kelmonroe(at)comcast.net Guest
Posted: Tue May 27, 2014 6:21 pm Post subject: Housai 285 hp oil leak |
I have a Housai 285 hp that appears to be leaking oil from the nose case front seals or the gasket. Has anyone else had this problem. Thanks Kelley
Pete Fowler
Posted: Thu Jun 05, 2014 6:35 am Post subject: Re: Housai 285 hp oil leak |
Check the rubber sump seal. When that leaks, oil is sprayed in a spiral pattern all over the nose case and will make it appear the case is leaking. That might be your problem as it's a pretty common thing for that sump seal to leak.
keithmckinley
Posted: Mon Jun 09, 2014 11:09 am Post subject: Re: Housai 285 hp oil leak |
Pete makes a good point.
It's tough to chase those leaks down. I had leak that drove me nuts and turned out to be from a pinched o-ring on a rocker cover. It was very hard to see.
jblake207(at)comcast.net Guest
Posted: Mon Jun 09, 2014 1:21 pm Post subject: Housai 285 hp oil leak |
A method I use to find the source of an oil leak is to clean the motor really good with some sort of detergent like Dawn dishwashing liquid, etc... this doesn't leave any residue like mineral spirits and leaves the engine very dry after the wash. Then dist the whole engine with baby powder then run the engine on the ground for 10 minutes or so. Your oil leaks will normally be very evident. Having said that, on these round motors, I stopped chasing the little leaks long ago. JB
To: "Yak-List" <yak-list(at)matronics.com>
Sent: Monday, June 9, 2014 2:09:06 PM
Subject: Re: Housai 285 hp oil leak
--> Yak-List message posted by: "keithmckinley" <cetopfed(at)gmail.com>
Keith McKinley
700HS
X26 Sebastian, FL
http://forums.matronics.com/viewtopic.php?p=424560#424560
; -Mat===============
Viperdoc
Posted: Mon Jun 09, 2014 2:10 pm Post subject: Housai 285 hp oil leak |
Yep, Bike Clean sprayed on the cowling, wing roots, and fuselage wipes the evidence of the pesky leaks right away after the day of flying. You sleep better knowing you have a nice clean airplane to get oily the flying session. Unless it is pouring oil out on the hanger floor or you are down 2-3 liters after a 1 hour flight I'm not worrying with it. As long as your hoses are not old and worn out not worth the trouble chasing a piss ant leak. You'll fly less and die with a tight anal sphincter.
Doc
On Jun 9, 2014, at 4:19 PM, jblake207(at)comcast.net (jblake207(at)comcast.net) wrote:
Quote: | A method I use to find the source of an oil leak is to clean the motor really good with some sort of detergent like Dawn dishwashing liquid, etc... this doesn't leave any residue like mineral spirits and leaves the engine very dry after the wash. Then dist the whole engine with baby powder then run the engine on the ground for 10 minutes or so. Your oil leaks will normally be very evident. Having said that, on these round motors, I stopped chasing the little leaks long ago. JB
From: "keithmckinley" <cetopfed(at)gmail.com (cetopfed(at)gmail.com)>
To: "Yak-List" <yak-list(at)matronics.com (yak-list(at)matronics.com)>
--> Yak-List message posted by: "keithmckinley" <cetopfed(at)gmail.com (cetopfed(at)gmail.com)>
Keith McKinley
700HS
X26 Sebastian, FL
Quote: |
ist"">http://www.matronics.com/Navigator?Yak-List
_________________ Viperdoc |
keithmckinley
Posted: Sat Jun 14, 2014 3:20 pm Post subject: Re: Housai 285 hp oil leak |
Doc you crack me up!!!! I'm sure you've examined your share of sphincters!!
Viperdoc
Posted: Sat Jun 14, 2014 8:09 pm Post subject: Housai 285 hp oil leak |
Enough to last a lifetime!
Doc
Quote: | On Jun 14, 2014, at 6:20 PM, keithmckinley <cetopfed(at)gmail.com> wrote:
Keith McKinley
700HS
X26 Sebastian, FL
http://forums.matronics.com/viewtopic.php?p=424840#424840
