Relocating the fuel filter
bob88
PostPosted: Mon Jan 27, 2014 10:11 pm    Post subject: Relocating the fuel filter Reply with quote
It looks to me that the Vans fuel filter in the tunnel will be beyond inconvenient when inspection time comes around. What about two fuel filters, one on each side, in a more convenient location such as under pilot/copilot seat or the wing attach area? Any major reasons NOT to do this?
rleffler
PostPosted: Tue Jan 28, 2014 2:21 am    Post subject: Relocating the fuel filter Reply with quote
I can't comment on any reasons to why not to relocate the fuel filter. It's not my area of expertise.
I can share with you that if you put an access panel on the side of the tunnel, taking the filter out isn't a big deal. I've taken mine out twice with out removing the top tunnel cover. Some folks have gone as far as putting an access panel on both sides.
David Ward sells a kit for this and in less than a half hour, you can have it installed. It's not rocket science, so it's also not that big of deal to fabricate your own parts too. It only takes me 5-10 minutes to remove the fuel filter.
Another key benefit is being able to inspect the forward part of the tunnel with out having to take everything apart. This is important for those of us that have center consoles install.
Bob
Sent from my iPad
http://forums.matronics.com/viewtopic.php?p=417743#417743
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
carl.froehlich(at)verizon
PostPosted: Tue Jan 28, 2014 3:55 am    Post subject: Relocating the fuel filter Reply with quote
Another way to look at this - the annual inspection requires the tunnel cover be removed anyway. Once the cover is removed pulling the fuel filter if mounted in the per-plan location is fairly easy.
I found that the tunnel cover itself needs to be shortened to allow more clearance with tubing and such on the forward end. The cover is shorten enough so that I don't use the most forward screws. This one thing makes the cover removal/install much easier.
Carl
Bob
Sent from my iPad
rleffler
PostPosted: Tue Jan 28, 2014 5:38 am    Post subject: Relocating the fuel filter Reply with quote
There are more than one way to skin a cat......
The access panels allow me to inspect everything forward of the fuel valve. I can easily remove the filter and pump through this opening.
I cut my cover at the fuel valve as to not require removing the forward cover unless something I find dictates it.
For those of use that have center consoles, this allows us the flexibility of leaving the stack in place during an inspection.
I then only have to remove the section aft of the cut.
On Jan 28, 2014, at 6:54 AM, Carl Froehlich <carl.froehlich(at)verizon.net> wrote:
Carl
Bob
Sent from my iPad
Bob Leffler
N410BL - Phase I
bcondrey
PostPosted: Tue Jan 28, 2014 6:21 am    Post subject: Relocating the fuel filter Reply with quote
Another consideration is that the stock location is downstream of the shutoff valve.  If the filters are upstream of the shutoff valve you'll have to deal with that also.
Bob
On Tue, Jan 28, 2014 at 8:37 AM, Bob Leffler <rv(at)thelefflers.com (rv(at)thelefflers.com)> wrote:
[quote]--> RV10-List message posted by: Bob Leffler <rv(at)thelefflers.com (rv(at)thelefflers.com)>
On Jan 28, 2014, at 6:54 AM, Carl Froehlich <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
--> RV10-List message posted by: Carl Froehlich <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)>
Carl
On Jan 28, 2014, at 5:19 AM, Bob Leffler <rv(at)thelefflers.com (rv(at)thelefflers.com)> wrote:
Bob
Sent from my iPad
> On Jan 28, 2014, at 1:11 AM, "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
> --> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)>
r to browse
nics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
href="http://forums.matronics.com/" target="_blank">http://forums.matronics.com
                   -Matt Dralle, List Admin.
Kellym
PostPosted: Tue Jan 28, 2014 6:38 am    Post subject: Relocating the fuel filter Reply with quote
Well, what does or doesn't need to be removed for the annual condition
inspection is dictated by what access panels exist to allow inspection
of components.
If a side panel access is installed, there is no reason that the tunnel
cover would ever need to be removed. Since I and a few others have Paul
Grimstead's Control Approach rudder pedal system, which puts the rudder
control arms through the tunnel cover, cover removal would involve
disassembly of a primary control system, something that should be
avoided for routine inspections. Thus a side panel access cover is
needed in my particular "modified" RV-10.
Keep in mind that what does or doesn't need to be inspected is
governed solely by Part 43 Appendix D, not some one's arbitrary annual
check list.
As to one filter or two, keep in mind that many type certified aircraft
do not have any filter between the tanks and the fuel servo inlet, and
if they do have one, it is often placed downstream of the boost pump,
rather than upstream as Van's has it. While filters could be put at the
wing roots, that means twice the work to service, and you would need to
be careful to locate well clear of the aileron pushrods travel.
Kelly
Kelly McMullen
KCHD
Tim Olson
PostPosted: Tue Jan 28, 2014 6:39 am    Post subject: Relocating the fuel filter Reply with quote
Also, any debris like o-rings and such that the valve throws off
will no longer be filtered. I came to the conclusion that
the filter was positioned in a decent place, and that after checking
it a few times and finding nothing, I was just going to stretch out
my inspection interval of that filter, and make it somewhat also
reliant on what I find in my regular sumpings of the tanks.
The access panel is about all I'd bother doing to improve things.
Bob
<carl.froehlich(at)verizon.net <mailto:carl.froehlich(at)verizon.net>> wrote:
Carl
> Bob
> Sent from my iPad
<mailto:marty.crooks(at)comcast.net>> wrote:
<marty.crooks(at)comcast.net <mailto:marty.crooks(at)comcast.net>>
r to browse
flying-nut(at)cfl.rr.com
PostPosted: Tue Jan 28, 2014 7:16 am    Post subject: Relocating the fuel filter Reply with quote
of components.
tunnel cover would ever need to be removed. Since I and a few others
have Paul Grimstead's Control Approach rudder pedal system, which puts
the rudder control arms through the tunnel cover, cover removal would
involve disassembly of a primary control system, something that should
be avoided for routine inspections. Thus a side panel access cover is
I modified the rudder pedals to go through the side of the tunnel
instead of through the cover. I also have a console from the tunnel
cover up to the bottom of the instrument panel that will have to be
removed so the side access panel is a really good mod .... that I'll do.
check list.
I'd use the word 'guided' rather than 'governed' unless things have
changed since I built my Pitts years ago. You can't go wrong using Part
43 liberally in our homebuilts.
aircraft do not have any filter between the tanks and the fuel servo
inlet, and if they do have one, it is often placed downstream of the
boost pump, rather than upstream as Van's has it. While filters could
be put at the wing roots, that means twice the work to service, and
you would need to be careful to locate well clear of the aileron
pushrods travel.
The Vans filter fits nicely under the seats ...... between the tunnel
and the fuselage side. I still might do that instead of the access panel.
Linn
Kelly
Checked by AVG - www.avg.com
Kellym
PostPosted: Tue Jan 28, 2014 7:22 am    Post subject: Relocating the fuel filter Reply with quote
Well, your Pitts probably had older operating limits language than what
is standard today. While a plane today could have different language, my
understanding of the standard ops limits requires you to use Part 43
Appendix D as a "minimum" checklist, same as it is for type certified
aircraft. You can do a more thorough, more detailed checklist, but not
less than Appendix D. One of the few sections of Part 43 that applies to
amateur built aircraft.
> annual check list.
Part 43 liberally in our homebuilts.
Kelly McMullen
KCHD
PostPosted: Tue Jan 28, 2014 9:50 am    Post subject: Relocating the fuel filter Reply with quote
Thanks Kelly. It's taken me 35 years to get back to building ...... I
have a lot of catching up to do!!!
Linn
what is standard today. While a plane today could have different
language, my understanding of the standard ops limits requires you to
use Part 43 Appendix D as a "minimum" checklist, same as it is for
type certified aircraft. You can do a more thorough, more detailed
checklist, but not less than Appendix D. One of the few sections of
Part 43 that applies to amateur built aircraft.
>> annual check list.
