Shipping from Europe to USA
Goto page Previous  1, 2, 3  Next
brian-1927(at)lloyd.com
PostPosted: Wed Jan 16, 2008 9:09 pm    Post subject: Shipping from Europe to USA Reply with quote
On Jan 16, 2008, at 6:20 PM, Bitterlich, Mark G CIV Det Cherry Point,
MALS-14 64E wrote:
Point, MALS-14 64E" <mark.bitterlich(at)navy.mil>
Thanks for the interesting reply Brian.
Just for kicks someday, you might try experimenting with shunt
loading the whole aircraft itself. This is often done on the
tactical aircraft I am associated with and works extremely well.
Huh. Neat idea. Yeah, that could be made to work. Feed the ends of the
wings as a balanced antenna. The wings would become a form of folded
dipole. I may just try that with the CJ while I have it all apart. It
would be easy to set that up.
Trailing wire systems on an aircraft with fabric control surfaces
makes me grimace, but you obviously have more experience with it
than anyone else around these days.
The trick I used was to run a tube out through the tailcone and then
line it with polyethylene tubing. The trailing wire went out inside
that. It formed a coax with the wire being the center conductor. My
Collins KWM-2 liked it so I didn't need a tuner. I just cranked it in
and out to make it resonate on the frequency I was using. The nice
thing is that the wire was completely behind the aircraft so there was
no way it could get hooked on any of the control surfaces. My landing
checklist still has "trailing wire -- in" on it. I tend to get "WTF"
from copilots when they read the checklist to me. Smile
Brian Lloyd 3191 Western Drive
brian HYPHEN 1927 AT lloyd DOT com Cameron Park, CA 95682
— Antoine de Saint-Exupéry
PGP key ID: 12095C52A32A1B6C
PGP key fingerprint: 3B1D BA11 4913 3254 B6E0 CC09 1209 5C52 A32A 1B6C
cliff(at)gesoco.com
PostPosted: Thu Jan 17, 2008 6:34 am    Post subject: Shipping from Europe to USA Reply with quote
You know....you can just take a SAT phone.....
> makes me grimace, but you obviously have more experience with it than
Clifford Coy
Director of Maintenance
Border Air Ltd
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
Skype: callto:Cliff.Coy <callto:cliff.coy>
RAMPEYBOY(at)aol.com
PostPosted: Thu Jan 17, 2008 6:40 am    Post subject: Shipping from Europe to USA Reply with quote
On the subject of importing foreign aircraft...with these military trainer types, do you have a lot of red tape to go through to import them? I did a little research once on importing an F-86 into the states, and it was way more red tape than I was willing to be involved in...Sounds like it's not so bad with the YAKS? Still best to go through a broker I guess and let them do what they do!
Boyce
Start the year off right. Easy ways to stay in shape in the new year.
PostPosted: Thu Jan 17, 2008 7:01 am    Post subject: Shipping from Europe to USA Reply with quote
Naw, that would be too easy. Smile
cliff(at)gesoco.com
PostPosted: Thu Jan 17, 2008 7:04 am    Post subject: Shipping from Europe to USA Reply with quote
I'd have to say the difference is mostly engine type and armament
packages.
The FAA has a little more heartburn over the capabilities of an F-86
than a Yak-52.
The Yak 52's were never really used as combat aircraft- the straight
52's don't have provisions to hang anything on the wings (not so for the
52TW tho').
Cliff
Boyce
<http://body.aol.com/fitness/winter-exercise?NCID=aolcmp00300000002489>
in the new year.
Clifford Coy
Border Air Ltd
629 Airport Rd.
Swanton, VT 05488
802-868-2822 TEL
802-868-4465 FAX
PostPosted: Thu Jan 17, 2008 2:01 pm    Post subject: Shipping from Europe to USA Reply with quote
Interesting idea, at least from a civil aircraft standpoint. Will the FAA buy that for over water beyond VHF range flights?
In the EA-6B it is not quite that simple. We have embedded gold flake in the aircraft canopies that was designed to keep RF out. Givent the ERP of the jammers, that is not really a bad idea. Regardless, it is pretty darn effective once you get up past UHF. Sure... Just install some coax and an external antenna.
And the readers of this list would simply be AMAZED at what it would take to actually do that.
Mark
PostPosted: Thu Jan 17, 2008 2:09 pm    Post subject: Shipping from Europe to USA Reply with quote
I wonder how many people besides myself know what a KWM-2 is, and the load that SOB must have put on the battery when transmitting! 6146 finals no less.
Not exactly a dash mounted rig was it? Where in the name of blazes would you mount that in a 52?
Lastly.... Collins gear is still my very favorite. I still own an S line myself that I restored decades ago. A 32S3C (yep, a "C" model that was actually made by ROCKWELL/Collins (!!!) and a 75S3C receiver... With station console. If it does not glow in the dark, what good is it? Smile
Mark Bitterlich
cjpilot710(at)aol.com
PostPosted: Thu Jan 17, 2008 2:43 pm    Post subject: Shipping from Europe to USA Reply with quote
In a message dated 1/17/2008 5:10:31 P.M. Eastern Standard Time, mark.bitterlich(at)navy.mil writes:
Just returned from ground school/recurrent training on the B17/B25/B24. The B-24 is getting major work done on her fuel tanks.  While waiting for that, one of our volunteer pilots, is refurbishing and restoring the original radios in the radio compartment. This includes the Morris code key, throat mikes, etc. Plus by May he will attempted to have a working Norton bomb sight. I've been told that if you hold a neon tube next to the antennae while transmitting, it will light the tube, with out a power cord.
Also as PIC I will be required to get a Ham radio license because of the frequencies IF I need to use the radios!!!
Not only that they're getting the belly turret fully functional (yes minus guns) and the top turret can now be moved manually. The old plastic glass turret was not perfectly round and would bind. While up there one day doing the refueling, I slipped while stepping over the turret and broke it when I fell on it. The new one ($5,500) is perfect. Who said I couldn't be an agent of change?
Newest pilot comfort? Fuel gages, new glass over head and a new electric standby horizon.
Pappy. -.. --- --- .-.. ... -.-. Y (I think)
[quote]--> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil>
Mark Bitterlich
PostPosted: Thu Jan 17, 2008 3:14 pm    Post subject: Shipping from Europe to USA Reply with quote
You're lucky Pappy, code is no longer required for an amateur ticket.
You spelled "d o o l s c" Not too bad.
I think you were trying to spell your last name: --. --- --- .-..
My first HF radio was a WW-II ARC-2B. AND I STILL HAVE IT (although
sadly my ex-wire poured salt all over it and pretty much ruined it). I
am not sure what bomber carried it, but it was definitely a bomber HF
rig. If memory serves, about 2-7 Mhz. Did AM, CW, and MCW. MCW is no
longer legal on the HF ham bands, but AM and CW sure are. I think you
could create quite a stir getting on the ham bands in a B-24, especially
while flying, but even on the deck would be special! Hey, I did...
When I called CQ from an EA-6B flying over IRAQ in Desert Storm, it
caused quite a pile-up. Of course 10 meters was wide open, and the
sunspot cycle was at it's peak. Rog on the neon tubes. We used to
actually hang them from wire antenna during Vietnam. Caused quite a
light show at night! Also a good indicator of power out. Surprised
that the radio in the 24 would do that... My best recollection is that
the finals in those radios were 24 volt 811's, ... 1622's? Man, I can
not remember, but basically a pair of 811's with a 24 volt filiment.
Typically about 25 watts carrier on HF (100 watts PEP). That's all you
really need.
Anyway, consider yourself lucky.... Back in the day (sheesh I am getting
up there with Pappy), you had to copy one minutes worth of 5 letter code
groups without making an error. They sent for 5 minutes, and you had to
get one full minute of that copy with NO ERRORS! By the time I went for
my extra class (20 words per minute), they had changed it to just
multiple choice questions, and it was actual text instead of code
groups... Much easier. Now... No code at all. I still think that was a
big mistake. The more you work for something, the more you value
that.... Somehow that message got lost in today's world.
Good Luck Pappy, let us know what callsign you get!
Mark Bitterlich
WA3JPY
MarkWDavis
PostPosted: Thu Jan 17, 2008 3:15 pm    Post subject: Shipping from Europe to USA Reply with quote
I'm not sure about the effectiveness of the gold canopies on the Prowlers.
When I was in the RAG, the story was that an instructor had taken a home
microwave radiation detector up when the pods were radiating and it pegged
the meter. Whenever I had ECMO's that insisted on "burning out" the pods
because it was good for them I explained that since we weren't at war it
wasn't really necessary. I didn't mind if we were actually using them. If
the Master Rad light didn't go out soon, I slowed down below 220 KIAS so the
RATs kick at least one transmitter off line. If I was light enough I'd take
it down under 192 KIAS so both kicked off line. Pissed 'em off. But my
nuts didn't glow in the dark!
dave(at)davelaird.com
PostPosted: Thu Jan 17, 2008 3:21 pm    Post subject: Shipping from Europe to USA Reply with quote
Mark and Brian,
I'm starting to think that you two need to spend some quality time
together - off list... in person - like maybe dinner, drinks and a
movie.
'Cuz your big-brain-mutual-admiration-society-of-two is starting to
sound more and more like a budding romance to me these days... Wink
Uh, not that there is anything wrong with that... in some states...
I jest because i love,
Dave Laird
N63536 1983 CJ6A "Betty"
Dallas (ADS)
On Jan 17, 2008, at 4:06 PM, Bitterlich, Mark G CIV Det Cherry Point,
Mark Bitterlich
PostPosted: Thu Jan 17, 2008 4:18 pm    Post subject: Shipping from Europe to USA Reply with quote
On Jan 17, 2008, at 1:58 PM, Bitterlich, Mark G CIV Det Cherry Point,
Turns out it doesn't matter what the FAA says. It only matters to the
country of departure and then, most don't even pay attention. The
Canadians did insist that I drop by for an inspection of the airplane
and me. The modified KWM2 (I changed the crystals and then retuned it
for the aviation HF bands) and trailing wire was deemed satisfactory
even tho' it didn't even remotely qualify as FCC-approved. (The FCC
has jurisdiction over radios, not the FAA.) They only cared if it
would work to communicate. In fact, the inspector said, "wow, I
haven't seen one of those in an aircraft for a long time. They work
great, don't they," as he handed me the paper that told the boys in
Gander to let me take off eastbound. No one in any other country even
looked.
Radio is fun. Almost as much fun as airplanes and computers.
brianl AT lloyd DOT com Cameron Park, CA 95682
PostPosted: Thu Jan 17, 2008 4:45 pm    Post subject: Shipping from Europe to USA Reply with quote
On Jan 17, 2008, at 2:06 PM, Bitterlich, Mark G CIV Det Cherry Point,
30A on voice peaks. I had the supply for the KWM2 wired directly to
the battery with its own contactor. I could still run the HF off the
battery in order to make a mayday call even if the rest of the
electrical system failed. Oh, and I had a backup battery for the rest
of the avionics. It was sized to run my LORAN and one comm radio for
the rest of the flight in case I lost my alternator. I figured I could
make position reports through the airliners.
Everything had 6146 finals and a 12BY7 driver.
Well, in the Comanche it was mounted right on top of the ferry tank.
There was just enough room for it between the tank and the ceiling.
The life raft was right next to it.
And I would not use a KWM2 (I stupidly sold it years ago) in the -52.
I would use my Icom IC-706mkII with my SGC-231 tuner. I have hacked
the Icom for general coverage transmit so I can use it in the
airplane. It will even transmit AM on the VHF aircraft band so I can
use it as a backup comm too.
I have always wanted a 32S3B/C and a 75S3C. I just haven't been able
to bring myself to pay the freight they bring these days. I had the
KWM2 and a 75S1/32S1 combo once. I am sorry I sold them too.
OTOH, there are some new designs that work very well. I have been
playing around with software-defined radios. Pretty cool stuff.
f4ffm2(at)adelphia.net
PostPosted: Thu Jan 17, 2008 4:52 pm    Post subject: Shipping from Europe to USA Reply with quote
On Jan 17, 2008, at 4:16 PM, Brian Lloyd wrote:
--> Yak-List message posted by: Brian Lloyd <brian-1927(at)lloyd.com (brian-1927(at)lloyd.com)>
On Jan 17, 2008, at 1:58 PM, Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E wrote:
--> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>
Turns out it doesn't matter what the FAA says. It only matters to the country of departure and then, most don't even pay attention. The Canadians did insist that I drop by for an inspection of the airplane and me. The modified KWM2 (I changed the crystals and then retuned it for the aviation HF bands) and trailing wire was deemed satisfactory even tho' it didn't even remotely qualify as FCC-approved. (The FCC has jurisdiction over radios, not the FAA.) They only cared if it would work to communicate. In fact, the inspector said, "wow, I haven't seen one of those in an aircraft for a long time. They work great, don't they," as he handed me the paper that told the boys in Gander to let me take off eastbound. No one in any other country even looked.
____________________________________________________________________________________
But it bores the crap out of a lot of us!
Best regards anyway,
Roger_______________________________________________________________________________
[quote]Brian Lloyd                         3191 Western Drive
          - The Yak-List Email Forum -
  --> http://www.matronics.com/Navigator?Yak-List
              - MATRONICS WEB FORUMS -
  --> http://forums.matronics.com
            - List Contribution Web Site -
  Thank you for your generous support!
--> http://www.matronics.com/contribution
PostPosted: Thu Jan 17, 2008 6:52 pm    Post subject: Shipping from Europe to USA Reply with quote
writes:
That is correct. I have often used that as a quick test for output.
Not necessarily. If you are using it in an aircraft on the aviation
frequencies your restricted radiotelephone license is sufficient.
OTOH, if you use it in the ham bands you will need a ham license. You
will need at least a general-class license. The requirement for morse
code has been removed.
Well, in code that was DOOLSCY. I think you wanted to send GOOLSBY
which would have been:
If you want to learn morse code there is an *EXCELLENT* system called
"Code Quick". It is what I am using to teach the code to the kids at
school. All the 5th-8th graders are studying for their ham radio
licenses and even tho' they aren't required to know the code, I am
teaching it to them anyway as their technician-class licenses will
only allow them code privileges on 80M, 40M, and 15M.
Code Quick web site: http://www.cq2k.com/
PostPosted: Thu Jan 17, 2008 6:57 pm    Post subject: Shipping from Europe to USA Reply with quote
On Jan 17, 2008, at 3:19 PM, Dave Laird wrote:
Mark and Brian,
movie.
Naw, we'd get together and he'd show me his (rig) and I'd show him
mine. Sounds like he has some stuff I'd like to have -- including the
-50.
Aw, shucks.
Hey, I live in California. If you ain't gay you ain't ... uh, electable.
Ah, but *whom* do you love? That is the question. Wink
Dave Laird
Dallas (ADS)
yakplt(at)yahoo.com
PostPosted: Thu Jan 17, 2008 11:43 pm    Post subject: Shipping from Europe to USA Reply with quote
We have the same interests and the same hobbies.  Even in his current activity of working with kids, we do more or less the same thing. His "kids" are a lot younger than mine, but what the heck! :_0
As for the other insinuation.... I heard the same thing about you, but when you told me you tried it and did not enjoy it at all, I decided to never mention it again. Am I a nice guy or what?
Mark Bitterlich
yakplt(at)yahoo.com
PostPosted: Thu Jan 17, 2008 11:58 pm    Post subject: Shipping from Europe to USA Reply with quote
Brian, I was talking about the idea of a sat phone taking the place of an HF radio. Not whether the KWM-2 was legal. Shoot... I believe the first SSB radios put in military aircraft was done by Collins and Curtis Lemay... 75A4 receiver I think.
Mark Bitterlich
yakplt(at)yahoo.com
PostPosted: Fri Jan 18, 2008 12:14 am    Post subject: Shipping from Europe to USA Reply with quote
Roger, a lot of things that other people say on this list bore me to east Jesus as well. I am far from a perfect person. To Wit: Along with all those technical articles on YAK electrical systems and "how to" articles that have helped a few people anyway, I also sometimes ramble along about other technical aspects such as managing to figure out how to make an HF antenna work on a general aviation aircraft. I admit the idea of flying a YAK-52 across the Atlantic also excites me just as much as an Immelman off the deck at 9VG.
Hopefully the good outweighs the bad. It may not in your case. Oh well.
As you said: "Best Regards Anyway"
Mark Bitterlich
jan.mevis(at)informavia.b
PostPosted: Fri Jan 18, 2008 1:47 am    Post subject: Shipping from Europe to USA Reply with quote
I’m not bothered by these discussions at all. At the contrary. If I don’t have much time, then I don’t read them completely.
I just don’t like “agressive” replies. And to the readers that have English as their native langue, please don’t forget that a lot of us outside usually speak other languages. So we make errors.
Jan
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Yak Pilot
Sent: vrijdag 18 januari 2008 9:11
To: yak-list(at)matronics.com
Subject: Re: Shipping from Europe to USA
Mark Bitterlich
Page 2 of 3
