rleffler
Posted: Fri Jan 19, 2007 8:04 am Post subject: Shop Organization |
I've been reading material found all over on a variety of web sites, but I'm still looking for a "best practice" on how to organize all the various rivets, screws, etc.
It seems to me that keeping them all in the bags may becoming problematic after awhile.
So what has worked well for you? Equally important, what didn't work well for you.
thanks,
bob
_________________ Bob Leffler
N410BL - Phase I
LIKE2LOOP(at)aol.com Guest
Posted: Fri Jan 19, 2007 8:23 am Post subject: Shop Organization |
In a message dated 1/19/2007 11:07:37 AM Eastern Standard Time, rvmail(at)thelefflers.com writes:
Quote: | It seems to me that keeping them all in the bags may becoming problematic after awhile.
So what has worked well for you? |
I bought a bunch of the little stackable bins at Harbor Freight, then added labels (marker would work) and this is good for all the small parts. I have about 4 tall and maybe 10 wide on a shelf.
I have clear, stackable tupperware (cheap) like bins for rivets. Mine are about 6 x 6 inces and 1.5 inches tall. They are very hard to tip over. Label all sides with the rivet size...makes life easy. The cleco's go in bins and are very easy to manage.
Steve
deej(at)deej.net Guest
rvmail(at)thelefflers.com wrote:
Heh heh, I've been keeping them all in the bags... I make sure
there is a good label on the bag, and tend to keep the "like" rivets
together, such as flush AD-3s in one group, flush AD-4s in another, etc.
Other have used things like this:
<http://www.fodcontrol.com/trey.html>
or this:
<http://www.aircraftspruce.com/menus/ha/cabinet.html>
-Dj
Tim(at)MyRV10.com Guest
Posted: Fri Jan 19, 2007 8:30 am Post subject: Shop Organization |
Good question Bob. One thing: It's probably one more
of those situations where what works for one might not be
the favorite solution for another.
Here's mine:
I finally got tired of missing rivets and
nuts/washers/bolts/screws. After a while I decided that
the only way to own a plane long term was to just go to
Van's and Aircraft Spruce and order extras of all normal
sized AN3 bolts, and many AN4 bolts. Even a few AN5's.
I also bought many extra pop rivets, and quantities of
the driven rivets. Same with washers of all sizes, nuts
of all sizes, including all-metal locknuts for in the engine
area. ALL of this hardware I just sorted out into those
drawer type desktop bins. (The rivets are in those
spring-hinge lid carrying trays for portability). That
way you get used to finding standard hardware items
in a standard area...and it's easy to see if you're down
on quantity after you get done with the kit...so you can
keep a couple of everything on hand.
For the more specialized hardware, I found it easiest
just to have 3 or 4 small shoebox type bins handy, with
all of the baggies stacked in numerical order, and the
baggie parts lists on top of each bin full of parts. It
made it quick to locate all of the required special
parts during the build, and as one bin thinned out, you
knew you were getting done with that section. I just
numbered the bins with tape labels with the bag numbers
that were inside. Eventually you end up with one
small bin of some misc. things.
For the large parts, I stored them on shelves or stuffed
away in the basement in stacks so I could find them easily.
The fuselage and finishing kit parts I often left in
the big box, all laid out for easy viewing. The special
parts (like aileron trim kit, flap position sensor, lights...)
all went onto a set of shelves too.
Being organized will take time to set up, but it will save
time in the long run too. I was absolutely not
organized though, as I still had a few times where I
looked for a half hour to find a part. Some people go even
further and database everything. Lots of good ideas, but
any one method isn't for everyone.
well for you.
thanks,
bob
rvbuilder(at)sausen.net Guest
Posted: Fri Jan 19, 2007 8:47 am Post subject: Shop Organization |
What worked well for me was to buy some of those parts cabinets and
unload everything into the drawers. Label each drawer and then recycle
unused ones when the next kit shows. It probably takes me about 4 hours
to inventory the bags and get the parts put away and the bins labeled,
but it saves a lot of time on the backend. Some pics are here:
http://www.mykitlog.com/users/category.php?user=msausen&project 2&categ
ory=619
Michael Sausen
-10 #352 limbo
kearney(at)shaw.ca Guest
Posted: Fri Jan 19, 2007 8:48 am Post subject: Shop Organization |
Bob
I am sure there are wiser people than I on the list, but as one who has
asked the same questions here is what I did.
The Yard Store (www.yardstore.com) sells the Extreme Rivet Tray which has
spring loaded covers. Given that I have knocked it off my table once and
didn't spill a single rivet, I can attest that it turned what have been a
very "riveting" experience into a non event. Here is a link to it:
http://www.yardstore.com/index.cfm?action=ViewDetails&ItemID=885
As well, I got some small parts trays (with a cover) that I used to organize
all the bits and bobs that came with my tail kit. After inventorying each
bag, I put the contents into the appropriate bin which was labeled with
Avery computer labels. So far, I have always been able to find a part within
seconds and have not lost anything. I can sent you the empennage parts bin
labels electronically if you wish - they are printed on standard Avery
Labels.
Each subit was inventoried into a separate parts bin. I kept the subkits
intact so I could always find a particular part by referincing the Vans part
list and just looking in the appropraite bin. Parts that were too large to
put in bins were lfet in the shipping crates so they wouldn't get damaged. I
installed hinges on the flat shipping crate so the lid would open easily and
safely.
I have a few Rubbermaid plastic bins into which I place all the parts I
"pull" when building a particular subassembly. At the end of the day all
parts go back into the bin so the chances of losing a small item in the
workshop debris is limited. I also try not to leave things on the workbench
or elsewhere while working - everything goes back into the bin until needed.
Cheers
Les Kearney
RV10 # 40643 - Lost in the empennage
Vern(at)teclabsinc.com Guest
Posted: Fri Jan 19, 2007 8:56 am Post subject: Shop Organization |
Rubbermaid makes a small clear plastic box (~6" x 6" x 1 1/2") with six
or seven compartments. They also make bigger ones for the larger bolts
and fittings. I use several of these for my rivets and other items (ie
nutplates, bolts, ect.). Then I use a sharpie to mark the different
sizes or part numbers on the top of the lid. The down side is I once
flipped the box over with the lid open and mixed the rivet sizes up. The
good news was I was just finishing the wings so the box was almost
empty.
Vern Smith (#324 fuselage)
Posted: Fri Jan 19, 2007 9:17 am Post subject: Shop Organization |
What has worked the best for us is to buy little trays with lids like you
can guy in the fishing department of Wal-Mart. The trays need to be able to
close and latch, then you really want a clear plastic lid (all IMHO). Write
the size of the rivet on the lid and on the back of each compartment. We
have 3-4 trays for rivets, one for screws, 1 each for AN3, AN4 and AN5 bolts
(with washers and nuts in the same drawer), 1 for special washers, 1 for
special nuts, 1 for snap bushings, 1 or 2 for rod end bearings and threaded
rod ends (which you could do without, but it is nice to keep them this way),
and a couple extras for misc stuff. In fact, one time I found a little set
of 4 trays that fit in a little carrying case with a handle. It is so nice
to be able to grab a tray or set of trays and take it where you are working
with, say, AN3 bolts and have everything you need right there with you.
Also, getting the set of bolts/nuts/washers that Spruce sells is a great
help in case you need to go up or down a size somewhere.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
jjessen
Posted: Fri Jan 19, 2007 10:17 am Post subject: Shop Organization |
All the answers you'll get are correct, in this particular category.
However, Les is leading a charmed life. I've knocked over my spring lidded
marvel of an rivet tray and this is what good it did me.....
http://www.soundingsresearch.com/RV-10/Images/Empennage/Tailcone/IMG_3525_30
.html
So, as others have pointed out, your mileage will definitely vary.
I like to pick up some take out food on the way to the hanger, which is
definitely adding to the overall cost of the plane. Usually I get some type
of soup, mainly because the plastic containers are just the right size with
a lid that stays put. Makes for great storage for bulk or oversized parts.
But mostly I use one of the many platic drawer organizers that you can pick
up for cheap at HD or Sears. Get one with large drawers and one with all
small drawers and you'll almost have enough room. I actually do like the
spring loaded rivet tray, but depending on how it hits a cement floor, it
may not perform all that well.
But the most important thing is to take the time to sort and label
everything, no matter the container system. This will be well worth it in
the long run. I typically label by both part number and bag number.
Have fun!
John Jessen
#328 (back at it tomorrow! Huzzah!)
drfred(at)suddenlinkmail. Guest
Posted: Fri Jan 19, 2007 10:21 am Post subject: Shop organization |
I uploaded a couple of pictures to mykitlog on how I've organized
things. Basically, just get several plastic boxes and bin organizers
from Wal-Mart or your local supplier. Get some tape and a sharpie and
label the bins.
Make sure whatever you have your rivets in is lockable. There are too
many stories of wasted weekends trying to separate out fallen rivets.
Open the container, get a few out and transfer them to a 35 mm plastic
can or small lid. Lock the big box up and never set it where it can
spill.
Another thing that I have found helpful is my woodworking bench. Wood
blocks and some hold downs are very helpful when you are trying to rivet
a long spar. You always seem to need a third hand. I think I uploaded
some pics when I built the flaps. Also on Mykitlog.
I'll take a couple of pics of some riveting tips that I have found
useful. Especially when putting several thicknesses of parts together.
Hope this helps.
Fred Williams
40515
jhstarn(at)verizon.net Guest
Posted: Fri Jan 19, 2007 10:48 am Post subject: Shop Organization |
Rivet trays. Go to www.yardstore.com page# 16 in their catalog (Cat# 70
2006), part# 14299 for new ones. I ordered two of their "used" ones. Great
trays, carry handle, spring loaded covers (in case you forget to close
them). Can hold from 8 to 16 different sizes (16 if you buy the split
inserts). I bought two trays five years ago, GREAT item. Get on their
mailing list, they always have specials going. Used tools etc. KABONG HRII
N561FS Archive this one.
Subject: RE: Shop Organization
to
Write
bolts
bob.kaufmann(at)cox.net Guest
Posted: Fri Jan 19, 2007 10:53 am Post subject: Shop Organization |
I went down to the local aircraft supply store, Home Depot and bought 3
cabinets, plastic with trays in them 2 1/4 high by about 4 1/2 wide by 5
deep and they are three columns and 6 rows. Now wish I had bought 4, but it
has keep me out of the bag search.
Bob K 90/90
Posted: Fri Jan 19, 2007 10:54 am Post subject: Shop Organization |
John (and all),
I've done this once before myself....actually, I spilled
some rivets twice. I do have a great solution to the cleanup
though. Here's what I did:
Took a plastic large peanut butter jar, and 2 pieces of hose.
Tygon, or poly tubing will work fine, with an I.D. of 1/4"
or more. Put 2 holes in the jar lid, and stick both tubes
into the jar. One tub only goes through about 1 inch. That
tube gets hooked to your shop vac. The other tube gets stuffed
down to within an inch from the bottom. That tube is what
you use on the outside end to suck up the rivets.
So then I vacuumed them up, into the jar, but when I vacuumed
them I tried to scatter them enough to only suck same-sized
rivets. Hopefully you'll maybe spill one size mainly, and
only a few oddballs. After you vac up one size, just empty
the jar and do another. You should be left with very few
rivets to hand sort.
The reason this happened to me is that I stuck a pen in the
lid to hold it open while I fished out rivets. Then of
course, I bumped the box off the chair.
Anyway, it makes for easier cleanup and sorting.
.html
Have fun!
John Jessen
Posted: Fri Jan 19, 2007 11:03 am Post subject: Shop Organization |
BUT then again I have known people who have the ability to disassemble an
anvil too.
Do Not Archive KABONG 8*)
Deems Davis
Posted: Fri Jan 19, 2007 11:38 am Post subject: Shop Organization |
Do what works for you, but you really can't call yourself an RV builder
until you've run a high speed drill through your thumb/finger/hand/
arm/? and spilled a container of rivets at least once !
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
thanks,
bob
LloydDR(at)wernerco.com Guest
Posted: Fri Jan 19, 2007 12:22 pm Post subject: Shop Organization |
You forgot drilling a friends or spouse finger to make yourself an
experienced builder. Only once you have done this and then talked the
person into coming back out to help can you truly be one of the crazy
guys in the garage....I have even heard rumors that if you get multiple
fingers of different people the value goes up!
Dan
rene(at)felker.com Guest
Been there done that....
Drilled finger
Drilled under finger nail
Dropped two trays of rivets....3-4, 3-4.5, did not attempt to sort, just
scoped them up, picked sizes out I needed that weekend and ordered
more....they come presorted that way.
Rene' Felker
40322
N423CF
801-721-6080
jjessen
Posted: Fri Jan 19, 2007 1:10 pm Post subject: Shop Organization |
You know that you are making progress towards RV builder Level 7 status when
you look down at a pile of scooped up rivets and can pick out a 3-3 from a
3-3.5 or 3-4 and get it right every time. Telling the 3-5 from a 3-4 took
me a little bit longer, like about 5 secs. Or, when you stick a rivet into
place and look at it before riveting and say, "that's too long" or "that's
too short." Amazing visual computer we got in our heads.
I consider that I'm still at Level 2. You don't get to Level 3 until you
have the Empennage completely done, the hole in the finger, the significant
other putting want ads in the paper for a new partner, the town telling you
that you really should mow the lawn before the fire season gets going, the
car hasn't been cleaned out in months, you've dumped rivets at least once
and it fazes you not one whit, the check book not balanced and the bills
piling up, nights spent staring out the window wondering why you aren't at
the hanger building (this at midnight), built the extension to the garage or
opened a hole to the basement, and so on.
We'll have to suppose those who are flying, have the painting done, all the
fairings done, all the electronics working like they should, and are now
simply having the time of their lives, are at Level 6. Not sure yet what
takes you to the blissful and enviable Level 7, but this has to be reserved
for the truly spiritual.
Bob Collins
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Fri Jan 19, 2007 2:19 pm Post subject: Re: Shop Organization |
When they were making "From the Ground Up," I was over at Oshkosh for a SportAir workshop and they let us tour the "set" (it was the hangar) where Joe Schumacher was building the plane. It was a FABULOUS workshop (perhaps you've seen the videos). One thing I thought was cool is he made an A-frame structure on casters. On one side he mounted all of the plans, so you could flip it up and over.
On the other side he had several rows of trays...with baby-food jars holding all the parts in an organized fashion.
I didn't construct the A-frame, but I did make a unit with shelvesof baby food jars, each holding a difference sized , rivet, platenut, screw, washer etc.
I also created spreadsheets as I unpacked each subkit, indicating where I put it, so that when it came time -- usually months later, sometimes years, I'd just fire up the spreadsheet and look it up.
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
