oil seal part number
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List
gkrysztopik(at)satx.rr.co
PostPosted: Wed Jun 21, 2006 5:07 pm    Post subject: oil seal part number Reply with quote
Mines weeping too, Auto Zone says it's a Felpro BS40387. no cross ref
available. Spose I'll check NAPA tomorrow because I want to make sure I
have the right part when I pull it.
Sounds like I should try to get the aluminum spacer too.
I may put the belt drive up for sale if anybody knows anyone that wants
one.
gary
- The Matronics Stratus-List Email Forum -
http://www.matronics.com/Navigator?Stratus-List
bryanmmartin
PostPosted: Thu Jun 22, 2006 2:28 am    Post subject: oil seal part number Reply with quote
The seal I got as a replacement for mine was made by Chicago Rawhide.
I don't have the part number handy but that's what the retailer cross
referenced it to. It's the same size as the National that it replaced
but the sealing lip is a bit deeper in the seal so it doesn't ride on
the same groove the old one made in the spacer so I had no problem
with that.
My plane is back in the air and it doesn't leak! Now I just have to
continue breaking in the rings and I'll be ready for Oshkosh.
sure I
wants
one.
gary
> <larry(at)macsmachine.com>
> Bryan,
> The seal you need is the National 415021. I will forward an info
> sheet
> on these seals.
> Larry McFarland - 601HDS at www.macmachine.com
> Bryan Martin wrote:
>> Does anybody know the part number for the oil seal for the lower
>> redrive bearing? I got my airplane back in the air today but it's
>> leaking oil from the seal.
Bryan Martin
do not archive.
Bryan Martin
do not archive.
PostPosted: Thu Jun 22, 2006 4:12 am    Post subject: oil seal part number Reply with quote
Thanks Bryan.
With a little luck, I'll see you there. Do you park with
autoconversions, Zeniths or camping?
gary
bryanmmartin
PostPosted: Thu Jun 22, 2006 4:27 pm    Post subject: oil seal part number Reply with quote
Last year I parked my plane among four other Zodiacs in the homebuilt
area and set my tent up in the trees near the classics camping area
with a bunch of other members of my EAA chapter. I'll probably do the
same this year.
Thanks Bryan.
gary
Bryan Martin
do not archive.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Stratus-List All times are GMT - 8 Hours
