Primer / paint question
Carlos Sa
PostPosted: Sun Jul 09, 2006 5:50 pm    Post subject: Primer / paint question Reply with quote
Hello, all
This is probably going to be obvious for a number of you.
I have applied a first coat of zinc chromate to some parts with a sponge brush.
In some spots, I get an ugly effect when applying the second coat.
It happens almost immediately.
All parts where previously scrubbed with scotch brite (color to remain unidentified), and then
swiped with a clean rag. I always wear gloves while working. Cheaper than H2O2 and band-aids. And
avoids fingerprints.
Any ideas what causes this? I see no apparent pattern...
Carlos
Montreal, Canada
CH601-HD, plans
__________________________________________________________
Lèche-vitrine ou lèche-écran ?
 Filesize:  253.09 KB
 Viewed:  246 Time(s)
 Filesize:  143.44 KB
 Viewed:  219 Time(s)
CH601-HD, plans
Montreal, Canada
gboothe(at)calply.com
PostPosted: Sun Jul 09, 2006 6:18 pm    Post subject: Primer / paint question Reply with quote
Carlos,
You did not say how long the drying time for the first coat was. Is it
re-emulsifying with the second coat?
Somebody out there correct me if I am mistaken, but isn't two coats of zinc
chromate an overkill? It has been my understanding that a thin film is all
that is desired.
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion
Tail done, working on wings....
Hello, all
brush.
Carlos
Montreal, Canada
CH601-HD, plans
jean-paul.roy4(at)tlb.sym
PostPosted: Mon Jul 10, 2006 4:45 am    Post subject: Primer / paint question Reply with quote
Sometimes, too much is worst than not enough.
Just my opinion
Jean-Paul
noelloveys(at)yahoo.ca
PostPosted: Mon Jul 10, 2006 4:59 am    Post subject: Primer / paint question Reply with quote
Do you wipe down the parts with a bit of MEK before priming? If you don't
like MEK, who does, then you can try methyl hydrate.
Noel
[quote] --
