nuckollsr(at)cox.net Guest
Posted: Fri Jul 14, 2006 5:02 am Post subject: External Power and electrical system |
At 09:47 PM 7/13/2006 +0200, you wrote:
<michele.delsol(at)microsigma.fr>
Listers,
I have been planning on adding external power to my system (one alternator,
one battery, PMag IO360). My original design was pretty simple, hook it
straight onto the battery such as one does when jump starting a car.
That works.
| Quote: | Then I
added a relay so that the external power terminals would not be hot when not
connected to external power.
What is the added value? What risks are mitigated by this?
Is your external power INTENDED to crank an engine with a
compromised battery . . . or just to run electro-whizzies on
the ground, or just charge a battery, or just maintain a battery?
Settling on one of these design goals drives the size of your
hardware ranging from a tiny wall-wart charger and 24AWG connecting
leads up to 2AWG welding cable plugged in through a very fat connecto.
| Quote: | Then some knowledgeable fellow builders told me
that I should only use external power for starting the engine nothing
else.
If that was their design goal, that's correct. What's your design
goal?
| Quote: | Then some other knowledgeable builders told me that I could install a
cigar lighter jack in parallel as an external power connector for recharging
the battery.
Yup, that's another achievable design goal . . .
| Quote: | Then there was the issue as to external power not being clean
DC current and consequently liable to play havoc with some of my sensitive
equipment.
If you have a battery on the bus any time ground power is
applied, then externally conducted noises are not an issue.
The battery is the airplane's best firewall against any and
all perturbations of bus voltage.
| Quote: | Based on this I proceeded to design a circuit which would
automatically disconnect all electricals except for the starter solenoid,
current to the PMags and current to my fuel pump. Whereupon another
knowledgeable person suggested that I should remember the KISS principle I
may be over designing my system.
Again, depends on your design goals. What do YOU want this
ground power system to do for you?
| Quote: | What do you guys suggest isolate my electrical system when external power
is hot or just hook it up onto the battery via a relay?
Start with the article at:
http://aeroelectric.com/articles/grndpwr.pdf
This is typical of ground power jacks installed on
type certificated aircraft with a few AEC enhancements
added as described in the text.
This installation may be used for just about every purpose
other than battery maintenance because you need to close
a contactor to get connection between external power and
the battery.
Let's start with what you want the connection to do and
then tailor it to that task. Most of what you were told
is inaccurate and/or incomplete.
chaztuna(at)adelphia.net Guest
Posted: Sat Jul 15, 2006 5:30 am Post subject: External Power and electrical system |
| Quote: | >
>Listers,
> Then I added a relay so that the external power terminals would not be hot when not connected to external power.
Michele,
Earlier you said that you intended to place your battery on the right side behind the firewall. It seems to me, that in this location, you can access the battery on your RV8 by simply opening the front baggage door and reaching down. With this location, why add weight and complexity when there is such a simple and obvious solution? What am I missing?
Charlie Kuss
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Sat Jul 15, 2006 8:05 am Post subject: External Power and electrical system |
It can be difficult to effectively asses one's needs when doing an
initial design. For the most part, whenever I have said to myself, "I
won't need that," I have found that indeed I eventually needed "that".
As others have said, there are three reasons for ground power:
1. starting the engine when the battery charge is too low;
2. to operate the electrical equipment on the ground without
discharging the battery;
3. to charge the battery.
If I were going to craft a ground-power plug I would ensure that it
was usable for all three functions.
Now for an anecdote. At OSH in 2000 I was supposed to fly my CJ6A in
the mass warbird formation on Friday. (I had already flown on opening
day on Wednesday as I recall.) At the proper time we hopped in our
airplanes. It was at that moment I discovered that someone had been
in my airplane and had turned on every switch, including the battery
master. My battery was dead. If I had had a ground power plug I might
have been able to put an initial charge on the battery and start the
engine and still fly in the shoe. As it was, I couldn't.
I considered trying to get some jumpers in there but, as the battery
was back in the empennage under the baggage compartment floor, it was
inconvenient and a rogue jumper cable was likely to do damage to
something. So I very carefully pulled the battery and hauled it up to
the warbird maintenance area were we were able to put it on a charger.
Several hours later the battery was charged and I was in the process
of reinstalling it. I was being extremely careful to keep the
terminal from touching any of the control cables but it was dark back
in there. I had avoided the rudder and elevator control cables but
missed seeing the much smaller trim cable. Of course I managed to get
the trim cable across the battery terminals. The trim cable failed
with a most satisfactory flash and bang. (Yes, the damned thing
literally exploded in my face.) I bashed my head against a bulkhead
and uttered the immortal words. I managed to extricate my temporarily-
blinded eyes from the baggage compartment only to have the pilot next
to me say, "So Sparky, having a bit of trouble, are we?" From then on
my call-sign was "Sparky".
So, yes, I want my ground power plug to be able to do it all. I
consider it to be a safety issue now.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
michele.delsol(at)microsi Guest
Posted: Thu Jul 20, 2006 9:57 am Post subject: External Power and electrical system |
Thanks Bob - as usual it is back to basics. This is what I want to
accomplish :
1 - Jump start the engine because the battery does not have enough juice
left. Would it be OK to just hook in onto the existing battery, turn the
master on, and push on the starter or should all electrics be isolated
except for PMags, fuel pump and starter solenoid?
2 - Charge the battery - cockpit shut, baggage door shut. Here I can leave
the main contactor off to isolate all circuits.
3 - Run electrical equipment in the airplane for testing as I assemble the
electrical circuit - for this one I guess I could just as well hook up an
external source onto the battery terminals or onto the main bus over the
rails. I don't really need an external power source to accomplish this.
Michele
Posted: Thu Jul 20, 2006 9:58 am Post subject: External Power and electrical system |
I've been debating whether to put the battery up front in the forward
baggage area or in the rear. The roar in favor of the rear has been so
strong that I finally capitulated and shall indeed be putting it in the
rear, but I shall prepare the front baggage well to receive the battery and
contactors if my CG permits it after all.
As for external power, Ill wait 'till the battery issue gets finalized.
Michele
mprather(at)spro.net Guest
Posted: Thu Jul 20, 2006 12:38 pm Post subject: External Power and electrical system |
Hello Michele,
Though it is common to 'jump start' airplanes (and cars, etc.), doing so
may likely cause the battery to have a significantly shortened life. As
soon as the engine is running at a speed (RPM) which allows the alternator
to put out it's rated current, the battery will be charged at that rate
(minus whatever operating load is on the system). Lots of people talk of
using a 60Amp (or greater) alternator. Dumping 50Amps+ into the battery
may heat it significantly (not to mention putting a heavy load on the
alternator)...
Matt-
accomplish :
Michele
Posted: Thu Jul 20, 2006 5:11 pm Post subject: External Power and electrical system |
At 07:54 PM 7/20/2006 +0200, you wrote:
accomplish :
See http://aeroelectric.com/articles/grndpwr.pdf
With the battery on line, you can have any equipment running
that you wish. I'd wait a minute or two after plugging
in ground power and charging the battery before you power
up the airplane for cranking.
| Quote: | 2 - Charge the battery - cockpit shut, baggage door shut. Here I can leave
The above circuit allows this also but won't work well
with battery maintainers because of the ground power contactor's
0.8A draw. If you want to run a battery maintainer, add
a small connector directly to the battery bus to connect a
battery maintainer. See:
http://batterytender.com/product_info.php?products_id=4&osCsid=98b86a9d022882459cf6e26026c0edf6
Street price on these is 25-30 dollars.
| Quote: | 3 - Run electrical equipment in the airplane for testing as I assemble the
Use the ground power jack and plug an AC supply into it.
Here's a nice one that will run just about everything but pitot heat
and fat landing lights:
http://mpja.com/productview.asp?product=5386+PS
If it were my airplane I'd have a high current external
power jack like that described above and a low current
tap to the battery bus for a battery maintainer.
At 02:31 PM 7/20/2006 -0600, you wrote:
Hello Michele,
alternator)...
While the "loads" cited are real, they're transient
and not even a minor hazard to an RG battery or an
alternator.
Posted: Thu Jul 20, 2006 5:44 pm Post subject: External Power and electrical system |
At 04:31 PM 7/20/2006, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Matt Prather" <mprather(at)spro.net>
Hello Michele,
alternator)...
Matt- | snipped
Matt,
Providing that your voltage regulator functions properly, you will never damage a battery as mentioned above. As the heavy charge quickly refills the battery, system voltage will rise. The voltage regulator will limit system voltage (and thereby amperage into the battery). This will prevent damage to the battery.
Charlie Kuss
glastar(at)gmx.net Guest
Posted: Thu Jul 20, 2006 8:23 pm Post subject: External Power and electrical system |
Hello Matt,
during winter I had to do jump starts 2-3 times on a now 3 year old
Panasonic, so for the first 2 to 5 minutes I did see on my amp meter a
load of 11-13 Amps coming, however as load is around 4-5 amps from the
cockpit an inrush current less then 10 Amps at the beginning has been
see, a lot more then the std. 1.8 you should charge with. So far I've
not seen a negative effect but I should do that winter a capacity test
to see more.
br Werner
Matt Prather wrote:
Hello Michele,
alternator)...
Matt-
>accomplish :
>Thanks,
>Michele
