Fuel senders
bob88
PostPosted: Mon Aug 18, 2014 6:22 pm    Post subject: Fuel senders Reply with quote
Are the Van's fuel float senders inferior to capacitative (sp?) senders? Are there problems with installation of the capacitative units (I have QB wings)?
Bob Turner
PostPosted: Mon Aug 18, 2014 7:49 pm    Post subject: Re: Fuel senders Reply with quote
Capacitive senders are more accurate than floats. But, when calibrated thru an EFIS (I have GRT) the floats are surprisingly accurate, except that they cannot see the top 5 gallons. But on top of that nearly eveyone puts in a fuel flow transducer, and their accuracy is amazing. My advice is to just put in the floats, and spend your money somewhere else.
Bob Turner
RV-10 QB
bill.peyton
PostPosted: Tue Aug 19, 2014 4:01 am    Post subject: Re: Fuel senders Reply with quote
I agree with Bob. The float type fuel senders are pretty accurate if you spend some quality time calibrating them with your EFIS. Coupled with the fuel flow sending unit you usually know within a couple of tenths of a gallon, your fuel consumption
Bill
WA0SYV
Aviation Partners, LLC
Lenny Iszak
PostPosted: Tue Aug 19, 2014 8:15 am    Post subject: Re: Fuel senders Reply with quote
Capacitive fuel senders are only worthwhile if you build your own tanks.
If you install them in QB tanks they won't see the top 5 gallons, just like the floats, because of the wing dihedral.
Tim Olson
PostPosted: Tue Aug 19, 2014 8:39 am    Post subject: Fuel senders Reply with quote
I find the floats plenty accurate after calibration to the EFIS anyway, and really don't much miss the top few gallons of reading, because where I really care about it is when it's under 1/2. With the totalizer on board, the floats are more a 2nd reference anyway. The totalizer is very precise when I top off the tanks.
On Aug 19, 2014, at 11:15 AM, "Lenny Iszak" <lenard(at)rapiddecision.com> wrote:
http://forums.matronics.com/viewtopic.php?p=428757#428757
schmoboy
PostPosted: Tue Aug 19, 2014 9:30 am    Post subject: Fuel senders Reply with quote
I kind of refer to the floats as a backup to the totalizer also. I
visually inspect and stick the tanks as part of preflight.
One thing that annoys me during flight when maneuvering is that the
floats will obviously be incorrect for a given period of time. This is
acceptable because I know that it will happen. The issue for me is that
my AFS EFIS will audible and visual warn me that the float readings
don't match the totalizer. I've thought about disabling that feature,
but I really like the reminder while on the ground after fill-up as a
trigger to reset the totalizer for full mains. Have others turned off
the float/totalizer mismatch warning?
-Sean #40303 (phase one complete, dreading more fiberglass work to
finish pants on mains)
Tim Olson <mailto:Tim(at)MyRV10.com>
August 19, 2014 at 11:38 AM
saylor.dave(at)gmail.com
PostPosted: Tue Aug 19, 2014 9:58 am    Post subject: Fuel senders Reply with quote
I adjusted the warning on mine for a pretty large difference, like maybe 15 gallons.  Still warns if I don't reset it, and less spam.
"The system will give the audible warning “Check Fuel Computer” on startup if the fuel computer’s gallons remaining value
does not match the fuel tanks level. This feature (if turned on in Instrument Calibration) should warn you if you have added
fuel and forget to adjust the fuel computer. The number of gallons that will generate an error is adjusted in Instrument
Calibrate. Since the fuel levels are NOT accurate when the tanks are near full this value is doubled when the tanks show
full".
That way I don't have to be reminded about my uncoordinated turns Wink
--Dave
On Tue, Aug 19, 2014 at 10:28 AM, Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)> wrote:
[quote]--> RV10-List message posted by: Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)>
I kind of refer to the floats as a backup to the totalizer also.  I visually inspect and stick the tanks as part of preflight.
One thing that annoys me during flight when maneuvering is that the floats will obviously be incorrect for a given period of time.  This is acceptable because I know that it will happen.  The issue for me is that my AFS EFIS will audible and visual warn me that the float readings don't match the totalizer.  I've thought about disabling that feature, but I really like the reminder while on the ground after fill-up as a trigger to reset the totalizer for full mains.  Have others turned off the float/totalizer mismatch warning?
-Sean #40303 (phase one complete, dreading more fiberglass work to finish pants on mains)
Tim Olson <mailto:Tim(at)MyRV10.com (Tim(at)MyRV10.com)>
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
FORUMS -
b Site -
          -Matt Dralle, List Admin.
schmoboy
PostPosted: Tue Aug 19, 2014 10:17 am    Post subject: Fuel senders Reply with quote
Ya. Think I have mine set at 10 gallon difference right now. Maybe
just increasing that will give me enough spread to reduce the warnings.
Working on IFR approaches now and that damn warning causes undesired eye
movement and interruptions after my uncoordinated turns. Smile
-Sean
David Saylor <mailto:saylor.dave(at)gmail.com>
August 19, 2014 at 12:57 PM
fuel and forget to adjust the fuel computer.*The number of gallons
that will generate an error is adjusted in Instrument *
*Calibrate*. Since the fuel levels are NOT accurate when the tanks are
full".
--Dave
PostPosted: Tue Aug 19, 2014 11:06 am    Post subject: Fuel senders Reply with quote
Off topic but I found auto trim (TruTrak) to be a big help during approaches.  It wasn't really the trim forces that bothered me as they aren't that big, it was the annunciator on the AP that I found distracting.  Any yeah, getting all those little annoying things cleaned up help a lot not just with approaches but with general enjoyment of the plane.
On Tue, Aug 19, 2014 at 11:16 AM, Sean Stephens <sean(at)stephensville.com (sean(at)stephensville.com)> wrote:
Ya.  Think I have mine set at 10 gallon difference right now.  Maybe just increasing that will give me enough spread to reduce the warnings.
Working on IFR approaches now and that damn warning causes undesired eye movement and interruptions after my uncoordinated turns. Smile
-Sean
David Saylor <mailto:saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)>
fuel and forget to adjust the fuel computer.*The number of gallons that will generate an error is adjusted in Instrument *
*Calibrate*. Since the fuel levels are NOT accurate when the tanks are near full this value is doubled when the tanks show
full".
--Dave
FORUMS -
b Site -
bwestfall
PostPosted: Wed Aug 20, 2014 10:56 am    Post subject: Fuel senders Reply with quote
My next question would be does the D-180 recognize a fuel imbalance any other time than startup?  I think the decision to alert based on real-time changes is to identify the rare event of a tank issue in flight.
-Ben
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman
Sent: Wednesday, August 20, 2014 10:39 AM
To: rv10-list
Subject: Re: Re: Fuel senders
Weird they implemented it that way. My old Dynons alert you if the fuel tank level changed since the EFIS was powered off.
"The fuel computer can be programmed in EMS > SETUP > FUEL > ADD THRESHOLD to automatically detect the
addition of fuel while the unit is turned off. When this is configured, the next time you turn the FlightDEK-D180 on, it
asks you if you added fuel and gives you a shortcut to the add fuel menu."
-Sean
full".
--Dave
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
PostPosted: Wed Aug 20, 2014 11:57 am    Post subject: Fuel senders Reply with quote
My guess--pure speculation--would be either that 1), AFS wanted a little more distance--no shortcuts--between the gauges and the totalizer, or 2), they didn't think of that.
--Dave
On Wed, Aug 20, 2014 at 10:38 AM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
[quote]Weird they implemented it that way.  My old Dynons alert you if the fuel tank level changed since the EFIS was powered off.
-Sean
full".
--Dave
FORUMS -
b Site -
Rob Kochman
Woodinville, WA
