Ed Godfrey
Posted: Wed Jun 18, 2014 4:32 pm Post subject: Looking for a source of 2024 |
Does anyone know of a source of some 2024 T3 .032 aluminum angle?
It is called to be used for the Instrument Panel Support Angle, both
inboard and outboard, as described in Figure 1 on page 41-5. I have
looked around and cannot find anyone who has it smaller than .063. I
would really appreciate any leads.
Ed Godfrey
40717
Posted: Wed Jun 18, 2014 4:40 pm Post subject: Looking for a source of 2024 |
I always just use .063".
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
Sent from my iPad
| Quote: | On Jun 18, 2014, at 8:32 PM, Ed Godfrey <egodfrey(at)ameritech.net> wrote:
Does anyone know of a source of some 2024 T3 .032 aluminum angle? It is called to be used for the Instrument Panel Support Angle, both inboard and outboard, as described in Figure 1 on page 41-5. I have looked around and cannot find anyone who has it smaller than .063. I would really appreciate any leads.
Ed Godfrey
40717
bcondrey
Posted: Wed Jun 18, 2014 5:11 pm Post subject: Looking for a source of 2024 |
It's not the extruded material like the .063, it's bent .032 sheet to make 3/4 angle. Avail from Van's.
Bob
On Wednesday, June 18, 2014, Ed Godfrey <egodfrey(at)ameritech.net (egodfrey(at)ameritech.net)> wrote:
[quote]--> RV10-List message posted by: Ed Godfrey <egodfrey(at)ameritech.net>
Ed Godfrey
40717
" target="_blank">http://www.matronics.com/Navigator?RV10-List
MS -
e -
-Matt Dralle, List Admin.
Ed Godfrey
Posted: Wed Jun 18, 2014 6:31 pm Post subject: Looking for a source of 2024 |
Jesse,
I have some .063 purchased from Aircraft Spruce, but I am having
issues with getting it to work on the inboard angle. I am trying to use
the angle between the F1044 and the panel, but there doesn't seem to be
the room for it. I spoke with Ken at Van's yesterday about notching out
the part that would contact the aft portion of the F1044, the short
surface with the nut plate, but he did not agree that notching it out
would be a viable idea.
Ed Godfrey
40717
On 6/18/2014 7:40 PM, Jesse Saint wrote:
Jesse Saint
352-427-0285
Sent from my iPad
> Ed Godfrey
> 40717
Ed Godfrey
Posted: Wed Jun 18, 2014 6:33 pm Post subject: Looking for a source of 2024 |
Bob,
Thanks for the info. That might work for the space between the F1044 and the panel surface.
Ed Godfrey
40717
On 6/18/2014 8:10 PM, Bob Condrey wrote:
[quote]It's not the extruded material like the .063, it's bent .032 sheet to make 3/4 angle. Avail from Van's.
Bob
| Quote: | --> RV10-List message posted by: Ed Godfrey <egodfrey(at)ameritech.net>
Ed Godfrey
40717
MS -
e -
| [b]
philperry9
Posted: Wed Jun 18, 2014 6:49 pm Post subject: Looking for a source of 2024 |
I notched mine recently. I had no choice but to rebuild the rib because of interference with the panel.
I went ahead and reenforced the webbing of the rib with .063. Then I added a piece of 3/4 angle to rebuild the flange that I removed. I'm confident that is stronger than the original design and I don't think it will collapse over time, but only time will tell.
If I had photos I'd share them, but the plane is in the hangar (3.5 hours away) and I'm in the recliner.
Phil
On Wed, Jun 18, 2014 at 9:32 PM, Ed Godfrey <egodfrey(at)ameritech.net (egodfrey(at)ameritech.net)> wrote:
[quote] Bob,
Ed Godfrey
40717
| Quote: | It's not the extruded material like the .063, it's bent .032 sheet to make 3/4 angle. Avail from Van's.
Bob
Ed Godfrey
40717
MS -
e -
Gordon Anderson
Posted: Wed Jun 18, 2014 10:03 pm Post subject: Looking for a source of 2024 |
I used some of the stringer profile left over from the tail and wing kits. The J can be arranged so as not to interfere with the cutouts, or cut off with a bandsaw.
Sent from my iPad
On 19.06.2014, at 03:10, Bob Condrey <condreyb(at)gmail.com (condreyb(at)gmail.com)> wrote:
Bob
Ed Godfrey
40717
MS -
e -
Posted: Thu Jun 19, 2014 4:11 am Post subject: Looking for a source of 2024 |
I'm not sure I understand what you're trying to do.
Jesse Saint
352-427-0285
Sent from my iPad
| Quote: | On Jun 18, 2014, at 10:30 PM, Ed Godfrey <egodfrey(at)ameritech.net> wrote:
Jesse,
I have some .063 purchased from Aircraft Spruce, but I am having issues with getting it to work on the inboard angle. I am trying to use the angle between the F1044 and the panel, but there doesn't seem to be the room for it. I spoke with Ken at Van's yesterday about notching out the part that would contact the aft portion of the F1044, the short surface with the nut plate, but he did not agree that notching it out would be a viable idea.
Ed Godfrey
40717
> Jesse Saint
> 352-427-0285
> Sent from my iPad
>> Ed Godfrey
>> 40717
rv10pro(at)gmail.com Guest
Posted: Thu Jun 19, 2014 8:18 am Post subject: Looking for a source of 2024 |
What Dimension do you need?
John Cox - 40600
On Thu, Jun 19, 2014 at 5:10 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
[quote]--> RV10-List message posted by: Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)>
Jesse Saint
[url=tel:352-427-0285]352-427-0285[/url]
Sent from my iPad
> On Jun 18, 2014, at 10:30 PM, Ed Godfrey <egodfrey(at)ameritech.net (egodfrey(at)ameritech.net)> wrote:
> --> RV10-List message posted by: Ed Godfrey <egodfrey(at)ameritech.net (egodfrey(at)ameritech.net)>
| Quote: | Jesse,
| Quote: | Ed Godfrey
> 40717
>> Jesse Saint
| Quote: | > Sent from my iPad
>>> On Jun 18, 2014, at 8:32 PM, Ed Godfrey <egodfrey(at)ameritech.net (egodfrey(at)ameritech.net)> wrote:
>>> Ed Godfrey
>>> 40717
MS -
e -
