bob88
Posted: Mon Jun 09, 2014 8:52 pm Post subject: Rear window installation |
I'm noticing quite a deep flange on the front edge of the rear window (left side) where I had to build up the cabin cover to fit the door. The choice is to shim it (with washers per Vans) or lay in a layer or two of glass on the flange before installing the window. The excess depth is about 3/16" (about a three washer stack would be needed). Suggestions? Better ideas? Go with the washers and hope to fill the channel with adhesive? I plan to use the Lord adhesive.
rleffler
Posted: Tue Jun 10, 2014 1:43 am Post subject: Rear window installation |
I shimmed mine with small pieces of cured fiberglass. I only had one place that needed shimming. Either method should work.
Sent from my iPad
| Quote: | On Jun 10, 2014, at 12:52 AM, "bob88" <marty.crooks(at)comcast.net> wrote:
http://forums.matronics.com/viewtopic.php?p=424600#424600
_________________ Bob Leffler
N410BL - Phase I
