dlm34077(at)gmail.com Guest
Posted: Sun Jun 08, 2014 3:50 am Post subject: RV10-List Digest: 1 Msgs - 06/07/14 |
Need more info. Is the problem the height of the vertical or the width of
the gear legs? IIRC we lowered the tire pressure and as the mains cleared we
lowered the vertical to clear by slightly raising the nose. If the problem
is gear width perhaps removing the wheel pant extensions and possibly the
some of the boards attached to the vertical door frame. Eight foot 2 in
seems about right for the standard garage door height. We maneuvered the
fuselage with vertical and engine easily out the standard height door.
Another possibility is the hydraulic crane from harbor freight. We used it
to mount the engine and to lift the nose as the airframe was removed from
the garage down a sloped driveway.
