rick(at)5mike3.com Guest
Posted: Mon Oct 10, 2011 1:10 pm Post subject: Elevator assembly |
Couple of questions for the experts:
I am attaching the elevator on my Kitfox IV.
At the end of the elevator push-rod there is a rodend that is attached
to the elevator with an AN23-15A (slotted head), this process was much
easier before the fuselage was covered.
Any downside to substituting with the equivalent size Hex bolt?
Also when attaching the elevator to the horizontal stabilizer 4 of the
6 clevis pins are not through enough for me to access the hole.
Any downside to getting a slightly longer clevis pin?
Thanks in advance.
Thanks Rick, KitFox IV 912.
90% done, 90% to go.
Guy Buchanan
Posted: Mon Oct 10, 2011 3:03 pm Post subject: Elevator assembly |
On 10/10/2011 2:07 PM, Rick wrote:
| Quote: | Any downside to substituting with the equivalent size Hex bolt?
On mine the hex head would poke through the fabric. It's a fun bolt to
tighten. I use a ground screwdriver inserted sideways in the slot.
No.
Guy Buchanan
Ramona, CA
Kitfox IV-1200 / 912-S / Warp 3cs / 500 hrs. and grounded
Now a glider pilot, too.
Deceased K-IV 1200
A glider pilot too. |
Tom Jones
Posted: Mon Oct 10, 2011 5:24 pm Post subject: Re: Elevator assembly |
Rick, like Guy points out, the reason for the AN23-15A Clevis Bolt is that a hex head bolt will wear a hole in the fabric. Use an offset screw driver to install it. I think I remember using the side of the tip of a straight screw driver too.
I had to use AN960-10L (light washers) and no washers on the heads of the pins to get enough clearance for the cotter pins. If that doesn't give enough clearance you may need to file off a little bit of the outside ends of the stab side of the hinges.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Lynn Matteson
Posted: Tue Oct 11, 2011 5:10 am Post subject: Elevator assembly |
I used a hex bolt, and it's been going strong for over 5 years. I
couldn't see using the suggested clevis bolt, as trying to hold the
screwdriver end while tightening a nyloc nut is not much fun.
Lynn Matteson
Jabiru 2200, #2062
Prince prop 64 x 30, P-tip
Rotec TBI-40 injection (sleeved to 36mm)
Status: flying with "Ramcharger" intake manifold...1187 hrs (since
3-27-2006)
On Oct 10, 2011, at 5:07 PM, Rick wrote:
attached to the elevator with an AN23-15A (slotted head), this
process was much easier before the fuselage was covered.
the 6 clevis pins are not through enough for me to access the hole.
Thanks in advance.
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Tue Oct 11, 2011 5:18 am Post subject: Elevator assembly |
With all this talk of wearing out the fabric, I was wracking my brain
to think why I don't have that problem....it's because I fattened out
that area when I installed ribs inside my vertical and rudder.
Lynn Matteson
Jabiru 2200, #2062
3-27-2006)
On Oct 10, 2011, at 9:24 PM, Tom Jones wrote:
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=354611#354611
N369LM |
Posted: Tue Oct 11, 2011 7:01 am Post subject: Elevator assembly |
Thanks to all for your input.
Looks like I will be pulling those clevis pins once again and they
don't remove easy.
--Rick
On Tue, 11 Oct 2011 09:15:38 -0400, Lynn Matteson wrote:
Lynn Matteson
Jabiru 2200, #2062
3-27-2006)
> Tom Jones
> Classic IV
> 503 Rotax, 72 inch Two blade Warp
> Ellensburg, WA
