john.marzulli(at)gmail.co Guest
Posted: Mon Jun 19, 2006 4:30 pm Post subject: Am I borked? |
Concerning the 701 Elevator:
When placing the rear spar ( 7h2-2 ) to 7h1-4 and and the other two ribs, is
it more critical to insure the ribs are at a right angle to the rear spar,
or that 7h2-2 is centered relative to the front spar ( 7h2-1 ).
I already drilled one of the full length ribs so it is flush to the rear
spar doublers ( next to, not overlapping ), and everything is at a right
angle, but I noticed that one of the clamps on the other rib slipped and now
the other rib is about 10mm off from the doubler when at a right angle to
the rear rib.
Moving the rib that I already drilled 5mm doesn't seem like an option since
the holes and rivets would be very close.
Any suggestions?
John in Seattle
http://701Builder.blogspot.com/
Posted: Tue Jun 20, 2006 8:00 am Post subject: Am I borked? |
Thank you everyone for your advise.
I luckily just messed up the measurments, not the part. After careful
measurement with the piece clamped down more I realizes the piece was
shifting when I moved the square. Some holes did need to be widened just a
bit, but it shouldn't be an issue.
John in Seattle
is
now
the rear rib.
since
Any suggestions?
John in Seattle
John Marzulli
