several months is to use an inch-lb torque wrench and, starting at 50 in-lbs I increase the torque until the filter moves.
I've never had a filter leak. Several year ago, I installed the safety wire With about 1/2 turn of slack to see if the filter ever moved. Never did.
Gary
On Jul 18, 2011, at 5:43 PM, Bruce Smith <haveblue1(at)mac.com (haveblue1(at)mac.com)> wrote:
[quote]Gary,
Bruce
Posted: Mon Jul 18, 2011 9:26 pm Post subject: oil filter torque |
Why over-tighten? That only makes removal more difficult.
Gary
Posted: Tue Jul 19, 2011 5:32 am Post subject: oil filter torque |
Sounds like you are saying that 16 lb.-ft. is over tightening. I don't
have a problem removing filters that are torqued this way. The problems
I've had is when an owner installs a filter without a torque wrench and
tightens it much higher. You probably recall that the filter torque
used to be 18 lb.-ft. I assume that Champion thought that was to tight,
and I would agree, and so it was lowered.
Cliff
On 7/18/2011 10:25 PM, Gary L Vogt wrote:
Gary
Posted: Wed Jul 20, 2011 9:47 am Post subject: oil filter torque |
I understand completely. I'm not advocating that everyone follow my lead. I've just run into oil filters that were nearly impossible to remove. I'm sure 10 lbs-feet (160 lbs-inches) would be well more than enough.
Sent: Tue, July 19, 2011 6:29:36 AM
Subject: Re: oil filter torque
--> TeamGrumman-List message posted by: flyv35b <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)>
Cliff
[quote] --> TeamGrumman-List message posted by: Gary L Vogt<teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)>
Gary
On Jul 18, 2011, at 7:10 PM, flyv35b<flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)> wrote:
> --> TeamGrumman-List message posted by: flyv35b<flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)>
mel(at)becknet.com Guest
Posted: Wed Jul 20, 2011 10:23 am Post subject: oil filter torque |
The single best thing you can do to ease oil filter removal is to
apply Dow-Corning DC4 lubricant to the rubber seal, rather than engine
oil. You can buy a lifetime supply from A/C Spruce for a few bucks.
Engine oil eventually gets sticky when compressed, which increases
removal torque requirements. DC4's inert silica suspension is designed
to maintain lubrication properties for a much longer time, over a much
wider temperature range.
I've had no problems removing filters lubed with DC4, even when
torqued to 18 ft-lbs.
-mel
On Wed, 20 Jul 2011 10:45:13 -0700 (PDT)
Gary Vogt <teamgrumman(at)yahoo.com> wrote:
Quote: | I understand completely. I'm not advocating that everyone follow my
lead. I've
I'm sure 10
don't
problems
and
tight,
Cliff
>Vogt<teamgrumman(at)yahoo.com>
> Gary
> Sent from my iPad
>>>like.
>>>was
Posted: Wed Jul 20, 2011 12:18 pm Post subject: oil filter torque |
I have used DC-4 for years too and maybe that is why I have no trouble
removing them. A tube of it will last forever it seems.
Cliff
On 7/20/2011 11:20 AM, Mel Beckman wrote:
Quote: |
The single best thing you can do to ease oil filter removal is to apply
Dow-Corning DC4 lubricant to the rubber seal, rather than engine oil.
You can buy a lifetime supply from A/C Spruce for a few bucks. Engine
oil eventually gets sticky when compressed, which increases removal
torque requirements. DC4's inert silica suspension is designed to
I've had no problems removing filters lubed with DC4, even when torqued
to 18 ft-lbs.
-mel
> enough.
> ________________________________
> From: flyv35b <flyv35b(at)minetfiber.com>
> To: teamgrumman-list(at)matronics.com
> problems I've had is when an owner installs a filter without a torque
> wrench and tightens it much higher. You probably recall that the
> filter torque used to be 18 lb.-ft. I assume that Champion thought
> that was to tight, and I would agree, and so it was lowered.
> Cliff
>> Gary
>> Sent from my iPad
>>>> like.
Posted: Wed Jul 20, 2011 10:11 pm Post subject: oil filter torque |
Well, you're probably right. Maybe if I'd gotten into the habit of using DC4 50 years ago when I first started changing oil, I'd be using it today. I confess I find using engine oil and torquing to 75 inch-lbs easier
Sent: Wed, July 20, 2011 11:20:34 AM
--> TeamGrumman-List message posted by: "Mel Beckman" <mel(at)becknet.com (mel(at)becknet.com)>
The single best thing you can do to ease oil filter removal is to apply Dow-Corning DC4 lubricant to the rubber seal, rather than engine oil. You can buy a lifetime supply from A/C Spruce for a few bucks. Engine oil eventually gets sticky when compressed, which increases removal torque requirements. DC4's inert silica suspension is designed to maintain lubrication properties for a much longer time, over a much wider temperature range.
I've had no problems removing filters lubed with DC4, even when torqued to 18 ft-lbs.
-mel
Gary Vogt <teamgrumman(at)yahoo.com (teamgrumman(at)yahoo.com)> wrote:
[quote] I understand completely. I'm not advocating that everyone follow my lead. I've just run into oil filters that were nearly impossible to remove. I'm sure 10 lbs-feet (160 lbs-inches) would be well more than enough.
From: flyv35b <flyv35b(at)minetfiber.com (flyv35b(at)minetfiber.com)>
To: teamgrumman-list(at)matronics.com (teamgrumman-list(at)matronics.com)
Sounds like you are saying that 16 lb.-ft. is over tightening. I don't have a problem removing filters that are torqued this way. The problems I've had is when an owner installs a filter without a torque wrench and tightens it much higher. You probably recall that the filter torque used to be 18 lb.-ft. I assume that Champion thought that was to tight, and I would agree, and so it was lowered.
Cliff
> Gary
> Sent from my iPad
david(at)newlangsyne.com Guest
Posted: Thu Jul 21, 2011 2:30 am Post subject: oil filter torque |
# I understand completely. I'm not advocating that everyone follow
# my lead. I've just run into oil filters that were nearly
# impossible to remove. I'm sure 10 lbs-feet (160 lbs-inches)
# would be well more than enough.
You have long feet.
Posted: Thu Jul 21, 2011 8:18 am Post subject: oil filter torque |
{smile} About 2 hours after I wrote that, I started thinking about what I wrote. I meant 120 inches . . . . But, you get my drift.
To: Team Grumman <TeamGrumman-List(at)matronics.com>
Sent: Thu, July 21, 2011 3:23:26 AM
