klehman(at)albedo.net Guest
Posted: Sat Jul 15, 2006 3:52 am Post subject: microphone noise |
Good day.
I've tried a couple of headsets but I have a lot of static whenever I
key the transmit button with the headset microphone plugged in. I can
hear it on my headset and it is being transmitted. No static if I key it
with the mic unplugged. So it would seem that the mic is picking up
cockpit noise. However clasping my hand over the boom mic or changing
its orientation does not change the static which seems to suggest it is
not cockpit noise. Any suggestions?
This is an Icomm A-200 radio and an intercom but bypassing the intercom
with its "pilot/all" switch doesn't change anything. The headset jacks
are mounted in a plastic box. Separate shielded wires are used for the
mic and the earphones with the shields carrying the grounds.
thanks
Ken
Posted: Sat Jul 15, 2006 5:07 am Post subject: microphone noise |
Ken wrote:
Quote: |
Good day.
it with the mic unplugged. So it would seem that the mic is picking up
is not cockpit noise. Any suggestions?
intercom with its "pilot/all" switch doesn't change anything. The
headset jacks are mounted in a plastic box. Separate shielded wires
are used for the mic and the earphones with the shields carrying the
grounds.
thanks
Ken
If you have a noisy cockpit, covering the mic with your hand probably
won't make much difference.
Is it electronic static or cockpit noise?
Does it change in pitch with engine rpm? (ignition or alternator)
Is it quiet it you key the mic with the master & all accessories on but
without the engine running? (cockpit noise)
If it's there with the engine & all other accessories off, you might
have radio problems.
If it's there but quieter & no pitch change with the engine idling, it's
probably cockpit noise.
FLYaDIVE(at)aol.com Guest
Posted: Sat Jul 15, 2006 6:10 am Post subject: microphone noise |
In a message dated 7/15/06 7:55:03 AM Eastern Daylight Time,
klehman(at)albedo.net writes:
thanks
Ken
Ken:
You have a good question ... Problem their ... My next question in the
diagnosis would be:
Is the static their when you use any other Headset - Mic Jacks?
If not then the problem is only associated with the Mic Jack you are using.
If the problem still exists on ALL jacks then you have to go back to the
common points - PTT Switch, Intercom and Radio.
Barry
"Chop'd Liver"
"When all the possibilities are eliminated then the only thing left is the
probability"
Posted: Sun Jul 16, 2006 6:59 pm Post subject: microphone noise |
Thank you Charlie and Barry for your thoughts.
It seems that it is cockpit noise that the mic is picking up.
Interestingly I have a flighttech intercom which uses a hot mic and
processes the mic audio to remove the cockpit noise from the intercom.
That works well and there is no noise in the intercom. However when
transmitting, the mic signal (and noise) goes directly to the radio and
is transmitted regardless of whether the intercom is on or off..
Speaking loudly helps for the time being
Ken
Charlie England wrote:
Quote: |
<ceengland(at)bellsouth.net>
Ken wrote:
> Good day.
> up cockpit noise. However clasping my hand over the boom mic or
> changing its orientation does not change the static which seems to
> suggest it is not cockpit noise. Any suggestions?
> grounds.
> thanks
> Ken
but without the engine running? (cockpit noise)
it's probably cockpit noise.
Posted: Thu Jul 20, 2006 6:42 pm Post subject: microphone noise |
Barry
No the hot mic works fine for the intercom. This particular intercom
processes the hot mic signal such that it eliminates the background
cockpit noise from my mic on the intercom. A different concept than the
more common voice actuated intercom and so far it seems to work as
advertised although I'm mostly flying solo right now.
When I transmit, the mic is connected directly to the radio (bypasses
the intercom) and that was when the objectionable noise was being picked
up and transmitted. As per Charlie's suggestion, I reduced the mic gain
adjustment on the radio and that seems to have helped quite a bit.
Ken
FLYaDIVE(at)aol.com wrote:
Quote: |
In a message dated 7/16/06 11:02:12 PM Eastern Daylight Time,
> Ken
Ken:
Thank you for the follow up to your problem. I would have never thought of a
HOT MIC as being the problem.
Is it possible to increase the Squelch by external knob or maybe internal
adjustment to shut off the continually on Hot Mic?
I would give a call to the manufacture and see what they say about the
problem. If you have this problem with their product. I'm sure there are others.
There might be a solution from the manufacture.
Barry
"Chop'd Liver"
