MA4-5 part number request
dreel(at)cox.net
PostPosted: Fri Jan 20, 2006 10:12 am    Post subject: MA4-5 part number request Reply with quote
Does anyone know the part number for the large copper washer with three bend-over locking tabs opposite a rotational position locking slot that is used on the right hand side where the fuel inlet finger screen filter is removed for cleaning? I want to check mine but ... anyway, carb is a precision airmotive MA4-5.
Dave Reel - RV8A
Bruce(at)glasair.org
PostPosted: Fri Jan 20, 2006 10:52 am    Post subject: MA4-5 part number request Reply with quote
What's wrong with the old one. You can recondition them by heating to red
hot with a torch and then quenching in water. This will restore the
malleability of the copper. The same trick works on spark plug gaskets.
Bruce
www.glasair.org
Kellym
PostPosted: Fri Jan 20, 2006 11:15 am    Post subject: MA4-5 part number request Reply with quote
With copper, unlike steel or aluminum, quenching makes no difference. You
can let them air cool and get the same results.
Bruce
www.glasair.org
Kelly McMullen
KCHD
Vanremog(at)aol.com
PostPosted: Fri Jan 20, 2006 11:37 am    Post subject: MA4-5 part number request Reply with quote
In a message dated 1/20/2006 10:13:32 A.M. Pacific Standard Time,
dreel(at)cox.net writes:
airmotive MA4-5.
16-A48 and they call it a gasket.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 771hrs, Silicon Valley, CA)
