Joined: 28 Mar 2008 Posts: 1972 Location: Riley TWP Michigan
Posted: Wed Feb 05, 2014 9:43 am Post subject: Electrical architecture with aux battery |
Attached is a circuit with a brownout battery (non cranking). It will be kept charged through a diode when the E-Bus alternate feed is off. The aux battery will be connected in parallel with the main battery when both aux battery switch and the E-Bus switch are turned on (expected normal operation after engine start). This circuit is not for my plane. I offer it for discussion and comments.
Joe
 Download |
| Filename: |
Z-11 Modified 2.pdf |
85.58 KB |
| Downloaded: |
464 Time(s) |
_________________ Joe Gores |
Posted: Wed Feb 05, 2014 12:49 pm Post subject: Electrical architecture with aux battery |
At 11:43 AM 2/5/2014, you wrote:
There is a way to avoid charging the aux
battery through a diode and eliminate one
switch.
http://tinyurl.com/7ro5yuc
Posted: Wed Feb 05, 2014 2:44 pm Post subject: Re: Electrical architecture with aux battery |
When the alternator is off or has failed, the extra switch in my circuit would allow powering the E-bus by only one battery at a time. I do not know if that is an advantage or not. The more complicated a system is, the greater the chance for pilot error.
Joe
