jluckey(at)pacbell.net Guest
Posted: Thu Nov 21, 2013 4:05 pm Post subject: Making fat wire fatter |
I need to terminate a piece of #2 or #4 (not sure which) welding cable with a #0 wire terminal. So I want to increase the diameter of the stranded copper a little bit so that it fits snugly within the #0 wire terminal.
I'm thinking about inserting the copper from some #12 solid wire into the center of the #2 (or #4) to fatten it up and then crimping it... Or maybe using a #6 brass machine screw inserted the same way.
Suggestions?
-Jeff
ceengland7(at)gmail.com Guest
Posted: Thu Nov 21, 2013 4:31 pm Post subject: Making fat wire fatter |
On 11/21/2013 6:04 PM, Jeff Luckey wrote:
| Quote: | I need to terminate a piece of #2 or #4 (not sure which) welding cable with a #0 wire terminal. So I want to increase the diameter of the stranded copper a little bit so that it fits snugly within the #0 wire terminal.
Suggestions?
-Jeff
| I'm pretty sure that Bob has a comic book on his site describing just that technique, using copper wire.
Posted: Thu Nov 21, 2013 5:59 pm Post subject: Making fat wire fatter |
Why not acquire the proper terminal?
Posted: Thu Nov 21, 2013 7:45 pm Post subject: Making fat wire fatter |
If that were possible, I wouldn't be asking this question
Without going into great detail - the terminal in question is built in to an existing fixture in a ground power connector plug.
Sent: Thursday, November 21, 2013 5:59 PM
Subject: Re: Making fat wire fatter
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
www.homebuilthelp.com[/url]
_-= * My Pilot Store www.mrrace.nbsp; -Matt Dralle, List ========================
timrhod(at)aol.com Guest
Posted: Thu Nov 21, 2013 8:32 pm Post subject: Making fat wire fatter |
I made small pieces of #12 copper wire sharpened them on one end and tapped them into the welding cable inside the terminal. when tight I then soldered it. Then placed heavy shrink tubing over the terminal and wire as a stress reliever.
On Nov 21, 2013, at 7:04 PM, Jeff Luckey <jluckey(at)pacbell.net (jluckey(at)pacbell.net)> wrote:
[quote]I need to terminate a piece of #2 or #4 (not sure which) welding cable with a #0 wire terminal. So I want to increase the diameter of the stranded copper a little bit so that it fits snugly within the #0 wire terminal.
Suggestions?
-Jeff
ctric.com
| Quote: | www.buildersbooks.com
uilthelp.com
otstore.com
matronics.com/contribution
st">http://www.matronics.com/Navigator?AeroElectric-List
cs.com
