Bill R
Posted: Fri Mar 14, 2014 11:43 am Post subject: corvair engine serial numbers |
Guys
I found three engines for sale, the serial numbers are as follows:
To702ZH
To205YR
To605RB
Can anyone tell me if any of these will work for a WW conversion?
Bill
| | - The Matronics CorvairEngines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?CorvairEngines-List |
jcochran16(at)gmail.com Guest
Posted: Sat Mar 15, 2014 7:24 am Post subject: corvair engine serial numbers |
A quick search of the internet for "corvair case numbers" yields the following copied from the Clark's Corvair catalog:
http://www.angelfire.com/ca4/CorvAIRCRAFT/VinSuffix.html
ZH 60-63 84hp Power glide
YR 64 Turbocharged Corsa
RB 65-68 140hp manual
The conversion manual gives a list of preferred cases for conversion. My manual is at the hanger, but I think the preferred case and heads is a version of the 110hp. Correct heads with the case is probably more important. Also there is no guaranty that the original heads are on these cases. There is also a list of acceptable heads. If no one else responses with better data, I will retrieve my manual and send better info.
Jeff C.
Bill R
Posted: Sat Mar 15, 2014 11:36 am Post subject: Re: corvair engine serial numbers |
Hi Jeff
Thanks for the info. Just bought a 110.
Hope it's good.
