riddon(at)sent.com Guest
Posted: Fri Aug 01, 2014 4:52 am Post subject: Tailplane transport |
I am refurbing my open trailer. For the tailplanes, I originally made a plywood box on the trailer for them both to fit in. I wondered if anyone had a better solution for transporting them?
Richard Iddon.
G-RIXS
kheindl(at)msn.com Guest
Posted: Fri Aug 01, 2014 5:32 am Post subject: Tailplane transport |
Yes, put them on the backseat of your car.
| Quote: | From: riddon(at)sent.com
Subject: Tailplane transport
Date: Fri, 1 Aug 2014 13:52:08 +0100
--> Europa-List message posted by: Richard Iddon <riddon(at)sent.com>
Richard Iddon.
G-RIXS
richard collings
Joined: 08 Jul 2011 Posts: 73 Location: warwickshire england
Posted: Fri Aug 01, 2014 6:10 am Post subject: Tailplane transport |
Hi Richard
My trailer has 2 vertically mounted dummy torque tubes over which each tail plane slide, at the base are stepped block to take the weight and stop them twisting. they are very simple and work well.I also have 2 pieces of plastic tube which I slide over the dummy tubes to keep them clean when the aircraft is assembled and over the exposed torque tube when the tail planes are off.
Hope that helps
Richard
Sent: Friday, August 1, 2014 2:31 PM
Subject: RE: Tailplane transport
| Quote: | Subject: Tailplane transport
Richard Iddon.
G-RIXS
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Posted: Fri Aug 01, 2014 7:23 am Post subject: Tailplane transport |
Hi Richard,
I had exactly the same arrangement on my factory trailer. After a long trip over rough roads both TP5 sleeves had disbonded.
Karl
Subject: Re: Tailplane transport
Date: Fri, 1 Aug 2014 15:09:13 +0100
Hi Richard
Hope that helps
Richard
Richard Iddon.
G-RIXS
target="_blank">http://www.matronics.com/Navigator?Europa-List
budyerly(at)msn.com Guest
Posted: Fri Aug 01, 2014 8:55 am Post subject: Tailplane transport |
Richard,
I prefer a box with soft foam padding on the bottom and 1/2 inch foam on the sides. It is important not to put any load on the TP16 trim tab pins. For our enclosed trailers we have done this.
Posts can be problematic if not built precise. Small trailers on rough roads means if there is any play it will impose shock loads. This may cause eventual bearing failure.
Personally, I put them in the back seat or padded and strapped in my truck bed. I sleep better that way.
Bud Yerly
Sent from my Verizon Wireless 4G LTE DROID
Richard Iddon.
G-RIXS
; - The Europa-List Email Forum -
r?Europa-List">http://www.matronics.com/Navigator?Europa-List
; - MATRONICS WEB FORUMS -
; - List Contribution Web Site -
; -Matt Dralle, List Admin.
tion">http://www.matronics.com/contribution
Posted: Fri Aug 01, 2014 9:34 am Post subject: Tailplane transport |
Richard, my trailer has a nice solution built by Roger
Targett. I will take some pix in next 2/7 to send you.
Regards, David
On Fri, 1 Aug 2014 13:52:08 +0100
Richard Iddon.
G-RIXS
Un/Subscription,
Forums!
Admin.
Jim Kelly
Posted: Fri Aug 01, 2014 9:46 am Post subject: Tailplane transport |
Hi David,         I'm also very interested in any trailer mods.
Jim Kelly
G-BWEG
On Friday, August 1, 2014, David Joyce <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)> wrote:
[quote]--> Europa-List message posted by: "David Joyce" <davidjoyce(at)doctors.org.uk>
Richard, my trailer has a nice solution built by Roger Targett. I will take some pix in next 2/7 to send you. Regards, David
| Quote: | --> Europa-List message posted by: Richard Iddon <riddon(at)sent.com>
Richard Iddon.
G-RIXS
Un/Subscription,
Forums!
Admin.
st" target="_blank">http://www.matronics.com/Navigator?Europa-List
MS -
k">http://forums.matronics.com
e -
t="_blank">http://www.matronics.com/contribution
_________________ Jim GBWEG |
stranfaer(at)btinternet.c Guest
Posted: Fri Aug 01, 2014 12:13 pm Post subject: Tailplane transport |
Yep back of vehicle wrapped in foam
Rgds the other one
On 1 Aug 2014, at 14:31, Karl Heindl <kheindl(at)msn.com (kheindl(at)msn.com)> wrote:
[quote] Yes, put them on the backseat of your car.
