joelhaynes
Posted: Fri Jun 30, 2006 8:50 am Post subject: N557XW Update |
Thanks again to all who responded on and off-line with congrats and advice regarding my first flight and somewhat higher temps than hoped for. I got out the high temp RTV and plugged a few small gaps here and there in my baffles and opened the lower cowl exit area a bit more as others have done. Second flight was this morning after the RTV cured. Full power CHTs at 6500 feet (field elevation is 5000 ft) were 380-390 which was a nice improvement over yesterday. Also, oil temp was 217. This is still likely an overestimate since I need to update the firmware in my Dynon engine monitor to fix a bug causin g artificially high oil temps. Thanks again to whoever it was that pointed that out to me. Without wheel pants and fairings I could only get 2550 rpm at 6500 feet with my 85 inch pitch Sensenich cruise prop. I am assuming that pants and fairings will allow for greater rpms as the speed increases. I certainly cannot complain about takeoff performance, even from our high altitude airport. Now onto fixing the slightly heavy left wing.
WHAT A RIDE!!!
Joel Haynes
7A 1.5 hours
Bozeman
| | - The Matronics RV7-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
