RPM indicator problem
raf
PostPosted: Mon Nov 14, 2016 2:41 pm    Post subject: RPM indicator problem Reply with quote
Hello,
during the last flight on YAK52, the RPM indicator (front and rear seats) went to 0, Oil pressure and Temp were ok. Once on the ground the indicator went back to normal ops. I suspect a connection problem.
My question is: where the RPM indicator take the input from? what is the location on the engine?
Thank you for your time !!
Raf
Viperdoc
PostPosted: Mon Nov 14, 2016 7:56 pm    Post subject: RPM indicator problem Reply with quote
One of the three wires to your TAC driver has bid rated loose in the sim pin attachment to the TAC drive on the left side of your accessory case. At least that is where it is on the M14P.
Doc
Sent from my iPad
On Nov 14, 2016, at 4:41 PM, raf <arlaviation(at)gmail.com> wrote:
Hello,
during the last flight, the RPM indicator (front and rear seats) went to 0, Oil pressure and Temp were ok. Once on the ground the indicator went back to normal ops. I suspect a connection problem.
Raf
http://forums.matronics.com/viewtopic.php?p=462538#462538
Viperdoc
Clouddog
PostPosted: Tue Nov 15, 2016 6:22 am    Post subject: RPM indicator problem Reply with quote
I had the same problem on my CJ. Tach Generator left side of engine. Loose connector. Took connection off, sprayed connector and pins with electronic cleaner and indicators working fine.5 minute fix.
On Nov 14, 2016 4:45 PM, "raf" <arlaviation(at)gmail.com (arlaviation(at)gmail.com)> wrote:
--> Yak-List message posted by: "raf" <arlaviation(at)gmail.com (arlaviation(at)gmail.com)>
Hello,
Raf
br> fts!)
r> > com" rel="noreferrer" target="_blank">www.aeroelectric.com
w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
p.com" rel="noreferrer" target="_blank">www.homebuilthelp.com
e.com" rel="noreferrer" target="_blank">www.mypilotstore.com
" rel="noreferrer" target="_blank">www.mrrace.com
          -Matt Dralle, List Admin.
List" rel="noreferrer" target="_blank">http://www.matronics.com/Navigator?Yak-List
FORUMS -
WIKI -
b Site -
dsavarese0812(at)bellsout
PostPosted: Tue Nov 15, 2016 6:31 am    Post subject: RPM indicator problem Reply with quote
That most likely will not be the case with the Yak 52. The 52's tach
generator Cannon plug is notorious for one of the 3 wires in the neck of
the cannon plug breaking at the solder joint of the pin.
Dennis
A. Dennis Savarese
334-546-8182 (mobile)
www.yak-52.com
Skype - Yakguy1
Hello,
Raf
<http://forums.matronics.com/viewtopic.php?p=462538#462538>
br> fts!)
FORUMS -
WIKI -
b Site -
nigel.willson(at)yakdispl
PostPosted: Tue Nov 15, 2016 6:48 am    Post subject: RPM indicator problem Reply with quote
Dennis is correct. Have had this several times on my Yak52. The wires are difficult to solder by the way!!!!
Nigel Willson
Flying Instructor & Examiner | Airshow Organiser | Display Pilot
Sent from my Samsung Galaxy S7 - powered by Three
From: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net>
Date: 15/11/2016 14:31 (GMT+00:00)
To: yak-list(at)matronics.com
Subject: Re: Yak-List: RPM indicator problem
--> Yak-List message posted by: "A. Dennis Savarese" <dsavarese0812(at)bellsouth.net>
Dennis
A. Dennis Savarese
www.yak-52.com
Skype - Yakguy1
     Hello,
     Raf
     br> fts!)
     FORUMS -
     WIKI -
     b Site -
_-============================================================
_-=
_-=       -- Please Support Your Lists This Month --
_-=           (And Get Some AWESOME FREE Gifts!)
_-=
_-=   November is the Annual List Fund Raiser.  Click on
_-=   the Contribution link below to find out more about
_-=   this year's Terrific Free Incentive Gifts provided
_-=   by:
_-=
_-=     * AeroElectric www.aeroelectric.com
_-=     * The Builder's Bookstore www.buildersbooks.com
_-=     * HomebuiltHELP www.homebuilthelp.com
_-=     * My Pilot Store www.mypilotstore.com
_-=     * Race Consulting www.mrrace.com
_-=
_-=   List Contribution Web Site:
_-=
_-=   --> http://www.matronics.com/contribution
_-=
_-=   Thank you for your generous support!
_-=
_-=                              -Matt Dralle, List Admin.
_-=
_-=          - The Yak-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-=   --> http://www.matronics.com/Navigator?Yak-List
_-=
_-=               - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-=   --> http://forums.matronics.com
_-=
_-=              - NEW MATRONICS LIST WIKI -
_-= Add some info to the Matronics Email List Wiki!
_-=   --> http://wiki.matronics.com
_-=             - List Contribution Web Site -
