erichdtrombley(at)juno.co Guest
Posted: Mon Aug 28, 2023 7:40 pm Post subject: Cabin fresh air exhaust |
Will, clever idea with the fuel outlet covers. Any idea how effective they are? Also, the second photo is the underside of a Europa, however, I am uncertain wha it is we should be looking at.
Erich Trombley
N28ET
Classic Mono 914
Posted: Tue Aug 29, 2023 3:56 am Post subject: Cabin fresh air exhaust |
Erich thanks.
No scientific evidence. My guess was that some engine air would get sucked up into the nosegear hole and past the bulkhead. I wanted to vent this as opposed to it getting sucked into the cabin.
Also i wanted to ventilate any posible gas seepage.
I get a good breeze in through the naca vents on the cabin sides about knee level.
I have a co detector in the cabin which has never alarmed.
The cabin exhausts i think through the throttle slot and doors.
Will
William Daniell
+1 786 878 0246
On Mon, Aug 28, 2023, 23:42 Erich Trombley <erichdtrombley(at)juno.com (erichdtrombley(at)juno.com)> wrote:
Quote: | --> Europa-List message posted by: Erich Trombley <erichdtrombley(at)juno.com (erichdtrombley(at)juno.com)>
Erich Trombley
N28ET
Classic Mono 914
pa-List" rel="noreferrer noreferrer" target="_blank">http://www.matronics.com/Navigator?Europa-List
FORUMS -
eferrer noreferrer" target="_blank">http://forums.matronics.com
WIKI -
errer noreferrer" target="_blank">http://wiki.matronics.com
b Site -
-Matt Dralle, List Admin.
="noreferrer noreferrer" target="_blank">https://matronics.com/contribution
h&jeuropa
Posted: Wed Aug 30, 2023 10:27 am Post subject: Re: Cabin fresh air exhaust |
While looking for something else on my computer today, I found this post concerning Cabin Air. I think G-IANI is still flying in the UK but I have no idea how to contact the owner and find out if this mod is still in place. Maybe someone in the UK can help?
Jim Butcher
Description: |
Download |
Filename: |
Cabin_Air_Extractor.pdf |
Filesize: |
317.86 KB |
Downloaded: |
93 Time(s) |
Burrilla
Posted: Wed Aug 30, 2023 10:59 am Post subject: Cabin fresh air exhaust |
G-IANI is indeed still flying, I know the owner is on the WhatsApp group but not sure about this one.
I had that mod installed on mine, G-OBJT but could not see any benefit and blocking it off decreased the CO2 reading on my monitor, and added weight for no real benefit so removed it.
Alan
Sent from my iPad
dmac7
Posted: Wed Aug 30, 2023 3:54 pm Post subject: Re: Cabin fresh air exhaust |
When it comes to Europa interior airflow each aircraft is somewhat unique, so I would not write off the duct from bulkhead to sternpost for all Europa's if it doesn't work on one. I think for it to be effective the flap slots would need to be somewhat blocked, I thought Klaus Dietrich designed some clear plastic flap slot cover's, I don't recall where I saw them but they looked good and not too difficult to build and install also one less opening for mice.
danbish99
Posted: Thu Aug 31, 2023 7:57 am Post subject: Re: Cabin fresh air exhaust |
Newbie question here - why would there be a need for the tubing from the D panel back to the port near the rudder? Seems you'd just install an adjustable vent or two below the D panel and an exit one near the rudder. The air is going to get to that exit with or without the tubing. Then test different adjustments in the vents until you get a setting that best matches your most used altitude. Wrong?
Dan
Burrilla
Posted: Thu Aug 31, 2023 8:12 am Post subject: Cabin fresh air exhaust |
Because you may find that the air pressure behind the D panel is higher than the cockpit and so you will simple see air coming from the rear to the cockpit unless you have some arrangement in the tail to lower the air pressure in that area.
In my aircraft that is what happens, Trigear XS.
Alan
Sent from my iPad
Dan
http://forums.matronics.com/viewtopic.php?p=511386#511386
Burrilla
Posted: Thu Aug 31, 2023 9:39 am Post subject: Cabin fresh air exhaust |
Don’t forget that you have the slots for the flaps which are below the wing during normal flight and may influence the pressure in the rear that you will need to compensate for.
Alan
Sent from my iPad
Quote: | On 31 Aug 2023, at 18:06, Wladimir Kummer <wladimirkummer(at)gmail.com> wrote:
I´m considering fitting a small air exit at the cockpit side where due the effect of wing´s top curvature there will be a negative pressure gradient. Also, I could be slightly turned down and after so to avoid water entering from rain.
Sender notified by
Mailtrack 31/08/23, 13:59:58
[img]https://mailtrack.io/trace/mail/ad7b2d87593e8241e4dc89b6a16e737e1191c76d.png?u=5817579[/img]Em qui., 31 de ago. de 2023 às 13:14, Alan Burrill <alanb(at)dpy01.co.uk (alanb(at)dpy01.co.uk)> escreveu:
Quote: | --> Europa-List message posted by: Alan Burrill <alanb(at)dpy01.co.uk (alanb(at)dpy01.co.uk)>
Alan
Sent from my iPad
> On 31 Aug 2023, at 16:59, danbish99 <bdanbish(at)gmail.com (bdanbish(at)gmail.com)> wrote:
> --> Europa-List message posted by: "danbish99" <bdanbish(at)gmail.com (bdanbish(at)gmail.com)>
> Dan
FORUMS -
WIKI -
b Site -
="noreferrer" target="_blank">https://matronics.com/contribution
