Fuel shut off valve
CDBenham
PostPosted: Wed May 07, 2014 7:17 am    Post subject: Fuel shut off valve Reply with quote
Fuel shut off valve does not completely stop the flow of fuel on my Yak55M. When I took it apart there was a loose spring (not attached to anything) in the housing. Looks like it is there to spring load the flapper valve but not sure how it says in place. The flapper seal looks like it needs to be replaced. Anyone have any experience servicing this valve.
Charles
 Filesize:  90.8 KB
 Viewed:  2258 Time(s)
 Filesize:  30.28 KB
