bakerocb
Posted: Fri Sep 11, 2015 8:05 am Post subject: IO-240 BxB Engine Mount Bushings |
9/11/2015
Hello Fellow Owners and Builders of KIS TR-1 Airplanes Powered by the IO-240 BxB Engine, I am going through another evolution of replacing the elastomeric bushings in this engine mount because of engine sag.
I am disgusted by the cost, and general non availability of the 638225 elastomeric bushing. This is the center tubular bushing: 1/2 inch inner diameter, 1 inch outer diameter.**
I am also unhappy with the fact that the elastomeric material in this bushing is too soft and allows almost immediate engine sag. I am considering trying to locate some rubber hose with a 1/2 inch inner diameter and 1 inch outer diameter and cutting it into short lengths and using that instead of the CM part #638225.
Your comments?
OC
**PS: Another particularly aggravating factor is the difficulty in installing new elastomeric bushings.
| - The Matronics KIS-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
sstearns2(at)yahoo.com Guest
Posted: Fri Sep 11, 2015 8:15 am Post subject: IO-240 BxB Engine Mount Bushings |
I think it is normal to get some sag soon after installation. I fitted my cowl so the spinner was 1/8 inch above the cowl knowing it was going to settle some. After flying for about 50 hours it settled to about 1/8 inch below the cowl. I put a large area washer under each of the lower engine mount points on the firewall and that aligned the spinner and cowl. That was 200 hours ago and no change.
Scott
To: KIS-LIST MATRONICS <kis-list(at)matronics.com>
Sent: Friday, September 11, 2015 9:05 AM
Subject: IO-240 BxB Engine Mount Bushings
9/11/2015
Your comments?
OC
Quote: |
ronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-List
matronics.com/">http://forums.matronics.com
ronics.com/contribution">http://www.matronics.com/contribution
wschertz343(at)gmail.com Guest
Posted: Fri Sep 11, 2015 8:57 am Post subject: IO-240 BxB Engine Mount Bushings |
Check McMaster Carr for different bushings. They may have something of use.
Sent: Friday, September 11, 2015 10:05 AM
To: KIS-LIST MATRONICS (kis-list(at)matronics.com)
9/11/2015
Your comments?
OC
href="http://www.matronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-List
aeromomentum(at)yahoo.com Guest
Posted: Fri Sep 11, 2015 9:30 am Post subject: IO-240 BxB Engine Mount Bushings |
Hello OC,
Have you tried looking at airboat suppliers? Many times they have non certified versions for a lot less money and at times harder versions. At least for the Lycoming style I use I can get ones that are very hard made from urethane.
Someone on ebay sells Continental bushing adapters that may be of use.
http://www.ebay.com/itm/Continental-O-200-to-C-85-Engine-Mount-Adapters-O200-/270845226093
The conical rubber bushings seem to about $22.22 for 8 on ebay:
www.ebay.com/itm/Continental-A65-A75-C75-C85-C90-O-200-engine-mounting-Bushing-P-N-SA22387-/111721088071
Mark
PS: Great Kitplane's article! Back when I was first learning to fly my instructor told me a trick so that Hobbs time could be used for flight time directly. He said to as you start let the aircraft move forward a foot so that the aircraft is no longer in the parking position and has moved under it's own power. I still do this today mainly as a brake test. Then at shut down do it so that it is not in the final parking position. This is not really an issue most of the time anyway since you normally need to push the plane back into it's parking spot. I think this now meets the FAR's for logging flight time but feel free to correct me if I am wrong.
To: "KIS-LIST MATRONICS" <kis-list(at)matronics.com>
Date: Friday, September 11, 2015, 12:05 PM
9/11/2015
Powered by the
replacing the
sag.
inch inner
material in this
I am considering
diameter and 1 inch
that instead of the
CM part #638225.
Your comments?
OC
difficulty in
bakerocb
Posted: Fri Sep 11, 2015 2:54 pm Post subject: IO-240 BxB Engine Mount Bushings |
9/11/2015
Hello Mark, Thanks for your input. You wrote:
1) "Have you tried looking at airboat suppliers?"
No, I haven't. I would be willing to look in that direction if you have any
links for me. I am not very optimistic though because the IO-240 BXB is a
relatively recent engine in the CM line and the engine mount bosses on the
IO-240 BXB engine crankcase are different than the engine mount bosses on
the CM O 200 engines and their ilk which have been around a long time.
(Because of the similar external appearance of the O 200 and the IO-240 BXB
engine crankcases I have had many people, including CM factory tech reps,
make erroneous assumptions regarding engine mounting parts for the IO-240
BXB engine.)
2) "Someone on ebay sells Continental bushing adapters that may be of use."
I found that site, including the Form 337 available on it, to be very
interesting. But only of specific value to an O 200 engine and not the
IO-240 BXB engine because of the different crankcase engine mount bosses on
those two engines.
3) "The conical rubber bushings seem to about $22.22 for 8 on ebay:"
That would be a big rip off. Those rubber bushings, CM part number 22387,
suitable for only the O 200 engine and not the IO-240 BXB engine are
available from Aircraft Spruce for $3.55 each. See here:
http://www.aircraftspruce.com/catalog/eppages/enginemountbushings.php?clickkey=3789
But Spruce also has an O 200 conical rubber bushing with part number
07-03493, which I think is identical to part number 22387 for $17.50. See
reference number 4 here:**
http://www.aircraftspruce.com/catalog/eppages/contmountparts.php?recfer=14540
The comparable conical rubber bushing part made by Lord with for the IO-240
BXB is $17.50 each from Spruce. See here:
http://www.aircraftspruce.com/catalog/eppages/lordenginemountscessna_07-01131.php?clickkey=41076
The CM version of this bushing is numbered 530740 and is available from
Aircraft Specialties for $28.15. See here:
http://www.aircraft-specialties.com/bushing-engine-mount-530740/
And apparently from Spruce for $37.55. See here:
http://www.aircraftspruce.com/catalog/eppages/continentalnewbushing_07-03553.php?clickkey=7487
But enough about the conical rubber bushings -- my heart burn is with the
tubular bushing, part number 638225, which does not properly support the
heavier IO-240 engine, which costs around $70.00 each, and you have to scour
the country side to even find 4 available from any one dealer. See here:
http://www.aircraftspruce.com/catalog/eppages/continentalnewbushing_07-04286.php?clickkey=167508
OC
**PS: Note that the tubular bushing for the O 200 ( Part number 628555-16,
reference number 1 in this diagram) is just exactly what it says -- a chunk
of hose. I wonder how much engineering went into that design.
Sent: Friday, September 11, 2015 1:30 PM
To: kis-list(at)matronics.com
Subject: Re: IO-240 BxB Engine Mount Bushings
Hello OC,
from urethane.
Mark
9/11/2015
Powered by the
replacing the
sag.
inch inner
material in this
I am considering
diameter and 1 inch
that instead of the
CM part #638225.
Your comments?
OC
difficulty in
bakerocb
Posted: Sat Sep 12, 2015 4:53 am Post subject: IO-240 BxB Engine Mount Bushings |
9/12/2015
Hello Bill, Great suggestion – many thanks. I did not find any suitable bushings at M C, but did find and order several different lengths of hose that I may be able to cut and turn into suitable 638225 replacements.
OC
Sent: Friday, September 11, 2015 12:56 PM
9/11/2015
Your comments?
OC
bakerocb
Posted: Sat Sep 12, 2015 7:11 am Post subject: IO-240 BxB Engine Mount Bushings |
9/12/2015
Hello Mark, You wrote:
1) "The conical rubber bushings on ebay are actually $1.25 each. But with
shipping the total is $22.22 for 8."
Right you are, and that is a good price for those who can use the 22387
bushing.
2) "If the O-200 adapters do not work could something similar be made for
the IO-240 BXB?"
Maybe, but the real issue is not the configuration, cost (approximately
$17.50), and availability of the CM part number 530740 (or its Lord J3608-1
substitute) end bushing, but the cost (approximately $70) , Durometer
hardness (too soft), and non availability of the CM part number 638225
center tubular bushing.
3) " If you can draw them up I can get a quote for making them but your best
bet may be to use the factory ones if you can get them."
Yes, I intend to continue using the CM part number 530740 (or its Lord
J3608-1 substitute) end bushing and keep searching for a better solution for
the CM part number 638225 center tubular bushing.
OC
Sent: Friday, September 11, 2015 7:30 PM
To: Owen Baker
Hello OC,
If the O-200 adapters do not work could something similar be made for the
IO-240 BXB? If you can draw them up I can get a quote for making them but
your best bet may be to use the factory ones if you can get them.
Mark
Keith.Miller(at)esa.int Guest
Posted: Mon Sep 14, 2015 1:52 am Post subject: IO-240 BxB Engine Mount Bushings |
OC,
I need to replace mine soon ( 638225 & 530740 ) . Like you I am happy to
pay for the 530740, but the 638225 is a rip-off - i priced it up at the
beginning of this year and found them for 49$ from aircraft specialties
supplies .
So if you come up with a solution i would be very happy to hear it . Also
if you can get some made i would also be happy to share the costs.
Keith
To: "M Ketteing" <aeromomentum(at)yahoo.com>, "KIS-LIST MATRONICS"
<kis-list(at)matronics.com>,
Date: 09/12/2015 05:12 PM
Sent by: owner-kis-list-server(at)matronics.com
9/12/2015
bushing.
the IO-240 BXB?"
OC
To: Owen Baker
Hello OC,
Mark
This message and any attachments are intended for the use of the addressee or addressees only.
The unauthorised disclosure, use, dissemination or copying (either in whole or in part) of its
content is not permitted.
If you received this message in error, please notify the sender and delete it from your system.
Emails can be altered and their integrity cannot be guaranteed by the sender.
Please consider the environment before printing this email.
bakerocb
Posted: Mon Sep 14, 2015 7:04 pm Post subject: IO-240 BxB Engine Mount Bushings |
9/14/2015
Hello Keith, You wrote:
1) "... i priced it up at the beginning of this year and found them for 49$
supplies ."
I ordered four 638225's from
on line a day or so ago at $48.45 USD only to receive a phone call saying
that it would be several weeks before delivery so I cancelled the order. I
am paying about $70 USD each for the ones that I was able to find on an
extended search.
2) "Also if you can get some made i would also be happy to share the
costs."
I don't know how to start that process. I don't know who CM's supplier is.
And the Durometer rating (hardness) of the 638225's that come from CM is too
soft in my opinion.
Also US regulations forbid making parts for US type certificated airplanes
without FAA approval and there are type certificated airplanes (Diamond DA
20-C1 for one) http://www.diamondaircraft.com/aircraft/da20/technical.php
that use the IO-240 B3B engine so if I were able to find someone to make the
638225's the maker would have to specify them as being offered only for non
type certificated airplanes. Probably not worth the financial return for any
potential maker.
3) "So if you come up with a solution i would be very happy to hear it"
OK. Right now I am waiting for delivery of several pieces of elastomeric
hose from McMaster Carr that I may into cut into short pieces and use as
substitutes for 638225's. There is precedence for this as the similar part
for mounting the O 200 engine, part number 628555-16, is just a piece of
hose. See here:
http://www.aircraftspruce.com/catalog/eppages/contmountparts.php?clickkey=26078
OC
Sent: Monday, September 14, 2015 5:52 AM
OC,
supplies .
Also
Keith
hans.erstad(at)gmail.com Guest
Posted: Tue Sep 15, 2015 2:17 am Post subject: IO-240 BxB Engine Mount Bushings |
As far as I can remember (but it is more than 15 years ago), the engine mount parts that came with the engine (IO-240-A) contained some pieces of rubber hose to slide onto the spacer and between the rubber bushings (and washers). Looking like the aircraft spruce O-200 picture on your last link.
I see no reason for having anything else than some rubber hose there.
I am still on these original parts.
Hans Christian
2015-09-15 5:03 GMT+02:00 Owen Baker <bakerocb(at)cox.net (bakerocb(at)cox.net)>:
[quote]--> KIS-List message posted by: "Owen Baker " <bakerocb(at)cox.net (bakerocb(at)cox.net)>
9/14/2015
1) "... i priced it up at the beginning of this year and found them for 49$ from aircraft specialties
supplies ."
on line a day or so ago at $48.45 USD only to receive a phone call saying that it would be several weeks before delivery so I cancelled the order. I am paying about $70 USD each for the ones that I was able to find on an extended search.
2) "Also if you can get some made i would also be happy to share the costs."
I don't know how to start that process. I don't know who CM's supplier is. And the Durometer rating (hardness) of the 638225's that come from CM is too soft in my opinion.
Also US regulations forbid making parts for US type certificated airplanes without FAA approval and there are type certificated airplanes (Diamond DA 20-C1Â for one) http://www.diamondaircraft.com/aircraft/da20/technical.php
that use the IO-240 B3B engine so if I were able to find someone to make the 638225's the maker would have to specify them as being offered only for non type certificated airplanes. Probably not worth the financial return for any potential maker.
OK. Right now I am waiting for delivery of several pieces of elastomeric hose from McMaster Carr that I may into cut into short pieces and use as substitutes for 638225's. There is precedence for this as the similar part for mounting the O 200 engine, part number 628555-16, is just a piece of hose. See here:
OC
From: Keith.Miller(at)esa.int (Keith.Miller(at)esa.int)
--> KIS-List message posted by: Keith.Miller(at)esa.int (Keith.Miller(at)esa.int)
OC,
supplies .
Keith
List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?KIS-List
_blank" rel="noreferrer">http://forums.matronics.com
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
bakerocb
Posted: Tue Sep 15, 2015 7:57 am Post subject: IO-240 BxB Engine Mount Bushings |
Sent: Tuesday, September 15, 2015 11:32 AM
To: KIS-LIST MATRONICS ; MILLER KEITH ; ERSTAD HANS CHRISTIAN ; WRIGHT JESSE
; SCHERTZ BILL
Subject: Fw: IO-240 BxB Engine Mount Bushings
9/15/2015
Hello Keith, Thank you for the response and pictures. You wrote:
1) "The 530740's look in really good condition so i am not so worried
about those but my 638225's are not
looking so good."
That has also been my experience, but some of my 638225's are completely
shredded / destroyed in the removal process. My plan is to install the
638225's (if I do reinstall any) with a coating of Dow DC-4.
http://www.aircraftspruce.com/catalog/cspages/dc4.php
I think that both the 530740's and 638225's tend to regain their shape after
removal if they wait around for a few days. There is also the issue of both
of those elastomers becoming hardened with the passage of time and losing
their vibration absorption ability even when sitting on the shelf. But since
the 638225's start out being too soft in the first place I don't see that as
a problem.
2) "... i intend to replace them this year ...." and ".... where did you
eventually get the 638225's from ?"
I have ordered three 638225's from Aircraft Spruce (were not in stock --
coming from some un identified location) at $69.70 USD each and the last two
that Skygeek had in stock for $60.28 USD each. See here for their present
out of stock status:
http://www.skygeek.com/continental-motors-638225-bushing.html
No 638225's have arrived yet. BUT the eight 6 inch pieces of hose that I
ordered from McMaster Carr have arrived today and I am very pleased (Thank
you Bill Schertz). I received two pieces each of:
8637K131 75A Durometer; 86805K53 75A Durometer; 5546T53 60A Durometer; and
87235K11 40A Durometer.
http://www.mcmaster.com/
My intent is to see if I can cut pieces of the first three into suitable
lengths (approximately 1 and 1/2 inches) and bore them out to 1/2 inch inner
diameter (to fit over the center metal spacer) to use as replacements for
the 638225's. (I think the two 40A Durometer pieces are too soft.)
3) "... and have you also decided to replace the 530740's as well ?"
Yes, I have ordered and received eight 5830740's from Aircraft Spruce, along
with a 1/4 inch thick piece of aluminum bar stock that I plan to make shims
from to shim forward the bottom crankcase mounting legs (if needed) in order
to move the spinner upward. I already have in hand several shims of thinner
thickness that I have created through the years.
OC
Sent: Tuesday, September 15, 2015 4:14 AM
To: Owen Baker
OC,
I attach a couple of pictures of my mounts . The 530740's look in
really
good condition so i am not so worried about those but my 638225's are not
looking so good . as a temp measure I swapped the mounts around ( top
mounts went bottom ) and the engine was looking a bit higher up . i intend
to replace them this year and had assumed Aircraft specialities had them in
stock , so its good that you told me they do not
(See attached file: IMG_4181.JPG)(See attached file: IMG_4203.JPG)
where did you eventually get the 638225's from ? and have you also
Keith
