jdriggs49(at)msn.com Guest
Posted: Tue Jun 03, 2014 5:19 am Post subject: Sudden Oiltemp dropout during climb out |
It really sounds like a wiring problem involving the sensor. The sensor itself can go out of tolerance or totally go bad but intermittent problems like this is usually always a wire problem. Loose connection or a semi broken wire.
[quote] Subject: Sudden Oiltemp dropout during climb out
Date: Tue, 3 Jun 2014 02:04:29 -0700
--> RV10-List message posted by: "Mike Whisky" <rv-10(at)wellenzohn.net>
Hello
I have seen now three times in the last 70h of flight that in long climb outs the oil temp dropped within a second from 185 down to 150-155 it stays there and recovers after leveling off most of the time back to normal within a second or so. I believe that this must be a sensor issue as the oil temp can't change that quickly. What is bothering me is that it only happens at the end of those climbs at around d 8k ft. Did anybody come across something similar?
Michael
RV-10 builder (flying)
#511
http://forums.matronics.com/viewtopic.php?p=424275#424275
http://forums.matronics.com//files/image_480.jpg
Posted: Tue Jun 03, 2014 6:20 am Post subject: Sudden Oiltemp dropout during climb out |
I had almost the exact same problem. Replaced the sensor, no help. Finally I put a dedicated ground from as close to the sensor as possible to the firewall. That fixed it. I have a very robust ground from the case to the engine mount, but the OT sensor needed the additional ground.
--Dave
On Tue, Jun 3, 2014 at 2:04 AM, Mike Whisky <rv-10(at)wellenzohn.net (rv-10(at)wellenzohn.net)> wrote:
[quote] --> RV10-List message posted by: "Mike Whisky" <rv-10(at)wellenzohn.net (rv-10(at)wellenzohn.net)>
Hello
Michael
#511
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
e -
-Matt Dralle, List Admin.
Mike Whisky
Posted: Tue Jun 03, 2014 7:00 am Post subject: Re: Sudden Oiltemp dropout during climb out |
Thank you for your replies I will follow your advice and check if it appears again.
Michael
_________________ RV-10 builder (flying)
#511 |
Gordon Anderson
Posted: Tue Jun 03, 2014 8:53 am Post subject: Sudden Oiltemp dropout during climb out |
Michael,
3 times in same flight conditions seems a little suspect to pinpoint it as a sensor / electrical issue, although I would certainly follow advice and add the ground to eliminate that possibility.
Having had problems with oil foaming in a previous career, I would wonder if there is a combination of rpm / aircraft attitude / ambient pressure in the climb phase which results in the sensor being in an air or foam pocket rather than having full oil contact, which is then resolved by transition to cruise. That could potentially falsify the sensor reading but might not be a cause for concern if there is no related change in oil pressure.
Cheers,
Gordon
41015, engine on, baffled
On Jun 3, 2014, at 4:19 PM, Dave Saylor wrote:
[quote] I had almost the exact same problem. Replaced the sensor, no help. Finally I put a dedicated ground from as close to the sensor as possible to the firewall. That fixed it. I have a very robust ground from the case to the engine mount, but the OT sensor needed the additional ground.
--Dave
Quote: | --> RV10-List message posted by: "Mike Whisky" <rv-10(at)wellenzohn.net (rv-10(at)wellenzohn.net)>
Hello
Michael
#511
MS -
e -
| [b]
Mike Whisky
Posted: Tue Jun 03, 2014 9:20 am Post subject: Re: Sudden Oiltemp dropout during climb out |
Hi Gordon,
thanks for sharing your thoughts I had a similar suspicion. I will now go through my flights and analyze them in Savvyanalysis.com to see if the phenomena occurred really always in a similar attitude, RPM or hight band.
But I have found already one exception so wiring/grounding is currently on top of my list.
Cheers
Michael
#511 |
Posted: Thu Jun 05, 2014 1:58 pm Post subject: Sudden Oiltemp dropout during climb out |
I've been waiting for this to come up...
I had a similar problem. That is, quick drops and rises of oil temperature. The high points looked like 'normal' temps. The low points were just below the recommended threshold, that is it would reads about 150F.
This has been going on for quite awhile. I swapped out sensors but the new sensor at first simply showed me the lower temps. For winter flying, I blocked some of the cooling air to bring the temp up but it seemed to have little impact. At some point, the temps again started vacillating between 'normal' and 'low' temps with no discernible pattern. The vacillations were instantaneous, as in '1 second'.
I never got around to trying to do some calibration testing of the sensor. Since everything else seemed right and normal, I just ran with it and removed the cooling air block.
I'm using a GRT engine monitor and sensor. I also have an SD-20 alternator installed on the vacuum pump pad (along with a 40amp main alt).
During my last oil change, I'm staring at the sensor and the wiring and realize that the generous service loop I have in place for the sensor could allow the wires to rest up against the SD-20 in flight. Could that have something to do with the problem? I can't make any sense of why such a thing would cause such a thing but...
I tightened up the service loop a bit so it now looks like this oil temp sensor and SD-20 with tighter service loop
I haven't seen anything but 'normal' oil temps since the change with no jumping around. Observation continues.
Does this sound possible in other installations? This curious builder wants to know.
On 6/3/2014 5:04 AM, Mike Whisky wrote:
[quote] Quote: | --> RV10-List message posted by: "Mike Whisky" <rv-10(at)wellenzohn.net> (rv-10(at)wellenzohn.net)
Hello
Michael
#511
| [b]
Albert Gardner
Posted: Thu Jun 05, 2014 4:00 pm Post subject: Sudden Oiltemp dropout during climb out |
[quote]I initially had the short occasional drops in oil temp but cured it by grounding the sensor case.Albert GardnerYuma, AZN991RV [b]
_________________ RV-9A N872RV
RV-10 N991RV |
