intercom noise (was radio noise)
uuccio(at)gmail.com
PostPosted: Fri Aug 22, 2014 8:39 am    Post subject: intercom noise (was radio noise) Reply with quote
When my (Rotax 912) engine goes over 3800 RPM it breaks the squelch on the
radio, the radio goes in RX mode and I hear a bunch of white noise, which
for all intents and purposes makes receiving transmissions very difficult.
I have been through several iterations of this problem (see previous posts,
involving a noisy Autopilot on the 130Mhz which is our local frequency) but
yesterday I realized that if I turn the intercom off the problem disappears
(the radio doesn't go into RX mode).
So it appears that there is some kind of noise source which makes its way
into the Intercom (it's a GMA 240). What steps can I take to get rid of
this problem? I have already shielded the magneto wires.
sacha
uuccio(at)gmail.com
PostPosted: Fri Aug 22, 2014 8:53 am    Post subject: intercom noise (was radio noise) Reply with quote
When I say "white noise" I mean interference noise that seems related to
engine RPM.
saylor.dave(at)gmail.com
PostPosted: Fri Aug 22, 2014 9:08 am    Post subject: intercom noise (was radio noise) Reply with quote
I'm not associated with any avionics manufacturer, but I know from experience with several Garmin audio panels that they just don't reject noise as well as PS Eng audio panels.  In several cases, changing to a PS got rid of whines, buzzes, static, etc. that extra shielding and ground loop witch hunts just didn't fix.  What you're hearing may just not be resolvable with a Garmin.  I really like a lot of their other products, but the audio panels aren't as good.
--Dave
On Fri, Aug 22, 2014 at 9:37 AM, Sacha <uuccio(at)gmail.com (uuccio(at)gmail.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Sacha" <uuccio(at)gmail.com (uuccio(at)gmail.com)>
sacha
Electric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
PostPosted: Sat Aug 23, 2014 4:19 am    Post subject: Re: intercom noise (was radio noise) Reply with quote
Breaking the radio squelch would not make it more difficult to hear incoming radio transmissions. The symptoms that you describe are from breaking the intercom squelch. The white noise is cockpit noise. As the engine RPM increases, the cockpit noise increases until it reaches a point where the intercom squelch is broken. Try adjusting the intercom squelch at cruise RPM using the large knobs, left knob for pilot and right knob for copilot.
Joe
Joe Gores
uuccio(at)gmail.com
PostPosted: Sat Aug 23, 2014 5:55 am    Post subject: intercom noise (was radio noise) Reply with quote
Hi Joe,
Thanks for your suggestion. What you say makes perfect sense. I tried
turning up the pilot intercom squelch before but I may have inadvertently
left the copilot squelch low and the copilot headset connected. I'll check
that next time I'm in the plane.
Sacha
uuccio(at)gmail.com
PostPosted: Thu Aug 28, 2014 12:56 pm    Post subject: intercom noise (was radio noise) Reply with quote
Joe,
I can confirm that you hit the nail on the head. Yesterday and today I
unplugged the copilot headset and the intercom squelch problem went away.
Thank you again!
Sacha
PostPosted: Thu Aug 28, 2014 2:10 pm    Post subject: Re: intercom noise (was radio noise) Reply with quote
You are welcome, Sacha.
Joe
Joe Gores
