Posted: Sat Dec 22, 2007 5:23 pm Post subject: Canopy Gas Struts (Springs) |
Hi guys,
I received my gas struts only two days after ordering. I bought the 40
lb force type and replaced the old ones today. I also took the old
springs and tried pushing each down
on a scale to see what the extended 1/2-inch force was after 4 years. I
got 28 lbs on one and 30 lbs on the other. The new springs are 40 lbs
right on the money and they
hold the canopy up without any difficulty. But for leakage over time, I
still feel the 40 lb type is the way to go.
robert stone wrote:
| Quote: | When you order the kit for the Zodiac601XL the 40# gas struts
will be included. You might specifically request 60# struts when you
order the kit however I don't know if Zenith Aircraft even stocks the
stronger ones. I would order direct from the McMaster-Carr Company,
Stock number for the 60# strut is 9416K123, the company web site is:
http://www.mcmaster.com/
Bob Stone
Harker Heights, Tx
ZodiacXL w/Jabiru 3300
s.c.richards(at)homecall. Guest
Posted: Sun Dec 23, 2007 3:19 am Post subject: Canopy Gas Struts (Springs) |
Larry
I think you are correct in using the lower pressure struts If canopy was
not latched correctly & opened in flight it may be impossible to reclose it
if gas struts are too strong. I beleive someone in UK had this problem & had
difficulity in maintaining level flight due to increased drag donot know
what struts he used. We have used adjustable struts & let the pressure out
(about 35lbs) so they just opened the canopy (of earlier design to XL) these
have also leaked over time & need replacing or topping up, they still hold
the canopy open after we lift it.
Merry Christmas
Clive
dredmoody(at)cox.net Guest
Posted: Sun Dec 23, 2007 7:03 am Post subject: Canopy Gas Struts (Springs) |
I think something important has been left out of the discussion regarding the strength of the gas charged struts or their loss of strength over time. The geometry of the design for their installation is such that the strut will only exert its rated force at the point when the canopy is almost closed (the strut is fully compressed or nearly so). Not coincidentally, that is also the point at which the canopy rail and strut bracket have the best mechanical advantage in compressing the strut. In other words, the only time the struts exert their full rated force, be that 40# or 60# or whatever, is right when the full weight of the canopy is helping to push down vertically with its greatest force and at it greatest leverage advantage. The struts' force at that point is also linear (or nearly so) along the long axis of the canopy rail so bending the rail to overcome that force is a very remote possibility.
Conversely, the point at which the force of the strut on the rail is lateral and at its greatest mechanical advantage against the canopy rail is when the canopy is fully open and the first bit of closing effort is made. If you test a new 40# stut versus a new 60# strut on a scale in the first inch or so of compression you will find that the difference is not the nominal 20# but only a fraction of that difference in force. The full 20# difference won't be in play until you have almost closed the canopy and at that point the mechanical advantage of the strut is so severely diminished that the extra force required to finish closing the canopy will be almost unmeasurable.
I believe it is safe to use whichever strength of strut you find necessary to prevent the canopy weight and/or a gust of wind from slamming it down. Having the canopy go throught that event will very likely cause injury to one of us or at the very least to the canopy itself. If it takes a couple of extra pounds of force at the open position to accomplish that margin of safety, I'm okay with that. I received the 40# struts with my kit and I just bought a pair of 60# struts from McMaster-Carr. Not a very big investment to secure the option to use them if and when I deem it necessary. My installation was such that they can easily be changed at any point I need to. The down side is that if I store them as backups, they will certainly lose strength by the time I need them. That may actually work to my advantage in that I may put them into service as 50# or maybe even 40# struts if and when I need them.
The incident reports regarding the 601XL canopy popping open in flight are all in agreement that the canopy will only open a few inches at most before the slipstream pressure prevents further opening. The reports also agree that the aerodynamic lift (or some other unknown force) effectively prevents closing it fully once it has lifted even that small amount. That makes it clear that the "popping open" sort of incident will not be affected one way or the other by the change of strut pressure.
Bottom line: (A) make damn sure you have the canopy securely closed as a part of your run-up checklist and use it. And (B) use whatever strut strength is required to make reasonably sure that your canopy won't slam down unexpectedly.
Sound reasonable? Merry Christmas all,
Dred
purplemoon99(at)bellsouth Guest
Posted: Sun Dec 23, 2007 9:10 am Post subject: Canopy Gas Struts (Springs) |
Dred,I bought the70# and they work great,they make the movement of the canopy more solid and seems to remove alot of the left and right slop at the rear of the canopy ,and my canopy is locking better than it ever has,seems to open smoother with less effort there great..... JoeN101HD601XL/RAM
rstone4(at)hot.rr.com Guest
Posted: Sun Dec 23, 2007 9:39 am Post subject: Canopy Gas Struts (Springs) |
Ed,
What you say below makes much sense to me. I completely eliminated the problem of the canopy slamming shut by it's self by installing the 60# struts and the system works fine now.
I had the canopy pop open in flight twice and so eliminated the Zenith design and installed my own, the same one I used on a KR-2 that I built some years ago. Its a latch I can see and I have had no problems with my canopy since making these two changes. If any of you guys have had a canopy pop open in flight you know it scares the hell out of you and if you would like to see my new latching system, I will furnish pictures and an explanation upon request.
Posted: Sun Dec 23, 2007 10:39 am Post subject: Canopy Gas Struts (Springs) |
Bob, I've got a cross member across the rear of my canopy,I'am thinking about a light chain with a snap on it ,with about 2" of slack to stop real radical pop open . Would like to see your set up Thanks Joe N101HD XL/RAM
Posted: Sun Dec 23, 2007 11:55 am Post subject: Canopy Gas Struts (Springs) |
➢ The incident reports regarding the 601XL canopy popping open in flight are all in agreement that the canopy will only open a few inches at most before the slipstream pressure prevents further opening.
Actually I had a very different experience in a similar situation. I was flying left-seat with my instructor in an Evector SportStar. This plane is very similar to the 601XL: low-wing LSA with a forward hinged bubble canopy. One difference Is that the canopy is split behind the seats. There is a cross-bar behind the seats:
www.evektoramerica.com/SportStarPlus.htm
The canopy popped while we were in the pattern. I would estimate that the gap was well over a foot. While the instructor flew I tried to close the canopy. I wrapped my arm around the cross-bar and used all my weight and strength and could not close the canopy. At best I think I got the gap down to 6-8 inches. Evector redesigned the latch the next year.
I believe the upward force was generated by lift and not wind under the canopy as it did not decrease as I closed the gap.
-- Craig
Posted: Sun Dec 23, 2007 12:03 pm Post subject: Canopy Gas Struts (Springs) |
Thanks Bob, you already sent me the photos and I pointed out that the hinge pin of that latch would be the weakest link to watch. I am strongly considering something like what you did but as a redundant measure..... sort of like that little cahin on a lady's bracelet, you know?
Merry Christmas,
Ed
Posted: Sun Dec 23, 2007 12:05 pm Post subject: Canopy Gas Struts (Springs) |
Joe,
I use a 1/16th x .75 nylon strap with plastic buckles to aluminum loops
center of the rear bow to one between the seat backs. It works fine,
and it doesn't have
the hard shock value of a chain if it gets caught in a breeze. It's
adjustable and doesn't get in the way up or down and doesn't weigh anything.
see links,
http://www.macsmachine.com/images/canopy/full/viewupperbracket.jpg
http://www.macsmachine.com/images/canopy/full/viewcanopyopen.jpg
I have had the canopy act as a sail with me setting on the wing and
carry me slowly across the apron a
couple of times until it was lowered, so it's durable
Posted: Sun Dec 23, 2007 1:07 pm Post subject: Canopy Gas Struts (Springs) |
I have just addressed this topic in an e-mail to the net. More information to follow.
Bob Stone
Posted: Sun Dec 23, 2007 2:12 pm Post subject: Canopy Gas Struts (Springs) |
Great idea Larry,Abetter mouse trap....Merry Xmas. Joe N101HDXL/RAM
Posted: Mon Dec 24, 2007 9:42 am Post subject: Canopy Gas Struts (Springs) |
Hi All
I am afraid the statement below is no longer correct, I
will attempt to attach a PDF scan my bit map scan is to large of an article
from the UK PFA magazine for
November to which my previous reply referred. I had trouble in locating
origin of report when replying. I will not test if this true unless by
accident.
Wishing you a Merry Christmas & trouble free flying
Clive
canopyopening.pdf |
99.01 KB |
512 Time(s) |
Posted: Mon Dec 24, 2007 9:59 am Post subject: Canopy Gas Struts (Springs) |
Thanks very much for the report. It sounds similar to what I experienced in the Evector.
A year or so ago someone mentioned having pictures or a video of a popped canopy on a 601. But they didn't want to post them so as to save embarrassing the pilot.
Guess I'll be using a block and tackle for my test. But I was planning to do it on the ground. If the test was done in the air I would suggest having someone in the right seat.
-- Craig
Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Tue Dec 25, 2007 6:26 am Post subject: Re: Canopy Gas Struts (Springs) |
Craig,
That compares with a situation the guy in the next hangar told me about.
a guy with a 601 at my field told me this; he forgot to securely latch the canopy on the right side. After takeoff, he noticed it due to the noise. He attempted to pull the right side down and latch it securely. This guy is about 6’ 4” and is a bear of a man. He said he couldn’t get it down, so he decided to loosen the left side so that he could level the canopy and then pull both sides down and close the latches.
Big Mistake.
He said the canopy immediately went to about 45 degrees and he entered a steep dive. He was able to reduce power, level off and gain control over the airplane. At full power, he was not able to climb, as the canopy acted like a speed brake.” At full power, he headed back to the airport at his present level and was able to land. He said everything that was unsecured (insecured?) err, not secure, in the airplane departed, including extra headsets, gps, log books, etc.
Tommy Walker in Alabama
N8701 18.5 hrs
P.S. Please don't take this as criticism of the 601 design. The PIC is responsible for making sure the canopy is secure before takeoff.
[quote="
-- Craig[/quote]
_________________ Tommy Walker
N25A - Anniston, AL |
Iberplanes
Joined: 10 Dec 2007 Posts: 174 Location: Igualada - Barcelona - Spain
Posted: Tue Dec 25, 2007 7:14 am Post subject: Canopy Gas Struts (Springs) |
To all of you,
BSCL : BEFORE START CHECK LIST. That´s mandatory and have to include tha
canopy latch check,
Happy new Year !!
_________________ Alberto Martin
601 XL - Jabiru 3300
http://www.iberplanes.es
Igualada - Barcelona - Spain |
Posted: Wed Dec 26, 2007 7:00 am Post subject: Canopy Gas Struts (Springs) |
Tommy.
You are right about one thing, the PIC is responsible for insuring that
the canopy is latched prior to take off. However the designer/producer of
the aircraft in question is responsible for insuring that his design is safe
and airworthy and with as many reports as I have seen on this forum about
canopies opening in flight including my own, I think the design is flawed.
Even though the aircraft is well built I had to glue strips of foam rubber
on the bottom side of the rear seal to keep cold air out. Also, this canopy
is too heavy for the supplied 40# gas struts because before I installed the
60# struts my canopy slammed down several times. One time was at our last
Young Eagles Flight Rally and a 10 year old boy got bonked on the head.
That's when I decided to do something about the weak struts.
Bob Stone
Harker Heights, Tx
rsteele(at)rjsit.com Guest
Posted: Wed Dec 26, 2007 9:38 am Post subject: Canopy Gas Struts (Springs) |
I think it's worth pointing out that, in fact, even if the design is
flawed, the designer of an experimental aircraft isn't responsible
for the airplane, the builder is. That's why it's an experimental.
It's a responsibility that's all to easy to ignore for us kit
builders, but it's the reality and something we shouldn't forget.
Sounds like there needs to be a checklist item for these latches -
another builder responsibility.
That said, I'm sure CH and everyone at Zenith is very serious about
safety and if they felt there were issues they would be corrected.
I'm guessing the issue with the struts is one of stress on the canopy
when the struts are new (you don't want to stress the canopy while
closing it) verses struts that weaken over time or are not up to
snuff when new.
Perhaps we should all test the strut strength before installation.
This is the type of discussion that makes this list so valuable. It
must have been really lonely being a builder before the days of the
internet.
Ron
On Dec 26, 2007, at 10:00 AM, robert stone wrote:
Tommy.
insuring that the canopy is latched prior to take off. However the
designer/producer of the aircraft in question is responsible for
insuring that his design is safe and airworthy and with as many
reports as I have seen on this forum about canopies opening in
flight including my own, I think the design is flawed. Even though
the aircraft is well built I had to glue strips of foam rubber on
canopy is too heavy for the supplied 40# gas struts because before
I installed the 60# struts my canopy slammed down several times.
One time was at our last Young Eagles Flight Rally and a 10 year
old boy got bonked on the head. That's when I decided to do
Bob Stone
Harker Heights, Tx
Tommy Walker
Posted: Wed Dec 26, 2007 1:52 pm Post subject: Re: Canopy Gas Struts (Springs) |
The point I was trying to make (and doing a poor job) was that based upon my neighbor's experience, you can't close the cowl if it pops open after takeoff.
Plus I added the Caveat lector, "let the reader beware" about design and checklist...
I've never been in a 601 and I guess I should keep my mouth shut.
N8701
[quote="rsteele(at)rjsit.com"]I think it's worth pointing out that, in fact, even if the design is flawed, the designer of an experimental aircraft isn't responsible for the airplane, the builder is. That's why it's an experimental. It's a responsibility that's all to easy to ignore for us kit
internet.
Ron
Tommy.
Bob Stone
Harker Heights, Tx
ggower_99(at)yahoo.com Guest
Posted: Wed Jan 02, 2008 4:10 pm Post subject: Canopy Gas Struts (Springs) |
I am now building a 601 XL, Not yet in the canopy area... But one thing is important in any airplane: Doesnt matter how overbuilt or extra safety is any canopy or door lock of any airplane, will fail if the pilot will not follow the checklists in every one of the points.
Also lets remember that only the wiser men can design simple and light.
Any one can desing a complicate and heavy what ever, just need to keep "thinking" and adding ideas
Now back... We all have to go through every check list routine the same every time, from beguining to end, never forget or skip any point.... All are so important that our life might depend on them.
Saludos
Gary Gower
Flying from Chapala, Mexico.
Tommy Walker <twalker(at)cableone.net> wrote:
| Quote: | --> Zenith-List message posted by: "Tommy Walker"
N8701
internet.
Ron
Tommy.
Bob Stone
Harker Heights, Tx
Tommy Walker
Be a better friend, newshound, and [quote][b]
