Engine monitoring system
richard.goode(at)russiana
PostPosted: Mon Sep 27, 2021 6:48 am    Post subject: Engine monitoring system Reply with quote
As people probably know, we test all our engines that we overhaul on a sophisticated dynamometer at Aerometal in Hungary. However we would like to update the current engine monitoring system, since we would like to have a constant readout and recording ability for all engine parameters such as CHT; EGT; oil temperature in and out; fuel flow; oil pressure; rpm et cetera.
I would welcome anyone's advice as to the best system to install – thank you
Richard
RICHARD GOODE AEROBATICS
Rhodds Farm, Lyonshall, Hereford, HR5 3LW, UK
Tel:  +44 (0)1544 340120 Fax: +44 (0)1544 340129
e-mail: richard.goode(at)russianaeros.com (richard.goode(at)russianaeros.com)
www.russianaeros.com
WORLD LEADERS IN RUSSIAN SPORTING AIRCRAFT & ENGINES
In partnership with Aerometal Kft, Hungary.
dsavarese0812(at)bellsout
PostPosted: Mon Sep 27, 2021 10:22 am    Post subject: Engine monitoring system Reply with quote
JPI 730 9C or 930Dennis
On Sep 27, 2021, at 10:50 AM, Richard Goode <richard.goode(at)russianaeros.com> wrote:
 <![endif]--> Clean false false false EN-GB X-NONE X-NONE {A2C985E1-F2D7-46F8-A064-2F38E0BA163A} 1344982854608 <![endif]--> <![endif]-->/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri",sans-serif; mso-ascii-font-family:Calibri; mso-hansi-font-family:Calibri; mso-bidi-font-family:"Times New Roman"; mso-fareast-language:EN-US;} <![endif]--> <![endif]--> <![endif]-->
Richard
easy_driver
PostPosted: Mon Sep 27, 2021 10:24 am    Post subject: Re: Engine monitoring system Reply with quote
i betcha you'd get a dozen replies pointing to JPI...
i know a guy - 10-something years ago he wrote a complete EFIS and engine monitor for his sukhoi. there was nothing on the market. the only EFIS was 10" BMA EFIS One. he had nothing on his panel, just a 12" superbright display with all the data you can think of. his code and display plus commercial electronics mounted on the engine.
i'd say: since he wrote it - it's infinitely customizable, can run on a big screen , display anything you'd like and log it or instantly send it elsewhere. probably for a fraction of JPI
Stratyaks
PostPosted: Tue Sep 28, 2021 3:53 am    Post subject: Re: Engine monitoring system Reply with quote
I would be interested to know if this is a possiblity - I have an interesting application that would not be served by anything commercially available
