pnicholson
Posted: Tue Apr 10, 2012 4:14 pm Post subject: Surging engine: CJ6A - HS6A |
In straight and level flight (6000ft, 1900RPM, temps near zero C)
I had sudden and 'dramatic' engine surging. The surge dropped from 1900RPM to 1500/1600 RPM and back up to 1900, then repeated. (Pretty scary)
I "richened" the mixture and the surging stopped, but I had to pull the mixture full aft to get rid of the surging. I was able to repeat this on the subsequent flight.
The only other obvious issue I am having is a (new) rhythmic puff of white smoke on the starboard side - not sure if it is related.
A previous issue was engine roughness on deceleration in the circuit which is still there but somewhat managed by RPM increases decreases as I pull back on the throttle.
Any thoughts on where to begin the search?
Phil
C-FEPN
(Ontario)
javiercarrascob
Posted: Tue Apr 10, 2012 4:40 pm Post subject: Surging engine: CJ6A - HS6A |
What are your Cyl. and Oil Temps when this happens?
--- On Tue, 4/10/12, pnicholson <pednicholson(at)gmail.com> wrote:
Quote: |
Subject: Surging engine: CJ6A - HS6A
To: yak-list(at)matronics.com
Date: Tuesday, April 10, 2012, 8:14 PM
--> Yak-List message posted by: "pnicholson" <[url=/mc/compose?to=pednicholson(at)gmail.com]pednicholson(at)gmail.com[/url]>
I had sudden and 'dramatic' engine surging. The surge dropped from 1900RPM to 1500/1600 RPM and back up to 1900, then repeated. (Pretty scary) [Shocked]
Phil
C-FEPN
(Ontario)
http://forums.matronics.com/viewtopic.php?p=370483#370483
http://www.matronics.com/Navigator?Yabsp; - MATRONICS WEB FORUMS - &nbstp://www.matronics.com/contribution" target="_blank">http://www.matronics===================
| [quote][b]
ldakos(at)bigpond.net.au Guest
Posted: Tue Apr 10, 2012 4:43 pm Post subject: Surging engine: CJ6A - HS6A |
G'Day Phil
I had a similar incident with my Cj when I landed I found a cracked intake
tube on one of the lower cylinder tubes where the oil drains screw in, it
had broken completely out, on inspection the other two had started to go the
same way, the engine had only done about 45 hrs at the time, I think the
extra weight of drain valves hanging and shaking on very thin metal is not a
real good idea.
Regards Lou
hess737(at)aol.com Guest
Posted: Tue Apr 10, 2012 4:50 pm Post subject: Surging engine: CJ6A - HS6A |
I had a similar roughness from a sticky exhaust at lower RPM. Ive seen short but dramatic roughness and loss of RPM at crz from a bad coil. Never had a mixture issue per se. Good luck.
Rich
Sent from my Motorola Smartphone on the Now Network from Sprint!
-----Original message-----
[quote]From: pnicholson <pednicholson(at)gmail.com>
Sent: Tue, Apr 10, 2012 20:16:48 EDT
Subject: Yak-List: Surging engine: CJ6A - HS6A
k7wx
Posted: Tue Apr 10, 2012 5:15 pm Post subject: Surging engine: CJ6A - HS6A |
Hello Phil,
May seem like a funny question, but is it a good idea to keep flying when the engine is acting up and it's unclear as to why? One of these times it may simply quit. It might be a better idea to limit flights to orbiting over the airport until this can be sorted out.
Warren Hill
N464TW
On Apr 10, 2012, at 5:38 PM, Javier Carrasco wrote:
[quote]What are your Cyl. and Oil Temps when this happens?
--- On Tue, 4/10/12, pnicholson <pednicholson(at)gmail.com (pednicholson(at)gmail.com)> wrote:
Quote: |
From: pnicholson <pednicholson(at)gmail.com (pednicholson(at)gmail.com)>
--> Yak-List message posted by: "pnicholson" <[url=x-msg://16/mc/compose?to=pednicholson(at)gmail.com]pednicholson(at)gmail.com[/url]>
Phil
C-FEPN
(Ontario)
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
| [b]
jackpot
Joined: 13 Jul 2010 Posts: 65 Location: Las Vegas, Nevada
Posted: Tue Apr 10, 2012 5:43 pm Post subject: Surging engine: CJ6A - HS6A |
Phil, I had a some surging happen as you described several years ago when I still had the Housi engine in my CJ, I found a plug on the very top of the back side of the Carburetor had not been safety wired and it had unscrewed, almost to the point of falling out, it is in the top of a pressure chamber that controls the fuel flow in the pressure carb.
The other surging problem I encountered was the seal around the wobble pump was bad and at a climb attitude, at altitude it was allowing air to be sucked in around the wobble pump shaft and the engine driven pump would loose suction because of the air in the fuel line, some surging and then no fuel pressure, engine quits,, but the first item to check is the plug on top of the Carb.. Good Luck... Gary
--- On Tue, 4/10/12, Warren Hill <k7wx(at)earthlink.net> wrote:
Quote: |
Subject: Re: Surging engine: CJ6A - HS6A
Date: Tuesday, April 10, 2012, 6:12 PM
Hello Phil,
Warren Hill
N464TW
Quote: | What are your Cyl. and Oil Temps when this happens?
--- On Tue, 4/10/12, pnicholson <[url=/mc/compose?to=pednicholson(at)gmail.com]pednicholson(at)gmail.com[/url]> wrote:
Quote: |
From: pnicholson <[url=/mc/compose?to=pednicholson(at)gmail.com]pednicholson(at)gmail.com[/url]>
To: [url=/mc/compose?to=yak-list(at)matronics.com]yak-list(at)matronics.com[/url]
--> Yak-List message posted by: "pnicholson" <pednicholson(at)gmail.com>
Phil
C-FEPN
(Ontario)
| http://www.matronics.com/Naviga_blank" href="http://forums.matronics.com">http://forums.matronics.com[/b] |
Posted: Tue Apr 10, 2012 6:51 pm Post subject: Surging engine: CJ6A - HS6A |
Phil,
All as stated, intake leaks, loose seals on the carb, cracked intake drain plug, cracked intake drain tubing connecting
The three lower cylinders, loose intake collars both ends ( supercharger and cylinder), primer pump seal, fuel pump seal between the oil pump and the fuel pump. And finally the diaphragm in the carb. Also how old are your fuel lines. A fragment off
The fuel line (flapper) can break off and partially to totally block the finger screen filter in carb.
This sounds like intake issues. I would stand her down until you sort this out.good luck.
Doc
Sent from my iPad
On Apr 10, 2012, at 8:40 PM, Gary Gabbard <ggg6(at)att.net (ggg6(at)att.net)> wrote:
[quote]Phil, I had a some surging happen as you described several years ago when I still had the Housi engine in my CJ, I found a plug on the very top of the back side of the Carburetor had not been safety wired and it had unscrewed, almost to the point of falling out, it is in the top of a pressure chamber that controls the fuel flow in the pressure carb.
--- On Tue, 4/10/12, Warren Hill <k7wx(at)earthlink.net (k7wx(at)earthlink.net)> wrote:
Quote: |
From: Warren Hill <k7wx(at)earthlink.net (k7wx(at)earthlink.net)>
Subject: Re: Yak-List: Surging engine: CJ6A - HS6A
Hello Phil,
Warren Hill
N464TW
Phil
C-FEPN
(Ontario)
cs.com
pnicholson
Pete Fowler
Posted: Wed Apr 11, 2012 10:18 am Post subject: Re: Surging engine: CJ6A - HS6A |
When the housai is too lean, it surges. High altitude lean surge is normal if it's over-leaned.
brian(at)lloyd.com Guest
Posted: Wed Apr 11, 2012 10:35 am Post subject: Surging engine: CJ6A - HS6A |
On Wed, Apr 11, 2012 at 11:18 AM, Pete Fowler <pfdesign1(at)cox.net (pfdesign1(at)cox.net)> wrote:
Quote: | --> Yak-List message posted by: "Pete Fowler" <pfdesign1(at)cox.net (pfdesign1(at)cox.net)>
I wasn't going to say anything but this has been my experience as well. I suspect it has to do with the carburetor mixture calibration changing at different air-flow rates. Recalibrating the carb on a flow bench would probably solve this problem and allow lean-of-peak operation.
But I am not 100% positive that I am right. As I said, it requires the use of a flow bench to check.
Brian Lloyd, WB6RQN/J79BPL
3191 Western Dr.
Cameron Park, CA 95682
brian(at)lloyd.com (brian(at)lloyd.com)
+1.767.617.1365 (Dominica)
+1.916.877.5067 (USA)
jetjockey
Joined: 12 Dec 2006 Posts: 31 Location: Granbury, Texas
Posted: Thu Apr 12, 2012 7:31 am Post subject: Re: Surging engine: CJ6A - HS6A |
I had this problem crop up intermittently several times over the last 10 or so years. I could never isolate the cause nor find any common condition that could have been causing the surging, other than it seemed to happen more often than not on warmer days or when I had the gills fully closed. I finally installed fire sleeve on my fuel lines and the problem has never recurred. My theory is that the fuel was vaporizing in the line from the filter to the fuel pump since turning on my electric boost pump always made the surging go away immediately. Fire sleeving the engine hoses isn't a bad idea regardless...
Ray
