bob88
Posted: Sat Jan 25, 2014 10:58 am Post subject: antenna question |
Which comm antenna choice have people found cost effective for belly mounting? Straight vs bent whip? The cheaper bare metal with ring connectors or more costly plastic with BNC connector?
n223rv(at)wolflakeairport Guest
Posted: Sat Jan 25, 2014 12:00 pm Post subject: antenna question |
Mines not cost effective, but I have 2 Comant bent whip antennas and they work great!!
| Quote: | On Jan 25, 2014, at 1:58 PM, "bob88" <marty.crooks(at)comcast.net> wrote:
http://forums.matronics.com/viewtopic.php?p=417578#417578
cooprv7(at)yahoo.com Guest
Posted: Sat Jan 25, 2014 12:21 pm Post subject: antenna question |
I used the cheap bent whip, http://www.aircraftspruce.com/pages/av/antenna_com/av534.php, and it works great. Just make sure you don’t tighten the nut on the ceramics too tight. After 7 years no issues with talking to tower on the ground even though it’s below the airplane, mine is located abeam the battery behind the baggage bulkhead.
Marcus
Posted: Sat Jan 25, 2014 12:33 pm Post subject: antenna question |
Electrically you would need a very sensitive antenna range to measure any
performance difference between the straight or bent whip. The bent whip
however provides practical advantage for mounting. Get one with the BNC
connector to mitigate ring connectors corroding over time - and the BNC
connector minimizes the "impedance bump" introduced with ring connectors.
Carl
Posted: Sat Jan 25, 2014 1:16 pm Post subject: antenna question |
I like the Rami bent whip for a good mount with BNC connector but cheaper than the Commant.
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
davidsoutpost(at)comcast. Guest
Posted: Sat Jan 25, 2014 1:42 pm Post subject: antenna question |
Deltapop Aviation. Great high quality antenna's at a very reasonable cost. http://www.deltapopaviation.com/Home.html
Sent: Saturday, January 25, 2014 1:58:59 PM
Subject: antenna question
--> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net>
rleffler
Posted: Sat Jan 25, 2014 2:47 pm Post subject: antenna question |
Take a look at Delta Pop Aviation. They make great antennas at a great price.
Bob
Sent from my iPad
| Quote: | On Jan 25, 2014, at 4:14 PM, Jesse Saint <jesse(at)saintaviation.com> wrote:
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
_________________ Bob Leffler
N410BL - Phase I
