Richard Lamprey
Posted: Sat Oct 04, 2014 2:40 am Post subject: Minimum CHT |
This subject has come up before, but still no clear answer... minimum CHT. The other day, cruising at 9500' over the Great Rift Valley in Kenya, in Europa 5Y-LRY (Classic, Mono, 912 UL, 15 years old, 650 hours), the CHT was down at 55 C. I have very efficient radiators made by Docking Engineering at Silverstone, but never saw the coolant at this low temp. I use to blank off from time to time, but then in the hot desert areas it goes up a bit higher, eg 110 C, so I have to cater for all Kenya conditions. At 55 C it ran sweetly. Rotax info tells me that the normal is 75 C to 110 C. Is any damage done at lower temps?
Richard, 5y-LRY, Kenya.
alanb(at)dpy01.co.uk Guest
Posted: Sat Oct 04, 2014 3:06 am Post subject: Minimum CHT |
I suggest that downloading the Rotax manual for your engine may be useful.
The only ref I can find to operating temperatures is a table referring to oil type and the temperature ratings for differing SAE, apart from the maximums obviously.
Perhaps it should be the Oil Temperature you should be considering.
As to any damage, not willing to speculate - sorry.
Alan
On 4 Oct 2014, at 11:40, Richard Lamprey <lamprey.richard(at)gmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p=431477#431477
thomas(at)scherer.com Guest
Posted: Sat Oct 04, 2014 3:23 am Post subject: Minimum CHT |
Dear Richard,
thank you for renewinging this question. N81EU has now 1.ooo hrs on the
Hobbs and with a modified cooling system. She has flown between the
arctic and the Sahara with sometimes vy low Oil / CHT temps. I do not
see any damage to the engine (e.g. compression), but will like to hear
more input on this.
greetings from the other side of Africa
<Thomas, N81EU>
Am 10/4/2014 11:40 AM, schrieb Richard Lamprey:
gsessare(at)hotmail.com Guest
Posted: Sat Oct 04, 2014 4:24 am Post subject: Minimum CHT |
hi everybody,
i want to leave this e-mail list. how should i do?
regards
| Quote: | Date: Sat, 4 Oct 2014 12:21:43 +0100
Subject: Re: Minimum CHT
--> Europa-List message posted by: Thomas Scherer <thomas(at)scherer.com>
Dear Richard,
more input on this.
<Thomas, N81EU>
> --> Europa-List message posted by: "Richard Lamprey" <lamprey.richard(at)gmail.com>
