Oil shut-off valve
Goto page Previous  1, 2
yakplt(at)yahoo.com
PostPosted: Sat Sep 18, 2010 7:36 pm    Post subject: Oil shut-off valve Reply with quote
Actually Jan, I don't believe in parking brakes. I personally think they are an accident looking to happen.
Mark
--- On Sat, 9/18/10, Jan Mevis <jan.mevis(at)informavia.be> wrote:
[quote] From: Jan Mevis <jan.mevis(at)informavia.be>
Subject: RE: Oil shut-off valve
To: yak-list(at)matronics.com
Date: Saturday, September 18, 2010, 3:45 AM
"Jan Mevis" <jan.mevis(at)informavia.be>
For a parking brake in my 50, I use something very simple:
a velcro strap
(like the ones used to tie up network cables) with which I
hold the brake.
When ready to depart, I simply unlock the brake by removing
the strap
(without undoing it) and then shift it on the stick. (If
this is unclear I
'll make a photo and post it to the list). I leave it on
the stick all the
time. It can't become an FOD while flying because your hand
is in the way.
Jan
William Halverson
PostPosted: Sat Sep 18, 2010 7:45 pm    Post subject: Oil shut-off valve Reply with quote
Oh .. no ... so I have to be infirm enough to _not_ be able to pull
the blades through now? Maybe rig up a torque wrench somehow?
Good God, time to trade her in for a lawn mower.
Hal
At 08:24 PM 9/18/2010, Yak Pilot wrote:
Actually, "when in doubt" pull out the spark plugs and let the oil
drain. It is actually quite easy to bend connecting rods just
using the prop as a lever. So it is actually not all just about how
many times you pull the prop through, but also how you are holding
it, where you are holding it, how hard you are pulling it, etc.
Doc advocates letting it all come out of the sump drain. Others
recommend fixing the ball check valve. Others recommend an oil shut
off valve.
PostPosted: Sat Sep 18, 2010 11:18 pm    Post subject: Oil shut-off valve Reply with quote
I concur with that, and I use my small mod only for starting up the
aircraft. When needed I can add another prime or two, without worrying that
the aircraft might jump forward. You never know who might be foolish enough
to stand in front of the prop ... even after shouting a loud "prop cleaar
Jan
PS: I would NEVER leave an aircraft alone with a running engine, and parking
brakes set, like some do.
radiopicture
PostPosted: Sun Sep 19, 2010 2:52 am    Post subject: Oil shut-off valve Reply with quote
I agree that one should NEVER leave the aircraft when it's running
(who does that, anyway?), but parking brakes have other purposes, such
as, oh, PARKING (chocks not always available immediately, or needed
for a short stay). Also, I always use the parking brake during pull
through... especially when it might have been flown recently, because
if somehow the mags are on (passengers anyone) and you failed to check
it, at least the plane wont be advancing on you while it's trying to
chop you up. Lastly, even though I'm in the plane, I set the parking
brake during start-up and shut-down run-ups.
worrying that
enough
cleaar
Jan
parking
radiopicture
PostPosted: Sun Sep 19, 2010 2:54 am    Post subject: Oil shut-off valve Reply with quote
If you're pulling them through from the middle third of the blades,
you'll know if something's up.
On Sep 18, 2010, at 11:43 PM, William Halverson wrote:
<william(at)netpros.net>
Hal
> how many times you pull the prop through, but also how you are
> holding it, where you are holding it, how hard you are pulling it,
> etc.
> shut off valve.
viperdoc(at)mindspring.co
PostPosted: Sun Sep 19, 2010 6:56 am    Post subject: Oil shut-off valve Reply with quote
Nay, just get a flat head Lycoming if that fearful of hydraulic lock.
Between the options of installing an oil cutoff valve with an electrical
interrupter linked to the mag switch is a great idea. An electric sump pump
that is run at shutdown in conjunction with the oil cutoff valve is another
great idea also. Simply draining the sump after shutdown keeps with my
belief in the KISS principle. But, even the KISS principle can bite you on
the ass if you arrived at the field with you head behind the power curve.
Pouring the gallon of oil back into tank is an entertaining experience to
say the least after the plane that I thought did not have a problem with
its' internal oil check valve is enlightening to say the least. So much for
the IRAN experience. So, the bottom line simply is trust nothing to be
totally fail safe. Now saying that living by the kiss principle, having
intake drains installed, draining the sump, pulling a min of 12 blades,
priming the cylinder side with the intake drain stop cock open while
watching for more oil to run out, being patient while the oil drains out of
the intake drain, and then closing the intake drain followed by pulling 4
more blades has worked for me through the last sortie. Will it work for this
afternoon? I don't know but I hope so.
Bottom line, if the process works for you and meets the common sense sniff
test then use it at your own risk. The Russians wrote the checklist and
pilot's handbook based on their years of experience with these aircraft.
Those techniques are tried and tested but also remember there was a ground
crew to prep and launch the aircraft so not to many pilots were going in and
out of the cockpit to pull blades, prime and pull more blades.
So since we all over time have learned what 70 to 80 lbs per cylinder X's a
min of 8 blades feels like if it starts to feel firmer as you are pulling
through STOP. Double check what you are doing. If you have an intake drain
make sure it is open. BUT, the best cure is open the cowl, pull the plugs,
and intake drain plugs. Now that can be simple or a real pain in the ass
depending on how complex you have gotten with the prevention of hydraulic
leak thing. Pulling plugs is however the definitive cure for hydraulic lock
though.
So, if it feels different to pull on the blade then stop and drain the
cylinders by pulling the plugs on the bottom cylinders. That way you know
for sure the hydraulic lock is cleared. Now granted, your O'Dark thirty
launch is going to be delayed for a couple hours while you do that though.
Doc
PostPosted: Sun Sep 19, 2010 7:03 am    Post subject: Oil shut-off valve Reply with quote
Danged, guess I got lucky when my 74 came with a parking brake leaver on the
stick like those found in the back seat of a 52. Who says the experimental
show did not exist in the DOSAF?!
Doc
mark.bitterlich(at)navy.m
PostPosted: Sun Sep 19, 2010 2:04 pm    Post subject: Oil shut-off valve Reply with quote
Doc, I believe most 50's originally came with the "parking brake" feature, but they were REMOVED by the Russians, for some reason like our version of an "AD". The man who would know all about that would be Richard Goode. He knows ALL the different updates to that airplane! I think there might have been a FOD or some other safety issues dealing with it. That is a wild A__ guess based on something I read ages and ages ago. Check with him.
Wouldn't surprise me to find your aircraft unsafe. HA! Just kidding Doc!
Jan, it is not an issue with me. I have hydraulic TOE BRAKES. They work even when the air pressure is at ZERO. Make wheel landings MUCH easier. Probably the best mod I have seen on this aircraft and the work FLAWLESSLY. The mod also put on Cleveland wheels (I can now use Goodyear tires) and disk brakes.
Mark
From: owner-yak-list-server(at)matronics.com on behalf of Roger Kemp M.D.
Sent: Sun 9/19/2010 10:56 AM
Doc
PostPosted: Sun Sep 19, 2010 2:20 pm    Post subject: Oil shut-off valve Reply with quote
See? It's all a matter of personal approach. I am 100 THOUSAND per cent sure Eric that this works for you. ME? I pull from the very END of the blade. But as I come around into compression I am not really PULLING. I am slowly with my fingertips inching it around very slowly FEELING for how much resistance it has. For me, that lever advantage also adds to what I can feel with my fingertips. It's all about experience and what works for "you". There really is no "perfect way", but just what works... period.... tof the person involved. I believe the utimate method is just being VERY CAREFUL and realize what can happen and what you are trying to "feel".
Personally, I look just slightly askance at the "pull so and so many blades" for every single type of occasion. It's not the number of blades really to me, other than to make sure all 9 cylinders have gone through at least one compression stroke of course, but rather how it feels as you are moving the prop through, and then how much oil I see coming out of the exhaust.
It's hard to put experience into the written word.
When it comes to this particular subject, there is so MUCH advice, a lot of it DIFFERENT, all of it technically CORRECT, and hard to figure out what is the "best way".
I didn't know hydraulic "Lock" from the ones sold by the Master Company when I first got my airplane. Now I know exactly what it feels like when I get even CLOSE to it.
Hard to explain how I got there. Smile
Mark
From: owner-yak-list-server(at)matronics.com on behalf of Eric Wobschall
Sent: Sun 9/19/2010 6:51 AM
Subject: Re: Oil shut-off valve
Hal
> etc.
> shut off valve.
PostPosted: Sun Sep 19, 2010 2:50 pm    Post subject: Oil shut-off valve Reply with quote
Eric, you probably won't like this and.. I am sorry for not agreeing, but I have to say I totally disagree with you in as polite a way as possible.
If we stay with stock brakes in the YAK series aircraft that use COMPRESSED AIR to actuate the brakes, then when that compressed air goes away... your parking brake all of a sudden "isn't". I have sitting in my hangar a spare YAK-50. I don't advertise that fact much because everyone always wants to borrow parts off it, and sadly I have been burnt by a few folks doing that, so I simply will not do it anymore. But the interesting thing is: A guy got out to start that particular airplane with the parking brake on. It starts. The air was depleted from the system. It started. It ran at speed into a hangar and ripped the wings right off. Picture/proof sitting in my hangar.
Relying on parking brakes for the exact reasons you just mentioned has in my mind an element of danger that is not required.
If "somehow the mags are on" there is also a the possibility that "somehow there is no air either", and that means no brakes.
Chocks/chains/ropes to me those are the only answers. And preferably two out of three.
My words are not going to change your opinion and they are not meant to. Why I am writing this is simply to put a bigger picture into the view of the discussion.
I think it carries a little bit of weight when someone says: "Parking Brakes can be dangerous, especially if you trust them to keep the airplane from moving when you are not in it". When you give that as a "theory" warning, of course that is one thing and doesn't carry all that much of an impact.
When you show pictures of one of the must beautiful YAKS ever out there, totally ruined by someone who relied on the parking brake ... it carries a lot more. I look at that airplane all the time, and I guess that is why I am so much against parking brakes AT ALL. But, I will readily admit to being overly cautious because of looking at that wreck every time I fly.
Mark
Sent: Sun 9/19/2010 6:48 AM
worrying that
enough
cleaar
Jan
parking
Good idea Vic. I'd personally like to know what you come up with as a solution if you don't mind telling. I've looked at the same issue myself and have seen a number of solutions.
Just because some might be interested, one of the best solutions I saw was with a lever you had to reach in with BY HAND through the back of the engine cowl in order to open the oil valve. Now that by itself was not so hot, but what made it REALLY cool is that it was also hooked to a lever arm that caused a BIG BRIGHT RED ROUND ROD to come out the top of the cowl right in front of the pilots eyes. Pretty darn hard to miss when starting the engine.
My personal idea is:
I don't like messing with the P leads, but one thought I had was to use a MECHANICAL SWITCH (no relays... although, yes, that would make it easier) and instead of using a small microswitch that interupted the starter switch (ala the other method) instead a hard wired mechanical switch that GROUNDS THE P LEADS! If the oil lever is CLOSED the "P" leads are GROUNDED. No oil, no engine start. PERIOD.
The only thing I don't like about that method is the idea of messing with the P leads. One more thing to break on a system that is absolutely essential that it works correctly. P leads are not something you really want to ever ground out on you accidentally.
I have not come up with the exact parts for this idea. But I think it might be worth thinking about some more.
Shutting off the oil after flight goes a LONG way towards minimizing the liklihood of bad things happening, but all you have to do is screw up ONCE and good bye engine. I'm trying to come up with a "fool proof design". So far, I've failed.
Mark
From: owner-yak-list-server(at)matronics.com on behalf of Vic
Sent: Fri 9/17/2010 8:03 PM
Hello ,
thank you all for your feedback about some side effects of my setup. Quite frankly, I only had in mind to prevent starting the engine with oil valve closed. And no, I did not think about an emergency shutdown in case a mag or two remained hot because of a broken earth connection. I will keep the oil valve anyway but am thinking of a way to close the fuel tap individually, but both valves to open with a mechanical linkage. I do not like an electric workaround of this problem, as some say, wires and switches do break. Anyway I keep you posted.
Vic
http://forums.matronics.com/viewtopic.php?p=312804#312804
radiopicture
PostPosted: Sun Sep 19, 2010 4:56 pm    Post subject: Oil shut-off valve Reply with quote
Mark, I'm not confused about our relative experience levels, so I
attribute full weight and value to your opinions. I can certainly see
how disaster can happen when relying on parking brakes in different
circumstances, and of course, judicious aircraft positioning is always
wise during any start for that reason. However, I think there's some
confusion here: You said "The guy got out". I am saying you should
NEVER have a plane running without a pilot in it. I was ONLY referring
to the routine pulling-though of the prop with the mags and ignition
off (obviously not running) AND the parking brake on for extra safety.
I have even been known to turn off mags in both cockpits. Only a very
foolish person would hand-prop a plane that's out of the same air that
actuates the brakes. Similarly foolish would be getting out of a plane
while it's running.
I am also saying that when you're IN THE PLANE, it's good to have the
parking brake on, as you might let off while concentrating on other
cockpit tasks. If something goes wrong, you're in position to re-apply
the brakes or cut the mags. Of course, this is not as necessary with
toe brakes.
Third reason to use the parking brake: Until you find chocks or tie
downs. Just in case there's any confusion, the search for chocks and
tie downs would not be with the engine running.
On Sep 19, 2010, at 6:25 PM, Bitterlich, Mark G CIV Det Cherry Point,
MALS-14 64E wrote:
Point, MALS-14 64E" <mark.bitterlich(at)navy.mil>
a way as possible.
in my hangar.
Mark
> worrying that
> enough
> cleaar
> Jan
> parking
radiopicture
PostPosted: Sun Sep 19, 2010 4:58 pm    Post subject: Oil shut-off valve Reply with quote
Agreed. When you know what you're doing, you can certainly pull on the
end of the blade. Just when you give dispensation, someone who's much
stronger than usual will manage to break something.
On Sep 19, 2010, at 6:10 PM, Bitterlich, Mark G CIV Det Cherry Point,
Mark
> Hal
>> etc.
>> shut off valve.
wlannon(at)persona.ca
PostPosted: Sun Sep 19, 2010 7:13 pm    Post subject: Oil shut-off valve Reply with quote
When a mag switch fails it fails to LIVE. A broken "P" lead makes the mag.
LIVE.
Pulling the prop through at mid blade is an invitation to eventual disaster.
Mark's procedure is the only correct one.
Walt
richard.goode(at)russiana
PostPosted: Mon Sep 20, 2010 12:42 am    Post subject: Oil shut-off valve Reply with quote
I'm reasonably sure that NO Yak 50s had a "parking brake" from manufacture.
Those that now do will usually have a modified 52 brake lock fitted.
Richard
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
PostPosted: Mon Sep 20, 2010 6:15 am    Post subject: Oil shut-off valve Reply with quote
Copy Richard. Thanks. As I thought since my stick looks exactly like the one in the 52 RCP I assumed that some RU backyard engineering took place. Still a nice feature to have to starts and run ups. Again common sense must prevail. Start with brake locked, stick full aft, throttle  at idle or barily open, and run up to 70% for mag check after CHT/oil in normal range. Stick aft standard for tail draggers starts and runups.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Richard Goode
Sent: Monday, September 20, 2010 3:38 AM
Richard
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
United Kingdom
----- Original Message -----
From: Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E (mark.bitterlich(at)navy.mil)
Sent: Sunday, September 19, 2010 10:55 PM
--> Yak-List message posted by: "Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)>
Mark
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) on behalf of Roger Kemp M.D.
--> Yak-List message posted by: "Roger Kemp M.D." <viperdoc(at)mindspring.com (viperdoc(at)mindspring.com)>
Doc
PostPosted: Mon Sep 20, 2010 2:37 pm    Post subject: Oil shut-off valve Reply with quote
You are very clearly advocating the use of parking brakes and are convinced that you have good ideas for using them. And there is no real right or wrong here, only a difference of opinion. It is not about experience levels... I don't put myself up on any pedestal, unless we are talking about a field I am a qualified professional in, and this is NOT one of them!
That said:
If you get out to do the "routine pulling of the prop" and you have a busted mag wire, the airplane can start. I would never trust my life to a parking brake. Therefore anytime I am pulling a prop through, at the very minimum that are two sets of chocks under the tires. That's just me, but I have seen blood all over the place and it kind of made a deep impression on me. It also made a deep impression on that guys leg.
For every point you make there is a counterpoint, just like mine to yours.
If you set a parking brake so that you can concentrate on other things, you are TRUSTING a parking brake to ALLOW YOU to take your concentration off the airplane moving. I don't happen to agree with that.
Simply put, I just will never trust a parking brake. Period. Not in any way. That very clearly may be an over-reaction as I have said. But... that is especially true when the parking brake relies on a system of continuous pressure, whether it be air or hydraulic. I just do not trust a system like that. You can, and more power to you! I will not... and more power to me. I chock the aircraft. Period.
Lastly, I also have to admit I have spent years aboard aircraft carriers. Unless an aircraft is on the cat, there are guys shoving chocks under it every time it stops. And everyone of them have parking brakes. Same same on the flight line after shut-down.
I like chocks. I don't like parking brakes. Not trying to change your mind at all. Mine will never change. Smile
Mark
Sent: Sun 9/19/2010 8:53 PM
while it's running.
toe brakes.
a way as possible.
in my hangar.
Mark
> worrying that
> enough
> cleaar
> Jan
> parking
radiopicture
PostPosted: Mon Sep 20, 2010 7:26 pm    Post subject: Oil shut-off valve Reply with quote
Logical. And of course, the Yak-52 was designed around the ground crew
culture. Something for one to consider when you're by yourself.
On Sep 20, 2010, at 6:26 PM, Bitterlich, Mark G CIV Det Cherry Point,
yours.
that.
Period.
Mark
while it's running.
toe brakes.
> a way as possible.
> in my hangar.
> Mark
> ________________________________
> such
> check
>> worrying that
>> enough
>> cleaar
>> Jan
>> parking
Page 2 of 2
