MJKTuck(at)cs.com Guest
Posted: Mon Feb 13, 2023 6:27 pm Post subject: No charge lamp stays on |
Hi Folks,
Started my 912UL today (first time for 2-3 months) and it started first
time! However, I noticed that the 12V 'no-charge' lamp (connected to the
rectifier pins L and C) remained illuminated indicating no charge.
I ran the engine a while to get it up to temp but the lamp stayed on and
after shut down my battery voltage had dropped below 11.5V. so it is
definitely is not being charged.
I'm sure it could be a number of things from a dodgy rectifier to issues
with the alternator.
Any pointers as to what to look first at would be appreciated.
Martin Tuck
Europa N152MT
Gilles
Posted: Tue Feb 14, 2023 3:05 am Post subject: No charge lamp stays on |
Le 14/02/2023 à 03:26, Martin Tuck a écrit :
Quote: | --> Europa-List message posted by: Martin Tuck <MJKTuck(at)cs.com> (MJKTuck(at)cs.com)
Hi Folks,
Started my 912UL today (first time for 2-3 months) and it started first time! However, I noticed that the 12V 'no-charge' lamp (connected to the rectifier pins L and C) remained illuminated indicating no charge.
I ran the engine a while to get it up to temp but the lamp stayed on and after shut down my battery voltage had dropped below 11.5V. so it is definitely is not being charged.
I'm sure it could be a number of things from a dodgy rectifier to issues with the alternator.
Any pointers as to what to look first at would be appreciated. |
Hi Martin,
I'd first check actual voltages with a reliable voltmeter, then perform a serious check of the wiring and connections.
Did your alternator charge before? Did you disconnect/connect anything since last time you ran the engine with no issues?
Best regards
Gilles
http://contrails.free.fr
http://lapierre.skunkworks.free.fr
_________________ Best regards,
Gilles
http://contrails.free.fr |
mjktuck(at)cs.com Guest
Posted: Tue Feb 14, 2023 8:28 am Post subject: No charge lamp stays on |
Thanks Giles,
I haven’t done anything to the aircraft since the last time I flew and all seemed well then. I found a good video on troubleshooting the system on the Rotax Owners site so I’ll be looking to perform those checks and see what might be going on.
Martin
Quote: | On Feb 14, 2023, at 5:07 AM, GTH <gilles.thesee(at)free.fr> wrote:
Le 14/02/2023 ?? 03:26, Martin Tuck a ??crit??:
Hi Folks,
Hi Martin,
Best regards
Gilles
Paul M 383
Joined: 19 Mar 2012 Posts: 102 Location: United Kingdom
Posted: Tue Feb 14, 2023 9:45 am Post subject: No charge lamp stays on |
Which video Martin (link or vid ref number)?
I thought I'd watched them all, but don't recall one on Reg/Rec or charging troubleshooting...!
Cheers,
Paul M
G-PLPM
Date: 14/02/2023 16:30 (GMT+00:00)
Subject: Re: Europa-List: No charge lamp stays on
Thanks Giles,
Martin
Hi Folks,
<Charge lamp issue> |
Hi Martin,
Best regards
Gilles
Posted: Tue Feb 14, 2023 11:37 am Post subject: No charge lamp stays on |
I had the same issue - Bob Nickolls said that the charge light system in the Ducati regulator is very primitive and not to pay attention. A reliable voltmeter is required.
Eventually my charge light went out by itself. The battery charged just fine while it was on.
William Daniell
LONGPORT
+1 786 878 0246
On Tue, Feb 14, 2023 at 12:46 PM Paul Mansfield <europaul383(at)hotmail.com (europaul383(at)hotmail.com)> wrote:
Cheers,
Paul M
G-PLPM
From: Martin Tuck <mjktuck(at)cs.com (mjktuck(at)cs.com)>
To: europa-list(at)matronics.com (europa-list(at)matronics.com)
Subject: Re: No charge lamp stays on
Thanks Giles,
Martin
Quote: | On Feb 14, 2023, at 5:07 AM, GTH <gilles.thesee(at)free.fr (gilles.thesee(at)free.fr)> wrote:
Hi Folks,
Hi Martin,
Best regards
Gilles
Gilles
Posted: Tue Feb 14, 2023 11:48 am Post subject: No charge lamp stays on |
Le 14/02/2023 à 20:36, William Daniell a écrit :
Quote: | I had the same issue - Bob Nickolls said that the charge light system in the Ducati regulator is very primitive and not to pay attention. A reliable voltmeter is required.
William and all,
Agreed.
First measure actual voltages.
Yes Bob Nuckolls on http://www.aeroelectric.com/ and on the 'List is key.
Best regards
Gilles
Gilles
DuaneFamly
Posted: Tue Feb 14, 2023 12:40 pm Post subject: No charge lamp stays on |
I would imagine you can tell if it’s operating properly if your panel voltage reading prior to start is about 12.5volts and with engine running (charging system working properly) you should see about 14.8volts.
Mike Duane N377EA
Europa XS Conventional Gear
Quote: | On Feb 14, 2023, at 12:48 PM, GTH <gilles.thesee(at)free.fr> wrote:
Le 14/02/2023 ?? 20:36, William Daniell a ??crit??:
Quote: | I had the same issue - Bob Nickolls said that the charge light system in the??Ducati regulator??is very??primitive and not to pay attention.?? ??A reliable voltmeter is required.??
Eventually??my charge light went out by itself.?? The??battery charged just fine while it was on.
William and all,
Agreed.
Best regards
Gilles
_________________ Mike Duane |
Posted: Tue Feb 14, 2023 6:58 pm Post subject: No charge lamp stays on |
Hi Paul,
Assuming you are a subscriber to RotaxOwner.com, the video can be found under Videos: 912 Videos: Charging System Troubleshooting.
https://www.rotax-owner.com/en/videos-topmenu/rotax-minute/404-charging
Martin Tuck
Cheers,
Paul M
G-PLPM
From: Martin Tuck <mjktuck(at)cs.com> (mjktuck(at)cs.com)
Thanks Giles,
Martin
Quote: | On Feb 14, 2023, at 5:07 AM, GTH <gilles.thesee(at)free.fr> (gilles.thesee(at)free.fr) wrote:
Hi Folks,
Hi Martin,
Best regards
Gilles
Paul M 383
Posted: Wed Feb 15, 2023 12:40 am Post subject: No charge lamp stays on |
I am a subscriber, thanks Martin... hadn't seen this one, so a useful addition to the library, thanks!
P
Date: 15/02/2023 03:01 (GMT+00:00)
Hi Paul, Assuming you are a subscriber to RotaxOwner.com, the video can be found under Videos: 912 Videos: Charging System Troubleshooting. https://www.rotax-owner.com/en/videos-topmenu/rotax-minute/404-charging Regards, Martin Tuck On 2/14/2023 11:44 AM, Paul Mansfield wrote:
<snip>
