Airing up the tires through the wheel pants.
Goto page Previous  1, 2
sportav8r(at)gmail.com
PostPosted: Fri Nov 06, 2009 7:44 am    Post subject: Airing up the tires through the wheel pants. Reply with quote
I leave the caps off the (AirStop) tubes.  Works fine for me.  Using a 4" screw-on extension through a fancy spring loaded door in the pants - same idea as a pugged hole others use.  I like the looks of Ed's straight-on chuck from Harbor Freight.
Bill Boyd
On Fri, Nov 6, 2009 at 9:58 AM, Richard Dudley <rhdudley1(at)bellsouth.net (rhdudley1(at)bellsouth.net)> wrote:
[quote]--> RV-List message posted by: "Richard Dudley" <rhdudley1(at)bellsouth.net (rhdudley1(at)bellsouth.net)>
Hi Bill,
I used a short length of plastic (polyethylene) tubing with ID slightly less than the OD of he cap. I split it to about a half inch from the end. I pushed it onto the cap. There was enough friction to unscrew and hold the cap. After filling the tire, I re-installed the cap and withdrew the tube. Worked well for three years.
Richard Dudley
RV-6A sold
Bill Schlatterer
PostPosted: Fri Nov 06, 2009 4:53 pm    Post subject: Airing up the tires through the wheel pants. Reply with quote
Man, I hate it when I type faster than I think ;-( Pretty oblivious/obvious
isn't it Smile Nutdrivers, poly hose, fuel line,,.... Sooo simple!
Thanks Bill
n142ds(at)gmail.com
PostPosted: Fri Nov 06, 2009 5:55 pm    Post subject: Airing up the tires through the wheel pants. Reply with quote
I gently come in from the side with a polymer putty knife.  Pops right off!
David W. Schaefer
RV-6A N142DS  "Nerdgasm"
TMX-IO360 Dual-LightSpeed Plasma IIIs, Hartzell Blended Airfoil, GRT HX EFIS
On Thu, Nov 5, 2009 at 8:34 PM, Bill Schlatterer <billschlatterer(at)sbcglobal.net (billschlatterer(at)sbcglobal.net)> wrote:
[quote] --> RV-List message posted by: "Bill Schlatterer" <billschlatterer(at)sbcglobal.net (billschlatterer(at)sbcglobal.net)>
So how do you deal with getting the valve stem cap on and off with only a
one inch hole? Go up from the sides or do you just not use a cap?
Bill S
7a finishing
Page 2 of 2
