Nose Wheel Boot/Tire wear
wschertz(at)comcast.net
PostPosted: Fri Nov 22, 2013 8:47 am    Post subject: Nose Wheel Boot/Tire wear Reply with quote
I have noticed that my front tire is wearing unevenly. The left side of the tire is worn significantly more than any of the rest of the tire. I attribute this to the nose wheel being ‘cocked’ from the prop airstream, so the tire is slightly (or more) deflected during flight, causing the left side to hit first, and then the wheel straightens.
If this is the case, then the fairings might not do as much as you expect.
Sent: Friday, November 22, 2013 8:43 AM
To: kis-list(at)matronics.com (kis-list(at)matronics.com) ; HERNANDEZ GALIN (galinhdz(at)gmail.com)
Subject: Re: Fiberglass Nose Wheel Boot
11/22/2013
Hello Galin, Attached are two pictures of my KIS TR-1 nose wheel pant. I put it together from a nose wheel pant from Van’s and shaft fairing from Glastar.
OC
Sent: Friday, November 22, 2013 6:47 AM
Subject: Fiberglass Nose Wheel Boot
Does anyone know where I can get a fiberglass nose wheel boot? It is the kind that is cut in half like the one in the attached photos.
kentpyle(at)iland.net
PostPosted: Mon Nov 25, 2013 7:46 am    Post subject: Nose Wheel Boot/Tire wear Reply with quote
I
oo have had unexpected nose wheel ware. I thought it might be caused by a canted strut. Kent
nFrom: William Schertz (wschertz(at)comcast.net)
Sent: Friday, November 22, 2013 10:46 AM
Subject: Nose Wheel Boot/Tire wear
11/22/2013
OC
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.mypilotstore.com">www.mypilotstore.com
href="http://www.mrrace.com">www.mrrace.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?KIS-List">http://www.matronics.com/Navigator?KIS-List
