Shell smoke oils
Goto page Previous  1, 2
nigel(at)yakdisplay.com
PostPosted: Mon Oct 20, 2008 10:29 pm    Post subject: Shell smoke oils Reply with quote
Here in the UK most display yaks run with one of two:
Marcol
or
Ondina
Shell Ondina is in my tank. It’s the base oil used in pharmacy (a bit like “baby oil”).
Thin, clear, (good for your skin apparently!), environmentally friendly, odourless, and edible.
Meaning it’s cockpit breathable with no nasty side effects……
Also produces thick WHITE (not the faintest hint of a brown) smoke.
Nigel
http://yakdisplay.com
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of cjpilot710(at)aol.com
Sent: 21 October 2008 01:30
To: yak-list(at)matronics.com
Subject: Re: Shell smoke oils
In a message dated 10/20/2008 5:47:38 P.M. Eastern Daylight Time, valleyauto(at)clearwire.net writes:
I tried it once. No good.
Jim "Pappy" Gooldby
Has anyone tried used automatic transmission fluid? Is it good or bad? I have a auto repair shop with lots of used fluid.
PostPosted: Tue Oct 21, 2008 4:37 am    Post subject: Shell smoke oils Reply with quote
In a message dated 10/20/2008 10:17:49 P.M. Eastern Daylight Time, johnwcox(at)pacificnw.com writes:
Actually I have breathed a blend of O2 and nitrous oxide. I recommend it big time! Particularly if you starting to pass a kidney stone at the Gatwidk airport immigration booth. A couple whiffs of that stuff and the world is just plain beautiful. The ambulance ride to Surrey Sussex hospital was like an carnival ride with me enjoying every minute. NO PAIN.
John that's a great idea about having it in my CJ. I think I could use a hose I seen sold at ACE. Doc, where can I get that stuff?? ;-}
Pappy
MSDS sheets are available on all of these alternatives including Pappy's Mobil One synthetic 10W that is recycled. Know the handling and toxicity of any product that you use. If you need one, an MSDS sheet, let me know.
Etienne provided some great (Fabulous) smoke shots which many of you can relate to the ingestion of the oil you are burning. Then again Pappy has probably plumbed that Chinese leather mask with an independent supply of O2 or nitrous oxide blended gas.
Vegetable, Mineral or Synthetic they all get the job done with differing toxicity to the pilot.
John Cox.
New MapQuest Local shows what's happening at your destination. Dining, Movies, Events, News & more. Try it out!
pilko2(at)btinternet.com
PostPosted: Tue Oct 21, 2008 5:16 am    Post subject: Shell smoke oils Reply with quote
Try the nearest Maternity Unit ...., I had a really easy time of Labour whilst my wife was pushing !
kp
Sent: 21 October 2008 13:37
Pappy
John Cox.
href="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
viperdoc(at)mindspring.co
PostPosted: Tue Oct 21, 2008 11:14 am    Post subject: Shell smoke oils Reply with quote
Double malt mate?
Could have been the CO causing the HA and puking your guts up too.
Doc
l39parts(at)hotmail.com
PostPosted: Sun Nov 02, 2008 9:04 am    Post subject: Shell smoke oils Reply with quote
What the hell is double malt?  Good scotch is single malt C the others are blends.  I know the air force is full of chardonnay drinkers C but I'd expect better of the navy.
[quote] Subject: RE: Yak-List: Shell smoke oils
Date: Mon C 20 Oct 2008 20:41:09 -0400
--> Yak-List message posted by: "Bitterlich C Mark G CIV Det Cherry Point C MALS-14 64E" <mark.bitterlich(at)navy.mil>
So you're telling me you get good smoke burning Double Malt Scotch even
if it does make you have a headache after puking your guts out?
You da man.
Mark
Page 2 of 2
