Float Flyr
Posted: Wed Dec 05, 2007 10:20 am Post subject: Carb Heat |
On the coldest frostiest days you will never get carb ice. It’s just too dry. Of course Ethanol puts a new wheel on the cart when it comes to carb ice. With that cursed stuff all bets are off.
On warmer days when the temperature is around the freezing mark (32F) and the relative humidity is in the 90 %s. With the humidity that high you are a good candidate for carb ice.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Sbennett3(at)aol.com
Sent: Monday, December 03, 2007 11:17 PM
Subject: Re: Re: Carb Heat
In a message dated 12/3/2007 9:41:12 PM Eastern Standard Time, dave(at)cfisher.com writes:
Any carbeurated engine can get carb ice or carb icing |
True, but we dont all fly in Canada.
If you have Carb heat then you have one less thing to worry about not having If you need it .
If you have carb heat, you better be prepared to use it cause you are always intaking colder air. Here we go again re hashing this... If I lived where I grew up near Chicago, i'd have it. Down where I live now... A different story. Steve Bennett NC
hottest products and top money wasters of 2007.
| Quote: | | http://www.matronics.com/contribution | 012345678901234
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
