carlp101
Posted: Fri Feb 10, 2017 1:18 am Post subject: Replacing nose wheel suspension bungee with springs |
Hi,
My Europa is currently fitted with bungee cord on the nose wheel suspension, but I also have the springs from Europa to replace it. Has anyone fitted the springs? Do they do a good job?
I'm concerned that the springs concentrate the forces at two points on the nose wheel frame rather than spreading it out as the bungee does. I'm wondering if it's probably better to stick with what I already have fitted.
Any experience / advise greatly appreciated.
All the best.
Carl
dpark748(at)icloud.com Guest
Posted: Fri Feb 10, 2017 2:44 am Post subject: Replacing nose wheel suspension bungee with springs |
Carl,
Converted my mono to trike two years ago and fitted springs with help of Neville.
Unlikely to fail and more or less a permanent fit!
Handling no problems.
Dave G-LDVO
Dave Park
| Quote: | On 10 Feb 2017, at 09:18, carlp101 <cparkinson(at)cisc-uk.com> wrote:
Hi,
All the best.
Carl
http://forums.matronics.com/viewtopic.php?p=465959#465959
cakeykev(at)gmail.com Guest
Posted: Fri Feb 10, 2017 3:47 am Post subject: Replacing nose wheel suspension bungee with springs |
I changed from bungee to springs years ago. I have had no problems at all.
Kevin Challis
G ODJG
Hi,
All the best.
Carl
danny shepherd
Joined: 27 Jan 2006 Posts: 117 Location: north Wales, United Kingdom
Posted: Fri Feb 10, 2017 4:07 am Post subject: Replacing nose wheel suspension bungee with springs |
Hi Carl,
I fitted the springs I think it was 2009. I've had no
problems what so ever. the only thing I do every annual is make sure
there's plenty of grease around the top and bottom where they hook on to
the frame. fitting was a little tricky, had to expand the springs using
a jack and put bolts in the spring to keep expanded while fitting.
managed to do it on my own, so you shouldn't have any problem. hope this
helps.
Danny. G-C.E.R.I
On 10/02/2017 09:18, carlp101 wrote:
Hi,
All the best.
Carl
Posted: Fri Feb 10, 2017 5:03 am Post subject: Replacing nose wheel suspension bungee with springs |
CarlI bought springs....but they dont fit the old style nose gear which i have. The issue is in the manual. Just so youre aware
Will
On Feb 10, 2017 05:24, "carlp101" <cparkinson(at)cisc-uk.com (cparkinson(at)cisc-uk.com)> wrote: | Quote: | --> Europa-List message posted by: "carlp101" <cparkinson(at)cisc-uk.com (cparkinson(at)cisc-uk.com)>
Hi,
All the best.
Carl
carlp101
Posted: Fri Feb 10, 2017 9:34 am Post subject: Re: Replacing nose wheel suspension bungee with springs |
Good to know they are OK.
Thanks all.
Carl
rlborger(at)mac.com Guest
Posted: Fri Feb 10, 2017 10:42 am Post subject: Replacing nose wheel suspension bungee with springs |
Carl,
Since you have the springs, I’d suggest you go ahead at the next opportunity (such as an annual) and replace the bungees with the springs. I have the springs on my tri-gear and the are working great. I helped Bud do my tri-gear conversion and he slipped a sheet of stainless steel between the spring and frame to help prevent the wear you describe. There’s lots of up-side to the switch and I can’t think of any down-side at all.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).
Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
On Feb 10, 2017, at 3:18 AM, carlp101 <cparkinson(at)cisc-uk.com> wrote:
Hi,
All the best.
Carl
