DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Mon Nov 03, 2014 4:06 am Post subject: Radio Transmits Poorly Only When On The Ground |
I have a gremlin that I don't know how to troubleshoot. I have a 601XL all-metal airplane with an Icom A-200 radio, a RAMI com antenna mounted on the top skin and connected with RG-400 cable. I did all the installation myself. I have had this flying for 6 years now. It transmits just fine in the air, but when I initially installed it, I would get comments that it was a bit garbled while transmitting on the ground. It was always good enough though, as I could still carry on a 2-way conversation, plus I was able to operate out of tower controlled airports and not get any negative radio comments. Receiving wise, I have always been able to hear just fine whether on the ground or in the air.
Just this summer, I started to get comments from fellow pilots that I was totally unreadable while transmitting on the ground. It would become crystal clear as soon as I took off. Does anyone have any thoughts of why this could be occurring or any place in particular I should start my troubleshooting??
_________________ David Gallagher
Cincinnati, OH area |
ceengland7(at)gmail.com Guest
Posted: Mon Nov 03, 2014 11:50 am Post subject: Radio Transmits Poorly Only When On The Ground |
On 11/3/2014 6:06 AM, DaveG601XL wrote:
David Gallagher
Zodiac 601 XL-B: flying, 280+ hours now
Next project under construction: Finish my father's Aircamper
Everybody, or just some other pilots? I have a similar issue with my
MicroAir when in receive mode and flying within a few hundred feet of
another a/c. I'm pretty sure that the AGC (automatic gain control) in
the MicroAir doesn't have enough range to avoid overdriving its input
when the transmitting a/c is close. Other radios don't have this problem
in the same environment.
Charlie
yellowduckduo(at)gmail.co Guest
Posted: Mon Nov 03, 2014 2:48 pm Post subject: Radio Transmits Poorly Only When On The Ground |
I had a somewhat similar issue with that radio. At the time I had an
assortment of headsets with different but not definitive results.
Opening the case and reducing the mic gain helped but a slightly
different setting seemed optimum for each headset . Eventually I noticed
that the problem was worse in the morning and typically went away after
10 or 15 minutes by which time I was usually airborne. When I asked
David Clark whether this might have anything to do with my mic they said
yes it could and they offered to replace it which did indeed fix the
issue for me. I bought a second DC headset and have been happy ever since.
Ken
On 03/11/2014 2:45 PM, Charlie England wrote:
<ceengland7(at)gmail.com>
> <david.m.gallagher(at)ge.com>
> Thanks,
> David Gallagher
problem in the same environment.
Charlie
_
