stearman456
Posted: Mon Jun 02, 2014 9:26 am Post subject: Bonding Straps |
In a mixed construction airplane (steel tube fuselage, wooden wings, aluminum structure flight controls, everything fabric covered) what would the down side be in not having everything electrically bonded? My electrical system is a two wire, 14v system with everything running to a "forest of tabs" ground bus on the firewall. The avionics (SL40 com, GTX 327 txdr) run to their own, dedicated ground bus which in turn is wired to the firewall ground bus. I'm doing the bonding per the original design, but I'm just curious. Would all the various assemblies of the airplane create static charges that would cripple the radios?
Dan
Posted: Tue Jun 03, 2014 7:07 am Post subject: Bonding Straps |
At 12:26 PM 6/2/2014, you wrote:
Dan
Bonding for static control, grounding for power distribution
and grounding for antenna performance are largely separate
issues.
P-static is not an issue for low speed aircraft cruising
in the lower atmospheres. Sounds like you've got the
lights lit up so the only thing left is to provide
adequate ground planes under antennas. But in no case
is there value in tying every 'grounded' device to
all other grounded devices.
stearman456
Posted: Tue Jun 03, 2014 7:52 am Post subject: Re: Bonding Straps |
Thanks Bob. Would there be any value in tying the avionics ground bus directly to the battery instead of to the main ground bus? (Putting the two ground buses in parallel instead of in series).
Posted: Tue Jun 03, 2014 11:05 am Post subject: Bonding Straps |
At 10:52 AM 6/3/2014, you wrote:
No . . . and especially not the battery(-) post.
The battery is but one of many components that
benefit by sharing a centralized ground but its
(-) terminal point should not be that
centralize ground location.
If you have a panel ground for potential vicitims
that is in turn tied ot the central ground on the
fire wall, you're good to go.
stearman456
Posted: Tue Jun 03, 2014 12:24 pm Post subject: Bonding Straps |
Ok - thanks. That was the way I understood it.
