rj_todd(at)yahoo.co.uk Guest
Posted: Thu May 09, 2013 12:43 am Post subject: Aero Composites |
Guys,
I heard a rumour that Aero Composites (the propeller manufacturer) is no longer trading. Can anyone please deny or confirm this? If true this is very bad news.
Best wishes to all,
Rodger
chazking
Posted: Fri May 10, 2013 3:55 am Post subject: Aero Composites II |
Confirmed.
AeroComposites sold their IP to MacCauley & the firm is consulting to MacCauley on their development of composite prop offerings.
Whirlwind propellers uses Maccauley components & will provide "custom" support. http://www.whirlwindaviation.com/index.asp
I had them (Bill) re-hub an AeroComposite prop (3300) & it's now installed on my 10. It's now "considered" a Whirlwind prop & is supported. Bill was very complementary of the blades. And, I picked-up 2 kts in pre & post speed tests. I was amazed so I ran the post speed test 15x.
Chäz
Posted: Fri May 10, 2013 4:57 am Post subject: Aero Composites |
Chaz,
Thanks very much for the info; looks like all is not lost!
Rodger
--- On Fri, 10/5/13, chazking <airplane-lists(at)hotmail.com> wrote:
Subject: Re: Aero Composites
Date: Friday, 10 May, 2013, 13:56
--> RV10-List message posted by: "chazking" <airplane-lists(at)hotmail.com (airplane-lists(at)hotmail.com)>
Confirmed.
Chäz
http://forums.matronics.com/viewtopic.php?p=40atronics.com/Navigator?RV10-List" target=_blank>http://www.matronics.com/= - MATRONICS href="http://forums.matronics.com/" target=_blank>http://forums.matronbsp; - List Contribution Web Site -http://www=======================
| [quote][b]
robin(at)PaintTheWeb.com Guest
Posted: Fri May 10, 2013 7:14 am Post subject: Aero Composites |
Chaz,
You picked up 2 knots over what prior prop?
Robin
chazking
Posted: Fri May 10, 2013 5:08 pm Post subject: Re: Aero Composites |
Hartzell PROP C2YR-1BFP/F8068D - Std Vans for IO 540
chazking
Posted: Fri May 10, 2013 5:28 pm Post subject: Re: Aero Composites |
More info: Two to Three blade... 2 blade - 52 # according to Hartzell tech support. 3 blade - 50# - AeroComposite web site.
chazking
Posted: Fri May 10, 2013 5:31 pm Post subject: Re: Aero Composites |
chazking
Posted: Tue Sep 02, 2014 6:48 pm Post subject: Re: Aero Composites |
Weighed the ACS and it's 52.2# with McCauley 4" hub (same size as Hartzell). Hartzell support told me their 2 blade is 52#. No difference between the two, weigh-wise.
