jebrick(at)comcast.net Guest
Posted: Sat Jan 25, 2014 4:37 am Post subject: RV-4 For Sale |
RV-4 For Sale (N474JB)<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Located on Pierce County Airport – Thun Field (KPLU)
TT A&E 1340 hours.
Aero Sport Power, IO-360-B1B with 9.2 compression.
Airflow Performance fuel injection with purge valve.
B&C Starter and Alternator.
Lightspeed Plasma III electronic ignition in place of right mag.
Whirl Wind 200RV constant speed prop.
Full IFR panel. GPS, VOR, ILS
IFR approach certified KLN-94 GPS
Mid Continent MD-200-306 CDI/Glideslope
Dynon D6 EFIS
TruTrak ADI
SL70 Transponder
Radios:
Audio Panel: PS Engineering Inc, PMA6000M-IRS
SL30 Nav/Com
ICOM A200
Antenna switchbox to permit use of bottom whip with ICOM handheld (3rd radio).
Dual axis TruTrak autopilot with automatic pitch trim.
Infinity stick grip with aileron and elevator trim on hat switch.
Dual USB ports.
Mountain High O2D2 Oxygen system.
Bose headsets front and back.
Fuel capacity: 53 gallons in normal leading edge (extended) wing tanks.
RV-7 Wing Tips
Tall main gear legs.
Andair gascolator in each wing root.
Custom built alternate air door.
Performance:
175 knot cruise on 8 gph or less.
Seattle to Oshkosh with one stop, each way.
Absolute ceiling: FL280. Yes… been there, May 29th, 2008. Normally aspirated.
Normal cruising altitudes are 11.5 or 12.5 but cruises nicely at FL210 too.
Aerobatic: absolutely… it’s an RV.
Construction:
Two part epoxy primer throughout.
Award for workmanship at Arlington, WA.
Attractive paint and upholstery.
Reason for sale: Medical. Asking $75K.
Questions? 253-230-8516
This email is free from viruses and malware because avast! Antivirus protection is active. [quote][b]
