Monowheel brake cylinder seals
n7188u
PostPosted: Mon Apr 24, 2017 6:54 am    Post subject: Monowheel brake cylinder seals Reply with quote
Dear Europa List members,
Continuing the inspection of kit A291 I have found that the brake master cylinder was seized.
I disassembled it and found that the cup seal has deteriorated and the master cylinder is full of black sticky crud.
I can clean the components but the seals will require replacement. Are these still available? The master cylinder is labeled "Kart Components".
Thanks for the help,
Chris
mike.davies210(at)gmail.c
PostPosted: Mon Apr 24, 2017 7:11 am    Post subject: Monowheel brake cylinder seals Reply with quote
Hi ChrisJust checked online they are still available at www.kartstore.co.uk/shop.cfm?cat=1475&node=28
Hope this helps
Regards Mike G-MLXP
On 24 Apr 2017 3:57 p.m., "n7188u" <chmgarb(at)gmail.com (chmgarb(at)gmail.com)> wrote:
--> Europa-List message posted by: "n7188u" <chmgarb(at)gmail.com (chmgarb(at)gmail.com)>
Chris
http://forums.matronics.com/viewtopic.php?p=468733#468733
n7188u
PostPosted: Mon Apr 24, 2017 1:38 pm    Post subject: Re: Monowheel brake cylinder seals Reply with quote
Thanks Mike. I presume the seal kit KC25 would work?
Chris
