Posted: Wed Dec 25, 2013 12:23 pm Post subject: Stick grip |
Guys
Those of you who used the Infinity (military type) stick grip, do you remember how much tube did you cut to shorten your stick?
And what did you use to adapt the stick grip internal diameter (1”) to the stick tube outside diameter (7/8”)?
Carlos
Posted: Wed Dec 25, 2013 12:47 pm Post subject: Stick grip |
Assuming you are staying with Van's panel, cut the stick such that the Infinity grip is as low as it can go (as in the bottom of the grip is touching the weld for the curved portion of the stick).
I got the adapter from Infinity - it came with the grip.
Carl
On Dec 25, 2013, at 3:23 PM, "Carlos Trigo" <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
[quote] <![endif]--> <![endif]-->
Guys
And what did you use to adapt the stick grip internal diameter (1β) to the stick tube outside diameter (7/8β)?
Carlos
ot;">www.aeroelectric.com
books.com"">www.buildersbooks.com
quot;">www.homebuilthelp.com
quot;">www.mypilotstore.com
">www.mrrace.com
List"">http://www.matronics.com/Navigator?RV10-List
//forums.matronics.com
Posted: Wed Dec 25, 2013 1:01 pm Post subject: Stick grip |
I don't remember how much was cut off, but infinity sells an adapter/spacer to make up the difference in diameter.
Jesse SaintI-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
Guys
Carlos
">www.mrrace.com
Kelly McMullen
Posted: Wed Dec 25, 2013 4:09 pm Post subject: Stick grip |
I think you will find that you should not take off the last 1-1.5" of the vertical part of the stick, so there is something to support the grip. The other aspect is that you need to make an elevator stop in the tail section to limit nose down elevator travel to Van's minimum of around 20 degrees. They allow a tolerance to 25 degrees, but that will have the stick grip hitting the panel no matter how short you make it. Other choice is to have the stick curved section bent to a smaller radius, but you are talking about bending heat treated chrome moly tubing with powder coating on it, so lots of ways to screw that up.
On Wed, Dec 25, 2013 at 1:23 PM, Carlos Trigo <trigo(at)mail.telepac.pt (trigo(at)mail.telepac.pt)> wrote:
Guys
And what did you use to adapt the stick grip internal diameter (1) to the stick tube outside diameter (7/8)?
Carlos
_blank">www.aeroelectric.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
tp://forums.matronics.com
- sent from the microchip implanted in my forearm
A&P/IA, EAA Tech Counselor
KCHD |
rleffler
Posted: Wed Dec 25, 2013 4:43 pm Post subject: Stick grip |
If you have an Aerosport panel, you'll want to cut it pretty short. I think I have about an inch below the grip.
Sent from my iPad
On Dec 25, 2013, at 3:55 PM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
[quote]I don't remember how much was cut off, but infinity sells an adapter/spacer to make up the difference in diameter.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
| Quote: | <![endif]--> <![endif]-->
Guys
Carlos
">www.mrrace.com
_________________ Bob Leffler
N410BL - Phase I
Posted: Wed Dec 25, 2013 7:26 pm Post subject: Stick grip |
I used the Tosten grip (which I like a lot for a couple of reasons - the Infinity seems great too). My panel is roughly standard. The stick with the grip definitely interfered with the panel.
I cut it a bit, can't say how much, but more was required.
I bent the sticks in a press to increase the standard curvature. Using wood blocks it was pretty easy to do but clearly one could go too far and perhaps start to buckle the sticks. Going slow and checking the clearance until it just cleared worked great. It's not hard to do. I requires a simple hydraulic press (think HF). I went and used a neighbor's press.
Bill
Guys
Carlos
Checked by AVG - www.avg.com
12/25/13 [b]
Posted: Thu Dec 26, 2013 1:42 am Post subject: Stick grip |
Thanks for your answers.
I just ordered the adapter from ACS, and now I confirmed that I should cut the tube in order to avoid the grip to hit the panel, that was what I expected.
Carlos
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: quinta-feira, 26 de Dezembro de 2013 00:09
Subject: Re: Stick grip
Guys
Carlos
01234567890123456789012345678
