rnewman(at)tcwtech.com Guest
Posted: Sun Jan 26, 2014 3:53 pm Post subject: I have a question regarding a Ray Allen Trim System for the |
Tal.
This is the trim servo, not an autopilot servo. Now if you go with an autopilot that supports auto-trimming, the autopilot system will connect into this servo. The trim servo is compatible with all major brands of autopilots
Bob Newman
N541RV
On Jan 26, 2014, at 6:38 PM, Tal Holloway <whodja(at)gmail.com> wrote:
I purchased a RV-10 tail kit and part of the pkg was a T3-12A-TS system. I'm just starting the kit and I'm not sure which AP I will eventually use. What AP is this system compatible with? Does it work with Garmin, AFS or Dynon? It's never been installed. Should I sell it and buy something different closer to avionics?
Tal Holloway
Posted: Sun Jan 26, 2014 6:06 pm Post subject: I have a question regarding a Ray Allen Trim System for the |
Bob mentioned our Safety-trim product, all the details are on our web site: www.tcwtech.com
On Jan 26, 2014, at 8:40 PM, "Bob Turner" <bobturner(at)alum.rpi.edu> wrote:
Hi Tal!
As the others have already posted, all of the available RV autopilots use a servo which drives the elevator directly, not the trim. I suspect the trim doesn't run fast enough in turbulence.
Different autopilots deal with trim differently. If you change airspeed, some units will simply indicate that you need to re-trim, manually. Others will drive the Ray Allen trim servos automatically (I know the Trio will do that, if ordered with "auto trim". I think the same is true for TruTrak).
This is a ways off, but you will find the trim speed about right at takeoff and landing speeds, but quite fast at cruise speeds. There is a box available ("safe-t-trim"??) which will automatically slow the trim speed as airspeed goes up; and at the same time will cut off trim if it runs more than 3 seconds, as a safety precaution against a runaway trim. An option to consider, when you get to the panel building.
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=417637#417637
rleffler
Posted: Sun Jan 26, 2014 7:36 pm Post subject: I have a question regarding a Ray Allen Trim System for the |
The same is true for Trutrak with the auto trim module.
I also recommend a module that controls trim spend like Safety-trim or the built in trim control in the VPX.
| Quote: | On Jan 26, 2014, at 8:40 PM, "Bob Turner" <bobturner(at)alum.rpi.edu> wrote:
Hi Tal!
Bob Turner
RV-10 QB
_________________ Bob Leffler
N410BL - Phase I
